Question about Apple iPod nano
Ipod repair How do I fix a faulty PC connection on an ipod?
  • Apple Master
  • 13,433 Answers
IF the connector is broken, see if you got warranty on it, or repair service at
Basicly, you would need to replace the connector if its broken, if you need to ask how, then its best that you take it to someone or apple for repair.
Posted on Sep 11, 2008
Ipod conection been snapped off fromthe arm, where can i get it repaired in northants
contact b and w service, they will repair, if you indicate that you have the red flasing light and the ipod does not play, they may fix it foc, but you may be charged. if it is an older model and has not been in for repair then they should upgrade the power supply, it depends how you wish to deal with them. some that are repaired have faulty arms, broken speakers and they fix it because of the problems with the units, pr i suppose, but contact then, see how you get on.
Feb 26, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
My left headphone of my ipod is not working anymore what can i do to fix this ?
The headphone may be faulty and not the IPod. Connect a different headphone to the IPod to check if the left headphone is still faulty. If the left headphone is still faulty then the IPod headphone is probably faulty and needs to be repaired.
Jan 20, 2011 | Audio Players & Recorders
Ipod wont turn on
connect it to your pc first and let it charge bcos it seems the battery is down
Nov 07, 2009 | Apple iPod touch
Sounds like the backlight of your LCD screen is broken. You can try to replace the LCD screen yourself, the part is available on any auction website. There is an iPod classic Repair service that can fix it for you. There is an iPod classic repair guide that can show you how to do the repair yourself.
Jun 26, 2009 | Apple iPod classic MP3 Player
My ipod apple 2G cannot detect to PC,
Computers dont detect ipods as storage devices. make sure you have itunes installed and then sync your ipod to itunes. and move all the mp3 music to itunes by going to File - Add Files. and then you can put that music on your ipod nano
Jun 19, 2009 | Apple iPod nano
My ipod wont switch on
I would suggest you take it in to the apple store for repair already. Most often this type of problem is hardware related already.
Mar 07, 2009 | Apple iPod nano MP3 Player
My ipod wont start and wont show up in my computer or itunes
Have you changed the power cable? most likely faulty power cable. but if that doesnt fix it your ipod has an internal problem and needs to be sent in for repair I had same problem but new cable fixed it.
Feb 06, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod not detecting on my pc
The first simple fix is to check that the connector socket on the ipod is free from lint etc. Use a quick puff of air. If it's accepting charge but not connecting to the pc it is one of two things.
  • Worst case scenario, the Logic board is dead and needs replacement. Not as expensive as it sounds. Call me
  • Hopefully though it's just a software thing. Install the very latest version of iTunes from the Apple site. Although they are identical models they might not have the same software version on the iPod themselves. Once iTunes is updated try syncing the faulty iPod. If it still doesn't connect it's probably the board.
All the best.
Dec 14, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod repair
Sounds like you have a board problem.
Try either or They specialize in ipod repairs.
Dec 12, 2008 | Apple iPod nano
Ipod won't charge
It means the hard drive is crashing. If it's clicking it means there is a problem with the hard drive. Try restoring your ipod or reformatting it.
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. 5rs_reset_clickwheel.png
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
iPod's battery doesn't charge Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port iPods that connect to USB ports require a high-power USB port. Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or FireWire port on the computer.
FireWire port on a Windows PC The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip: Some Macintosh computers can charge iPod even though they're asleep. If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
You are using Windows 2000 If you use your iPod with a computer using Windows 2000, see document 304801 "iPod: Proper charging procedures for Windows 2000" for steps on how to keep iPod charging.
There are too many devices in the FireWire chain Your computer can provide power to FireWire devices that don't have their own power sources, such as hard drives and cameras. If there are too many of these kinds of devices connected to your computer, iPod may not be recognized.
  1. Disconnect all devices from your computer's FireWire port(s).
  2. Connect iPod to the computer's FireWire port using the FireWire cable that came with iPod.
If this resolves the issue, consider purchasing a powered FireWire hub to connect your nonpowered devices to. These hubs are available from the Apple Store.
iPod is locked up If iPod is locked up it will not charge, reset iPod. When you reset iPod all your songs and files are saved, but some customized settings may be lost. Tip: iPod will not wake automatically if you connect to a 4-pin FireWire port. Press the Select button (center of wheel) to wake iPod.
Faulty cable If something is wrong with the FireWire or USB cable that came with iPod, it may not supply any power to charge the battery. Note: Only iPod models with a Click Wheel can get power from a high-powered USB port using the supplied cable (includes iPod mini, iPod (Click Wheel), iPod photo, iPod with color display, iPod nano, and Fifth Generation iPod).
  1. Make sure you are using the cable that came with iPod. Some third-party cables may not work properly with iPod.
  2. Make sure nothing is in or blocking your computer's FireWire or USB ports.
  3. Check the connections to make sure the cable is completely plugged in.
  4. Try another known-good FireWire or USB cable if available.
If this resolves the issue your FireWire or USB cable needs to be replaced. You can arrange for replacement at the iPod Service Website.
Faulty port on the computer If something is wrong with your computer's FireWire or USB port, it may not supply power to iPod. Note: Only iPod mini can get power from a high-powered USB port using the supplied cable.
  1. Check the connections.
  2. Try another known-good FireWire (or high-powered USB) port on a different computer if available.
  3. If you do not have access to another computer, use the Apple iPod Power Adapter.
  4. Plug in one end of the FireWire cable to the Apple iPod Power Adapter and the other end to your iPod.
  5. Plug the Apple iPod Power Adapter into a working electrical outlet.
  6. If you have an iPod (with Dock Connector) model, connect the FireWire end to the Apple iPod Power Adapter and the dock connector to iPod. Warning: Never plug the dock connector end of the FireWire cable into a computer's FireWire port.
If this resolves the issue, consult your service and support guide to see how you can have the computer's port repaired.
Faulty Apple iPod Power Adapter If something is wrong with the Apple iPod Power Adapter, it may not supply power to iPod.
  1. Try another known-good electrical outlet.
  2. Make sure all the connections are good. Try disconnecting and reconnecting all connections to make sure they are snug.
  3. Try another Apple iPod Power Adapter if one is available.
  4. Try connecting iPod to a computer's FireWire port using iPod's FireWire cable.
If this resolves the issue the Apple iPod Power Adapter needs to be repaired. You can arrange for repair at the iPod Service Website.
You might consider additional troubleshooting steps for the Apple iPod AC Adapter before having it replaced.
Faulty dock connector or FireWire port on iPod If something is wrong with iPod's FireWire or Dock Connector port, it may not supply power to iPod.
  1. Make sure nothing is in or blocking iPod's FireWire or Dock Connector port.
  2. Check the connection to make sure the FireWire or Dock Connector cable is completely plugged in.
If this did not resolve the issue iPod needs to be repaired. You can arrange for repair at the iPod Service Website.
Related Terms: charged, dead, die, dying, drained, draining, drain, drains, frozen, freeze, freezes, freezing
Keywords: ktech kipod kipodwin kipod1 kipod2 kipod3 kipod4 kipod5 kipodphoto kipodmini kipodmini2 kshuffle kipodnano kipodnano2 kshuffle2 Did this article help you?
It solved my issue...
Tell us what works for you.
It's good, but...
Report typos, inaccuracies, etc.
It wasn't helpful...
Tell us what would have helped.
Apr 21, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
