Question about RCA 32V550T 32" TV
TV sparks inside case
My TV sparks inside it's case. I took it apart and they seem to be coming from the power supply.
I have replaced the fuse many times on this thing - it doesn't burn out with this problem.
Do I replace the power supply? Where would you recommend to find one.
Thanks.
  • 41 Answers
There will be a problem in powersupply.and ity is best to be checked by the technician in order to see the deffective parts..
Posted on Sep 10, 2008
Re:pc88mx - the fuse in the adaptor blows. I was having problems with the keyboard power cutting out. I took the case apart to check the internals, and (to make a long story short) discovered it was t
It's very hard to exactly diagnose your problem exactly without being there. I'd say you have a power supply issue inside the keyboard. Maybe a shorted filter or diodes. If you have replaced the AC adapter, be sure that the polarity, voltage and current rating is correct.
Apr 23, 2014 | Audio Players & Recorders
I have 47" LG LCD TV (47LD450-AU) and when I try to turn it on the red LED just blinks slowly. So I took it apart to check the power supply panel (P/N: EAX61289601/12) and it seems fine, at least all the...
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 01, 2013 | LG 47LD450 47 in. TV
Euro Prox Model UV209-11 upright vacuum--
prise it apart I'm pretty sure it has clips much like a computer case.
Dec 13, 2012 | Euro-Pro UV209 Upright Vacuum
Tv started to smoke took apart and found found the
I assume it was the power supply that you replaced? It is very likely that a fusible device on another board has gone open circuit to protect any damage due to the initial problem. Again I assume you have a plasma TV in which case there will probably be a problem on the Y or Z sustain boards which may also need to be replaced as this may have been the reason for the other board to burn up
Dec 20, 2009 | Televison & Video
Proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Jun 20, 2009 | Proscan 26LB30H 26 in. LCD TV
Want to check fuse on 46h83 toshiba
only fuse I know is near back of tv inside power section right next to the power cord input ... my first thought tho is damaged capacitors inside same area ... good luck getting it apart ... I took mine apart but difficult to figure how
Jun 10, 2009 | Toshiba 46H83 46" Rear Projection...
LTV-32w6 won't turn on
were on the power supply is the fuse located
Nov 12, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
TV Sparks inside case
I think I would turn it off and unplug it. You could get an estimate on reparing the power supply cord or whatever the problem is or the TV maybe ready for replacement.
Aug 16, 2008 | RCA 32V550T 32" TV
Fuse
Are there any fans moving in the case? As in, are you getting any power? If no fans are moving, it's possible it's:
1) the power supply (PSU)
2) your 'jumper' from the power button to the motherboard has come unplugged
3) you're grounding out somewhere
One cheap-o way of testing a power supply is:
Turn your power supply off.
Unplug your power supply.
Get a paper clip.
Bend it into a U-shape with the ends close together.
Put one end of the paper clip into *the* green wire in the plug of the PSU.
Put the other end of the paper clip into a black wire of the PSU.
Plug in the PSU.
Turn on the PSU.
If the fan runs in the PSU, it's safe to say this PSU is in working order.
If the the power supply was fine, but when you hit the power button and it no fans inside the case move, check the plug from the case to ther "power on" jumper on the motherboard. if that's correct, I'd suggest removing the entire motherboard from the case and setting it onto a phonebook and see if it'll turn on there.
If fans are moving when you hit the power button, but no beeps, fans turn back off after a moment, ect:
1) Motheboard is bad
or
2) Processor is bad
These are the situations that are most likely.
Computers are picky about being played around in. You can look at them wrong and they'll stop working. Sometimes it's as simple as pulling them apart and putting back together again to make them work... at least in my experience. I wish you the best of luck.
Nov 16, 2007 | HP Pavilion a420n PC Desktop
Dead
dude i dont know if this will help you or not but the same thing happened to mine and im an electrician, so i took it apart and screwed around with it and everything seemed to be cool so i took it to a tv repair shop and they fixed it and it only cost me $65.00. he told me that the power supply motherboard burned out for good.
Nov 14, 2007 | Memorex MT2206 TV
RCA 32V550T 32" TV Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
