I have a WD 500GB external drive wich I bought a couple of years ago and I believ I have fried the firewire interface, I have just purchased a dynamode 3.5" sata/ide enclosure but the connections do not appear compatable, any advice you have would be very welcome
    Problem Solver:
  • 6 Answers
If you open up the WD external drive to get at the actual hard drive inside, you'll see the drive is either ide or sata then you can put it into the enclosure.
Posted on May 29, 2011
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
Sep 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
WD Recognition problem
if it supports firewire plug it trough it, if not replace usb cable, because there may be problem with power, or data transfer with is most cases. replacing ac and cables should help if not drive is most likely is psychically damaged.
Sep 22, 2009 | Western Digital MY BOOK HOME 1TB EXT...
My Apple G5 and WD Passport 500Gb don't mount
You need to determine whether the problem is at the disk interface or at the computer interface. Will the drive mount on ANOTHER machine using FireWire? Will your computer mount ANOTHER device using FireWire? This will tell you which machine is at fault. It's not unheard of for the FireWire channels in a Mac to just go bad, and (unless it is a Mac Pro) it typically requires a logic board replacement to address. For a G5, this would not be cost-effective. On the other hand, as I say, it could just be a bad interface in the drive itself. It's up to you to determine which it is.
Sep 20, 2009 | Apple iMac G5 Desktop
WD 500GB MyBook stopped mounting on MacBook Pro
Have you tried it in another computer? I think these kind of problems can sometimes be caused by USB voltage problems, especially if your MBP has an old battery (I believe the battery is used as a power buffer to keep size of transformer down). If that doesn't work, see if you can find someone with the same HDD power supply and try switching that over. Failing that it's data recovery, you may be able to do this yourself by switching the actual hard drive into a new enclosure.
Aug 23, 2009 | Western Digital 500GB My Book Pro-External...
Can I Repartition WD 500GB My Book Firewire Drive w/DATA ON IT?
Greetings.
You will need to have a third party software to achieve this. I recommend norton partition magic. I have been using it in the same scenario as yours and works. they now support firewire. Easy to use and gets the job done.
Hope that helps.
Jan 10, 2009 | Western Digital My Book Essential Edition...
Dell Inspiron 1525 - Firewire not working
It may be the communication setup.
You might need to set within the Camera PTP protocol.
The WD drive specs out a 6 pin connector, not a 4 pin.
Nov 17, 2008 | Computers & Internet
I recently purchased an external hard drive, and how do connect it to my computer.
External Hard Drive is mostly of the USB interfacing type. If urs one is the same, then it is just as simple as plugging in a pen drive in the USB port. If it has external power supplies then u can easily figure out how to connect. There are two parts in the power supply (if external power supply cable is provided), 3-pin main power supply connector and other is the adapter which goes to the external hard drive.plug in the other end of the adapter into the hard drive (there is a hole in it). connect the main power cable to the adapter extension. now for the usb Hard Drive, connect the USB cable to the USB port of the computer. Switch on the power supply to the Hard drive and u r ready to use ur brand new External Hard Drive. If it is a Firewire interfacing one then u may need to open the CPU box, and then connect the firewire connector on to the motherboard firewire port. It is easy to identify, it is a red colored port/connector.
Oct 11, 2008 | Western Digital 500GB My Book World...
My Book firewire not bootable on mac
I picked up a couple of My Books lately( via Ebay), and noticed that i can not get them to work on the Firewire interface with my Dual Core Intel Mac. Shows up on USB2.0 fine however.I found an online reference that said Apple changed some things on the Firewire interface year or two ago, and that vendors had to update their firmware (it related to Firewire devices reporting a unique ID to the Mac).
Jan 12, 2008 | Western Digital My Book Essential Edition...
Computers & Internet Logo
250 people viewed this question
David Payne
David Payne
