How to replace rubber door seal on zanussi washer zwf1432w
3 Suggested Answers
apart4u
  • 213 Answers
SOURCE: how to fit a door seal on zanussi washer dryer WDT 1085
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
  • 13 Answers
SOURCE: my zanussi zwf1432w washing machine the rubber
Thats algae, you need to replace the rubber.
Posted on Feb 15, 2010
Zanussi fl 1084 washing machine door seal. How do I replace the rubber seal?
the seal comes in a shrunken size use a hair dryer to stretch it on to the door lip
Dec 03, 2013 | Washing Machines
Black mould
this is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
May 13, 2010 | Zanussi ZWF1440 Front Load Washer
My zanussi zwf1432w washing machine the rubber
Feb 15, 2010 | Washing Machines
IS IT EASY TO REPLACE THE DOOR SEAL/GASKET ON ZWF1430W
it is very very difficult to replace the door seal on a zanussi washing machine, its best fitted by an engineer
Feb 03, 2010 | Zanussi ZWF1430W Front Load Washer
Bearings hve gone and washer is just 3 years old is it worth having them fixed or should i get a new washer costing under £200 its a zanussi zwf1432w
Replacing drum bearings is very costly, average cost around £130 so you would do better to replace it.
Jul 29, 2009 | Washing Machines
Zanussi fjr1454w door seal change.
with both clips,< locking rings > removed seal it is removable by just working it off the drum slowly,< there is overflow tube in front bottom side to disconnect also>. It is very important when installing new one that you put it in the same positiont as old one and lock rings go on same as well.
Apr 26, 2009 | Zanussi FJ1454W Front Load Washer
Mouldy Door Seal
Use tilex to remove the mold. Then see what happens. If the mold comes back right away it may be a problem with the rubber gasket not seating as it should. Let me know. And please rate my solution. thanks.
Feb 02, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi 1035E
you have to check the electric door lock first open the door then take out the metal ring posted on the rubber seal then you have two scews on the font where the latch of the lock unscrew it and change the electric lock
May 11, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
