Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Propane Gas
When we opened the pool.. the heater came right on.. we shut it for a few weeks.. but now,, it ignites, but stays on for only a second then blows out.. i have backwashed the filter as i have fgound it has helped in the past.. but dont know what to test next
    Top Expert:
  • Teledyne Laars Master
  • 6,465 Answers
Check flame sensor
Posted on Mar 19, 2016
5 Suggested Answers
  • 139 Answers
SOURCE: laars lite 2 pool heater burners will not ignite
millivolt readings are independent of pump and filter.just make sure heater is in off position for accurate read
Posted on Jun 21, 2009
  • 9 Answers
SOURCE: Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
Posted on Jun 28, 2009
  • 2598 Answers
SOURCE: cannot start teledyne laars pool heater
Hi should be horizontal crack pipe and see if gas is there do this with every thing off then pruge pilot line should have gas then
Posted on Feb 17, 2010
  • 3 Answers
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Posted on May 29, 2010
Boiler ignition is loud, boiler runs for a few seconds then goes out
flame sensor, air flow restriction or blower not producing enough pressure. clean the flame sensor to start. inspect venting, etc
May 13, 2013 | Jandy Lx Pool & Spa Heater - Electronic...
Hi I have an H400 hayward. when heater is activated, it stays on for 5 seconds then shuts down eventually reading ignition failure code or IF on screen. the ignitor is new, the heat sensor is new, the gas...
When you say it stays on, Does the main burner actually light? If the burner never lights, then I'd look closely at the igniter, as it also acts as the flame sensor. Possibly you have a good enough ground to get a spark, but not good enough to sense the flame. If the main flame is starting, look and see if it is blowing off of the igniter. If this is the case, perhaps it isn't in the correct position, or there are still a few dirty passageways in the main burner. You can download a manual for your heater here: http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
Aug 10, 2010 | Hayward H400 High Wind Stack
Pool heater shuts off after a few second
You didn't indicate your exact model. There are different versions of the H200 series. If it is milivolt then there is no electric, Must have correct milli-volt pilot generator. If it's electronic, check the air flow pressure switch on the combustion air.
Jul 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
Opened & cleaned pool. Haward 250 Heater woun't stay on.
Could be a dirty or faulty ignition sensor. This is the sensor that tells the heater that there is a flame burning normally. If that sensor gets dirty or fails, the heater thinks there's no flame even though there is and cuts the gas as a safety measure. Cut the power, remove the cover, and check all the wire connections to be sure the leads are clean and dry and snug. The ignition sensor is near the bottom. If that doesn't work, then the sensor might be faulty rather than dirty. Call a tech to replace it.
May 30, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward heater not staying lit
possibly poor pilot adjustment or insuficient mv output from thermopile
Jun 19, 2009 | Hayward H Series Millivolt 250,000 Btu...
HEATER GOES OFF ON EO2 OR EO4 CODE . WATER FLOW IS 145GPM HEAT EXCHANGER IS CLEAN FAN WORKS FINE. VENT PIPE HAS BEEN CLEARED OUT THIS IS A MINI-MAX 400 I RUN A FAN BLOWING ON THE HEATER AND IT STAYS ON...
EO4 is the heater fan error, it may go on briefly and then shut off after only a few minutes. most likely cause is a blown fan-there is a thermal switch installed on the blower fan that shuts off the fan when it gets too hot. the only workable solution is to replace the blower fan unit completely also 145 GPM is a very high flow rate; normal residential pools operate in the 40-70 gpm range and 110+GPM on commercial pools if this is residential you may have too much pump for your system. 1 1/2-2 hp is standard if you also run an automatic vaccuum off the same pump
May 07, 2009 | Pentair MINIMAX NT TSI IGNITER
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Propane Gas  Logo
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
