Question about Haier 45-Pint Dehumidifier
Humidity setting always reads "LO"
3 Suggested Answers
  • 4736 Answers
SOURCE: Unir ran good for 8
In addition to a faulty humidistat sensor, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, contact Haier Customer Support
1-877-337-3639, before your warranty expires.Haier units will generally show an E1 code if a sensor or circuit is faulty and unit will not run at all.
I hope this helped you troubleshoot & solve the problem
Posted on Aug 11, 2011
heinzhvac
  • 229 Answers
SOURCE: "Lo" reading at humidity setting
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end. if this helps please rate me.
Posted on May 17, 2011
Humidity display window always LO
I would go to a box store and get a guage that displays relative humidity and see where it settels at. Your humid may actually be low.
Apr 11, 2014 | Amana 45 Pint Electric Dehumidifier -...
WE have a model DE45EJ - T. The humidifer is not pulling in anything or making any noise or doing anything at all. It says Lo in the bottom reading.
The "LO" in the bottom reading, Indicates the current humidity extraction setting. If the unit was operating properly not that long ago (A couple of hours), the reason it is not doing anything, maybe that there is no humidity above "LO" = 30% at this time. Once it the humidity level rises above 30%, it should turn ON and function normally.
Also, was the timer set to turn the unit OFF at a specific time?
If the unit wasn't working properly a couple of hours ago.
Check the air intake filter for excessive dirt or clogs. Turn the unit OFF & unplug it before removing the filter. While the unit is OFF, remove the bucket, empty it if needed and carefully replace i, making sure it is fitted properly in to it's holder.
Air obstruction: The dehumidifier requires an minimum of 12" to 18" clear air space around the entire unit.
Hope this has helped you further troubleshoot and solve the problem. To assist you further, in case you have misplaced yours, I am including a link to your Owner's Manual that you can download and print for future reference. http://www.haieramerica.com/en/asset/product/4ba7175e54
Jun 22, 2011 | Haier 45-Pint Dehumidifier
Machine runs, but no water is coming out into the bucket
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture/humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | LG LHD459EL Dehumidifier
May 17, 2011 | Haier Dehumidifiers
543515 humidifier runs but doesn't collect any water.
try checking the setting of your humidifier, if the actual humidity level matches, what is set on your unit.
Aug 01, 2009 | Kenmore 54351 Dehumidifier
Humidifier measuring wrong %
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is 2 years old.
Aug 03, 2008 | LG LD65EL Dehumidifier
Humidity reading is 16% when actual humidity is 46%
Running a dehumidifier when the ambient temperature is to low will cause freeze-ups. Also running it when the dew point of the moisture in the air is to low will cause it to freeze up when you set it to low which would be a higher number on the set point.
The hand written number on the probe casing is probably a quality control inspector number.
May 04, 2008 | Danby DDR586R Dehumidifier
User Manual has no guidelines.
When you first turn on the unit it is set to 40% humidity which is the lowest the unit will accept. You can only move the up arrow from that point. The 63 you are seeing is the actual humidity. If you want 50% youo need to press up arrow till 50 is displayed. The manual for this unit is terrible. Just leave it as it is and it will attempt to bring it down to 40%. 30 to 50 is the recommended humidity range.
May 03, 2008 | Haier 65-Pint Dehumidifier
Humidifier stopeed working
You have a bad fan motor. Put your hand against the grill to see if there any air movement. You need to buy a new fan motor assembly, it is attached by two long
bolts, easy to swap, except the wiring may not be easy. May have to cut the 3 wires and resolder. Get to the motor by removing the back panel and then the fan. Removing the fan may not be easy, they put some gunk on the spidle thread.
The cheapest price I have seen for the motor is $27-$28, shipping about $8 and tax
about $1.5.
Sep 18, 2006 | LG Goldstar LD65EL Dehumidifier
How to use
sorry its kind of late. if you still have this problem let me know
Sep 03, 2006 | Kenmore 54501 Dehumidifier
Haier 45-Pint Dehumidifier Logo
73 people viewed this question
Top Haier Dehumidifiers Experts
Shawn DuRee
Shehu Pro
Shehu Pro
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
