Question about Pioneer PDP-4350HD 43 in. Plasma Television
TV OK when displaying Sky, but on terrestrial the picture occasionally breaks up with audio crack. Aerial signal is good, with a new aerial and aerial amplifier. Problem is gradually becoming more frequent.
    Sergeant:
  • 247 Answers
Sounds like a simple cable issue, have you tried switching out the audio source cable? Or are you running HDMI? if so I would switch out the HDMI cable also.. Hope this helps..
Posted on May 28, 2011
What do you know about the hdtv rotar remote outdoor amplifier antennaes, will it solve our tv breaking up in the picture
if the pic breaks up due to signal loss a message will be displayed on the screen,(no signal)
if the signal is weak and not arriving at the aerial then there will be nothing to amplify
I would check that all connections from the back of the tv right up to the aerial are ok,check that you have line of site from your aerial to the transmitter ie-no trees in the way,is the aerial aimed in the correct direction,sometimes strong winds can turn an aerial
Have a look at your neighbours aerials ,how do they compare with yours,
I dont think you really need to install a fancy aerial for no real gain
Len...
Sep 03, 2014 | Televison & Video
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
The aerial port does not work.
It is possible the tuner or antenna connection is bad---If you can call up the menu with the remote set needs to be switched from cable etc to air or antenna and channels programed------not on the rear input connection but for the tuner in the set (presume it has a tuner if antenna connection of any type is there.
Oct 29, 2012 | Televison & Video
Wil my tv work with out remote
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.connecting the speaker wires of an RCA TV to an amplifier: The signal that is fed to the speakers is not designed to be fed to the line-level inputs of your amplifier. You'd need some kind of conversion and I can't tell you exactly what that would be.
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
Nov 22, 2011 | AOMNI Corporation Televison & Video
I have a brand new technika tv 216/54g. It has freeview built in. I have a brand new indoor digital amplified aerial also technika but I cant get it to pick up any stations. Do I need anything else? please...
You don't necessarily need anything else, but you may not have a strong enough signal to pick up the digital/freeview channels using an indoor aerial. It could also be that the indoor aerial is not correctly aligned.
If the signal strength is lower than approx. 50%, the TV may detect them during the automatic channel scan but it wont store them. When the signal strength for any digital channel is 50% or lower it's more or less unwatchable - the picture would be constantly breaking-up or freezing and the audio drops out continually. Trying to scan for channels using an indoor aerial is rather hit and miss. Numerous attempts may be necessary before you get any channels.
Assuming you have a roof aerial, it is far easier to temporarily connect the TV to a fixed aerial point while you run the automatic channel scan. The TV will store all the channels and you can then move it to it's permanent location and connect the indoor aerial. You can then adjust the indoor aerial with the channels already stored until you find a location for the aerial where you have a good signal.
Doing it this way also eliminates the possibility of a fault with the TV and confirms that you are performing the channel scan correctly. If the TV is connected to a fixed aerial point and you are still unable to receive or store any channels, then it's likely that you are performing the channel scan incorrectly or there is a fault with the TV.
Please try scanning your channels using a known working fixed aerial point. If you are still unable
to receive any channels - or you don't have any fixed aerial points - please post back for further assistance.
Hope this helps.
Regards,
BElectric
Feb 28, 2011 | Televison & Video
Our new digital LCD tv occasionally suffers from picture breaking up and even total loss of signal, after some time, 5 to 15 minutes the signal is restored. Fiddling with the aerial run and connections has...
Tune to a strong channel.
Go into the menu. Find the Channel or Antenna whatever your tv calls it. Set the signal strength display.
If the signal strength show good and your picture is lost then a problem may be in the tv.
More than likely the antenna is not picking up a strong signal. Try rotating it some.
You can go to www.tvfool.com to see what stations are in your reception area.
Feb 13, 2011 | Televison & Video
No signal on teristeral but able to watch tv through sky
This could be down to several things so sorry if this is long winded but really needed more info from yourself...
Sky gets its signal from the dish mounted on your exterior wall.
your terrestrial signal comes from your terrestrial aerial be it external or internal.
If you do have an aerial cable coming into your property and it is connect to your television. Go into your TV MENU and set it away on Auto Tune if this does not come up with any channels. Try auto tune on your built in Digital tv ie DTV if it has this option...
If neither of these work then you need a new aerial or it needs to be re-aligned.
Personnally I would not bother with a Terrestrial Aerial You already have Sky installed so this will be fine for when the Whole of the UK goes digital. Dont be fobbed off by people telly you that you need a Digital aerial as your sky dish is already Digial anyway.
Hope this Helps
Little Dish Fitter
Apr 12, 2009 | Samsung 37 in. Flat-Panel LCD HDTV
New aerial wont pick up digital reception and fuzzy picture on terrestrial channels
Hi.
If you put aerial up your self was it wide band aerial ?
Is it in the atic or on the roof ?
Have you used decent quality cable (not the cheap stuff)
How long is cable run from aerial ?
Have you checked that when you fitted rf plugs that none of the braid strands are touching solid copper inner core ?
Ask an earial installer or Tv shop what the signal strength is like in your area.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Televison & Video
Pioneer PDP-4350HD 43 in. Plasma Television Logo
64 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
