Question about Hitachi P50H401 50 in. Plasma HDTV
I have a hitachi p50h401 and sound went out. someone said update software how do you do that? Thank You
    Sergeant:
  • 247 Answers
Well if the sound went out it may have only effected 1 output source, What type source are you using, HDMI, RCA, Composite, DVI, VGA with mini adapter? If for example the HDMI, port you are using has simply lost sound to that port, HDMI carries both sound and video so simply moving to HDMI 2 or even 3 may solve this issue. Also i would suspect the cable you are using, HDMI cables are often defective. If you are using coax thru your cable company i would also change that coax from your tv to the hd box.
Posted on May 28, 2011
  • 4 more comments
  • jap3232 May 28, 2011
    hulk917 I am getting sound from my dvd player with surround sound. Cable company was here a few months ago and put new cables and box and checked everything and told me I had no sound anywhere. I thought it was a problem with the hd cable receiver but they said it is the tv. any ideas? TY
  • John Waters
    John Waters May 28, 2011
    Interesting, I have heard this problem many times, I use to work for Charter Com, Cable and Internet tech support, and this issue is always a cable, are you running an hd box and if so are your coming in from the box via hmi or coax?? Often thee are also SAP settings in some of the newwe models that will only effect your cable.
    It was a charter rep that was here. I have a new hd box and he put new cables from the box to the tv the hdmi cable I think goes from my surround sound to the tv. He took the cables and checked the tv sound with both hdmi and the regular cables. also checked the settings on the tv it was all ok but no sound. I did have a bad hd box which was replaced. My screen would turn green when changing channels. I have a booster in the house because of signal strength and have had a few problems with the cable company
  • John Waters
    Hmm i see a surround sound system is in the mix, try bypassing the surround sound system and go to the tv directly from the hd box and see if your getting audio from the tv itself. I would also consider using the color stream rgb cables to rule out a hdmi port issue. also did you check your sap settings in the tv itself if sap is on turn it off. often sap settings can trigger a silent mute.
  • John Waters
    Also was wondering have you tried bypassing the hd box completely to see if basic cable without the box has audio. I worked for charter for about 5 years and have seen some pretty bad issues that often turned out to a misdiagnoses by the field tech whom installed the set up.
    I know the rep did all you said he bypassed the box and went direct to the tv also the tv in the right hand corner has ypbpr:3 when you turn it on that is something that just started. You sound just like the last rep here. I am not sure about sap couldnt find it in the settings but I know the rep checked some things in the settings and reset them to factory start. TY
I have a hitachi p50h401 tv. when using the hdmi input i do not get sound out of the rca audio outputs. how can i get sound out the rca outputs
Check the manual. I doubt that the rca audio is for output. More than likely it's the audio input when using composite video.
Nov 09, 2014 | Hitachi P50H401 50 in. Plasma HDTV
Cant update my hitachi P50H401 with downloaded firmware update
If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 05, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I have a hitachi p50h401 50" it has picture but no
I would check the software and make sure it's the latest or upgrade.
Jan 23, 2011 | Hitachi P50H401 50 in. Plasma HDTV
My hitachi P50H401 will not turn on. No sound no
check your sdr boards. you can test them with a multi meter. they are known for going bad. what happens is the two caps by the output go bad on the power supply and they make the sdr boards burn out. you can replace the two caps and save lots of money. then please check out this web page http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
This web page has info about repairing these. The 4 flashing lights maybe the x sus or the y sus but it's still a good idea to check the sdr boards since its a common failer. I had one tv with a bad sdr board flash 3 time and another set it was flashing 4 times.
Nov 16, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi P50H401 display problem
it is problem your TV high voltage unite(EHT)
change it by authorised service centre
Aug 28, 2009 | Hitachi P50H401 50 in. Plasma HDTV
I have exactly the thame probleme for the thame Hitachi P50H401
the most common problem in this tv. is the
tv. inverter you have sound but not picture
check the price at www.shopjimmy.com that
part you can change your self and save money
Aug 15, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Broken plasma display panel
hi,i have same hitachi p50h401,just over a year old,mint condition never use stand but boards inside have some problems(blue light is flashing but tv not turning on).will sell it or buy yours.thx oliver.e-mail to oshvetz@yahoo.com
Aug 09, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi 55 s69 plasma
Do you have the menu on screen??
If you dont have image, maybe you need change the Y-Sus PWB and the SDR´s
Sep 15, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi tv please help
I write the same in other consult
Jul 09, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi P50H401 50
The problem occurs when the broadcaster changes the audio type in the digital stream.The firmware update will fix this issue.
Dec 15, 2007 | Televison & Video
Hitachi P50H401 50 in. Plasma HDTV Logo
220 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
