Question about Refrigerators
I have a Kenmore 596.61852101 refrigerator with freezer on the bottom and there is a fish smell coming form the back near the fan. Took the covers off in the back to locate anything dead. notice a stong smell coming from the one of the holes where the srews holes are located to fasten the fan cover onto the frige. No water on or underneath the frige.
  • 87 Answers
SOURCE: Frigidaire side by side, water leaking onto bottom of freezer
If you looked at the back section of the freezer (inside) and found ice then you need to completely defrost the fridge freezer. What you are describing is a frozen evaporator and the freezer needs airflow to work properly. If the unit starts behaving normally after defrosting then you need to monitor it closely as they will normally start playing up again after 2-3 weeks. If it does fail again then you probably have a defrost problem normally the defrost heater but can also be the defrost timer o defrost sensor. If it fails to reach temp then I would suggest contacting a decent repair guy who should be able to diagnose which one within a reasonable time. I would recommend defrosting first though because the same symptoms can happen when a door is left ajar. Hope the above is of some help.
Posted on Sep 14, 2007
  • 29 Answers
SOURCE: Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Posted on Aug 13, 2008
tborn6
  • 700 Answers
SOURCE: Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
Posted on Mar 27, 2009
turbo5280
SOURCE: Kenmore refrigerator freezer not freezing
The problem is in the defrost system.. You have a defrost heater in your freezer that comes on 3 times a day & melts the frost to keep your freezer frost free. That frost turns to water & runs down a drain & eventually goes to a drain pan located under the unit. On these models the hole for the drain is located directly under the evaparator fan. The drain hole is to far from the heater so the water settles & then freezes around the fan blades causing it to stop spinning. Its that fans job to circulate cold air from the freezer to the fridge, so now all the cold air is staying in your freezer. Last I knew they were workin on a solution to this but you need to contact the manufacturer. A temporary fix would be to unplug & then defrost the freezer by taking out the freezer panel & melting all the ice. Boiling water is effective. When you get the ice gone from around the fan you should be able to see the drain hole & be sure water runs freely down the hole. Put it back together then adjust the front legs of the fridge so the whole unit slopes back slightly causing the water to run back to that drain hole without settling.
Posted on Apr 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Dead fish smell from my Kenmore Elite Bottom Mount Refrigerator
dead fish smell ( under the frig there is a cond pan that collects water from the defrost . whirlpool has some tabs that you can put in pan/ it helps .. I would put a cup of bleach in pan every 3 months . and if you can find the drain inside the freezer add it thorugh the drain . algae builds up in drain and plugs it . mm
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE side by side refrigerator smells on the outside!
Mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section . Too much bleach and the smell of bleach would be circulated by the fan to the room , so be sure to add water .
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Smell fish odor when fan comes on.
Tim, Clean the refrigerator completely with clorox and water. Unplug and remove the rear panel in the back of refrigerator and wash the evaporator coil with this solution. Check the amount of flow to the condensate pan below. The drain line has the gel and this contaminated smell from top to bottom and you will need to insure that all the smell remaining in the drain is draining freely and decontaminated with the clorox. Do these things and wash the remaining pan below the best you can and you will be set to go.
Jun 20, 2009 | Whirlpool GD2SHGX Refrigerator
Horrible oder
You are going to have to take the back cover off and investigate. Check the defrost drain pan first. If anything from the freezer, like raw meat juice, went down the defrost drain, it would end up in the defrost drain pan, usually located very near, possibly on both sides of, the fan motor at the bottom of the refrigerator. The next thing to look for is a dead mouse. They like the warmth from the refrig., and can get killed from a fan blade, electrocution, or if they ingested poison, that makes them thirsty and the warmth plus the availability of the water from the defrost drain makes an ideal place for the to curl up and die. (A dead mouse usually dehydrates and stops smelling after a few days.) All that sounds like lots of fun, right? Happy hunting and good luck.
Jan 13, 2009 | Kenmore Refrigerators
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer problem (icing behind cover inside of freezer)
Several things to check. Refrigerator needs to be put in manual defrost mode, then check defrost heater and defrost thermostat.
Jun 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
