Question about RCA 32V550T 32" TV
TV Sparks inside case
When I power up this tv it sparks near what looks like the power supply. Bright blue power! Looks cool at night but not as good as the Olympics coverage after 3 times.
  • 876 Answers
I think I would turn it off and unplug it. You could get an estimate on reparing the power supply cord or whatever the problem is or the TV maybe ready for replacement.
Posted on Aug 16, 2008
Bought a new power supply since the previous power supply looked burned and short circuited. Installed the new power supply and sparks flew inside the Tv right when I plugged it in.
If you look around at where the sparks came from or for evidence of burnt parts inside the TV - not in the power supply - then you will find the fault that probably caused you bad looking power supply in the first place!
Oct 20, 2015 | Samsung UN37EH5000FXZA 37in Led 1080p 60hz...
Why does tractor runs fine til it warms up then stalls and wont restart til cools down
Check to see if you still get spark at the spark plug wire when this happens, common problem is a "Hot Coil" the coil windings breakdown under high heat and causes a stall until it cools down, just pull a plug wire place it near engine ground with a small gap see if there is a bright blue spark when you crank the engine over. If no spark, or it is weak orange spark..let it cool down then try it again if it then sparks bright blue you have a coil issue and it needs replaced. I have also had key switches over heat and stall the engine as well check your wiring connections on the key switch if its burnt looking there is also a problem.
Jul 29, 2014 | Craftsman Garden
Apex ld3249 shot sparks out and tripped the breaker
A nasty short somewhere or wrong voltage to set---do not keep plugging it in and tripping the breaker--in fact do not plug in at all until a technician examines it(tell him/her what the issue is).
To answer the question here: Dead short on or across the AC voltage line inside the set most likely of primary side of power supply.
Nov 04, 2012 | Apex Digital LD3249 LCD TV
Toshiba TV dead: is there a fuse inside? Toshiba 24AF46 is dead after a thunderstorm and nearby lightning. Plug sparks when I plug it into the wall. Nothing happens on the TV. No sound, nothing when I hit...
Yes,there is a fuse in inside on the tv main pcb board near the power a/c cord.But if the tv have sparks,main pcb board could have more other components fries too.If tv less 10 years repair it by a shop,more than that should buy a another tv.
Jun 09, 2011 | Toshiba 24AF46 24" TV
POWER SUPPLY
zenith are famous for bad soldering even going back to the 80s with the 960-05 boards in the space command sets.
i would pull out the circuit board and check the soldering before doing anything else.
Sep 09, 2009 | Zenith Televison & Video
TV sparks inside case
there will be a problem in powersupply.and ity is best to be checked by the technician in order to see the deffective parts..
Aug 16, 2008 | RCA 32V550T 32" TV
Arcing blue sparks internally
the thing which you have seen is resistance not the capacitor. whenever that goes hot or arcing it is due to heavy short ckt in tv. as you are not much aware of tv technology please caall skilled person to do it for you. please now do not start again unless it is repaired. otherwise it may be problematic. good luck.
Oct 06, 2007 | Sanyo DS24425 24" TV
Sparks
Where exactly are the sparks coming from? If you remove the back of the TV, can you see exactly where the sparks are coming from?
Sep 14, 2007 | Sanyo DS24425 24" TV
RCA 32V550T 32" TV Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
