Question about RCA TruFlat 27F520T 27" TV
The tv is a 32"
    Top Expert:
  • RCA Master
  • 74,383 Answers
Hello
The horizontal output transistor of your RCA TV has shorted. Horizontal output transistor is one, that drive the Line Output Transformer [LOT] in short, which gives voltages requred to the picture tube of your tV. There are mainly two resons for this transistor shortage. If the above said LOT has shorted [a winding short in between at its inner side; and is irreparable]; and for some other reasons which cannot be predicted. First replace this transistor, which can be located very near to the LOT and will be screwed onto a metal heatsink to radiate heat away from it while working.
It will be three terminal black component. Replace it with same type and number, and switch ON your tV for a short time, say 4 seconds or so; unplug the device from AC mains wall socket, touch the replaced component with bare fingers and feel the heat. It may be slight warm, bu not too hot. If LOT has damaged, this transistor also will heat up, and a whisiling sound will be there. If so; never switch it ON again; replace the LOT and it is damaged. OK.
Posted on May 28, 2011
I have 20 blinks on my Sony after it turns itself off
Continous blinks of standby light to Sony TVs denotes a fault with its IIC bus line. Might be a short. Visit this site for more details. Blinking codes to many brand TVs are described in detail. Pull up older posts.
Mar 18, 2013 | Sony FD Trinitron WEGA KV-20FA210 20" TV
My RCA PurFlat keeps beeping and the light in front (near the power button) keeps blinking, it won't come on, can this be fixed?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_23_2012_2_17_42_pm.jpg
Apr 22, 2012 | Televison & Video
When I try to turn my RCA PURFlat 27" TV on, either with the remote or main button a blue line shows up in the screen and like within 2 seconds it goes off. What's the solution for this problem)?
My rca purflat doesn't turn on with the remote, batteries are good, it however turns on when I press the power button and then the channel button.
Sep 16, 2010 | RCA TruFlat 27F520T 27" TV
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony trinitron kv32fv15 standby light continously blinks won't po
check IC301,with a ohm meter,shorted to ground,IK video path defective......can get parts at Mats Electronics # 1-800-628-1118.hope this helps
Feb 16, 2010 | Sony Televison & Video
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Aug 20, 2009 | RCA TruFlat 27F520T 27" TV
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
RCA TruFlat  27F520T 27" TV Logo
116 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
