Question about Hitachi 500GB External USB 2.0 Hard Drive
I have a hitachi oso 2520 external hard drive how do i back up my computer to it where can i find instruction manual
  • Hitachi Master
  • 27,725 Answers
Depending on your operating system this may vary in windows7 click start control panel you should see system security tab in that back up then windows will ask for a back up DESTINATION location you can select either dvd or another device or in XP click start all programs accessories system tools you should see back up after the back up finishes windows will tell you your computer back up was successfull also you could right click on the back up file select properties this will tell you how many GB were used
hope this helps
Posted on May 28, 2011
So my internal hard drive is screwed this already know and Im wondering if I can somehow attach it to my external hard drive which is the Hitachi Oso and get the information off of it so possible im n
If the HDD sector zero is damage, there is no way you can use your HDD internal or external. You could try and change the board with another one of the same specification. If the HDD is just stuck from the inside, then you could take it apart and just move the pointer. Good luck.
Jan 22, 2015 | Office Equipment & Supplies
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
My hard drive is not being recognize
Jan 06, 2013 | Computers & Internet
I dropped Hitachi external drive...
If you have no backup and your drive is damaged, that is it, no data.
Plug the usb in with your drive, leave your computer looking for the drive. If windows, it may take some time. If Mac it won't be long. If neither can see it, the TOC is damaged and it will need a computer engineer to try and recover the drive.
May 28, 2017 | SimpleTech by Hitachi SimpleDrive Rev. 3...
Hello, I have a new Hitachi Life Studio external drive but cannot read the tiny printing in the book I need to transfer the photographs from my computer onto the external and don't know how to d
Hello. I understand how hard it is to read some of those instructions. Here is a link for you to copy/ paste that takes you to Western Digital. They bought Hitachi. This is the PDF instructions that you need to be able to install the software correctly to do your backup.
http://www.hgst.com/hdd/support/pdf/Quick-Start_LifeStudio_Desk.pdf
Hope this helps you..
Nov 03, 2012 | Computers & Internet
Won't back up to hitachi external hard drive
hmmm what backup software are you using, from windows or hitachi? seems if the computer can see the drive, then it's a file formatting issue that you are facing.
May 24, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
There were no instructions on how to download files from my c drive to an external hard drive....need to know how to do this. I have plugged the hard drive (Hitachi 500 gb - usb 2.0 into the usb port on...
to copy the files from your computer hard drive to external had drive first you will have to select the files needed to be transfered then copy them and open the external hard drive and make a new folder and paste them
Mar 01, 2011 | Computers & Internet
The unit won't turn on... fry's on 8-17-2010...tooo much info to loose this is the 2nd, time that i have used it
You can still save your information if you remove the actual hard drive from its enclosure.
Simple as opening the enclosure, remove the hard drive then use an external hard drive dock - here
A hard drive dock instructions are here. Youtube: http://www.youtube.com/watch?v=OUrw9W3-FcA
and connect it to your computer for back up to a new hard drive.
A how-to can be found here. Youtube = http://www.youtube.com/watch?v=hQ_vjyvK28A
Let me know if this works.
Dec 21, 2010 | Hitachi External 1TB hard drive 7200RPM...
Hitachi 500GB External USB 2.0 Hard Drive Logo
269 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
