Question about ASUS X83Vm-X1 Notebook
How can i reset the bios on my asus x83vm-x2 ? I've tried to get to the cmos battery but was unable. Also can't find a reset button
3 Suggested Answers
byteguy
  • 2229 Answers
SOURCE: Asus V6J reset cmos button please
The computer should show you a key to hit to enter the setup. Nomally the keys may be F2, F10, DEL, or some other key.
If your computer does not even give you any display, then you can't enter setup--it's failing the POST which means it won't work at all.
In a laptop, you could take it apart far enough to find the CMOS battery and disconnect it to reset the CMOS, but I'm thinking you might have a hardware problem here--like maybe a motherboard.
One thing you can do is unplug it, remove the battery, then reinstall the battery, plug it in and try again. In a laptop, anything further will require dissembling the case.
Posted on Dec 19, 2009
  • 265 Answers
SOURCE: I've put an bios password
hI ,
tHE ONLY THING i CAN TELL YOU IS TO , 1ST - REMEMBER THE PASSCODE IS CASE SENITIVE , SO TRY IY IN LOWER AND UPER CAPS ,
2ND TRY A BOOTABLE DISK AND SEE IF IT WORKS ? OTHER THEN THAT , YOU MIGHT HAVE TO SEND IT AWAY TO THE FACTORY...........GOODLUCK .......ROY
Posted on Aug 25, 2011
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
How can i bypass bios password
Solution 1: Unable to power on the notebook.
1.1: Reset hole available on the bottom?
1.1.1: Reset hole available. --> Use a spiculate pin to tip the reset hole.
1.1.1.1: Problem solved. --> Able to power on.
1.1.1.2: Problem persists. -->1.2
1.1.2: Reset hole unavailable. --> 1.2
1.2: Try to power on just using battery.
1.2.1: Able to power on. --> 1.3
1.2.2: Unable to power on. --> Check the adapter indicator.
1.2.2.1: Adapter indicator on. --> Try to power on just using adapter.
1.2.2.1.1: Able to power on. --> 1.3
1.2.2.1.2: Unable to power on. --> Contact ASUS service center for help.
1.2.2.2: Adapter indicator off. --> Adapter problem, check the cable or contact ASUS service center for help.
1.3: Try to enter the BIOS by pressing F2 button when ASUS logo appears.
1.3.1: Able to enter the BIOS. --> 1.4
1.3.2: Unable to enter the BIOS. --> Contact ASUS service center for help.
1.4: Try to enter the Operation System.
1.4.1: Able to enter the OS. --> Reinstall the OS for a try.
1.4.1.1: Problem solved. --> Able to power on.
1.4.1.2: Problem persists. --> Contact ASUS service center for help.
1.4.2: Unable to enter the OS. --> Contact ASUS service center for help.
this one is copyed.
May 11, 2014 | ASUS Computers & Internet
How I can to reset my motherboard Foxconn p4m800p7ma
do you want to reset BIOS ? is that what you mean ? reset BIOS is done thru clear CMOS.it should be a button on the motherboard push
it down 1-2 seconds if no button remove CMOS-battery looks like a watch-batterry for 10-20 seconds.be careful with the battery it should
be some kind of hook holding in place.replace it liked you removed
it.
Apr 13, 2013 | ASUS P5PE-VM Motherboard
Every time the battery goes dead on my ASUS X83vm and plug in and turn it on, the clock/date reset and the recently replaced network adapter which was the same one maybe different version (Intel Pro 5100 I...
Most people do not realize that a laptop has 2 batteries... the normal 4-6-9 cell battery that we constantly recharge and a smaller (internal) battery to maintain CMOS memory where the clock and other data are stored.
The CMOS battery is normally inexpensive, typically you can find them in a good electronics store or even on ebay. They are easy to change as they typically have a quick disconnect plug. I am not sure where it is located on the ASUS, but look in the memory compartment or the hard drive compartment.
Aug 29, 2011 | ASUS X83Vm-X1 Notebook
How to remove restricted access
Reset the CMOS (BIOS memory).
You do that and it will remove and BIOS passwords.
It will tell how to "clear CMOS" in the motherboard manual.
Or you can try unplugging the computer, and removing the little CMOS button cell battery for a few minutes.
Note if you do clear it, you'll probably have to set a few BIOS settings from the defaults.
Jul 01, 2010 | ASUS M2N-MX Motherboard
System fail due to cpu overclocking, voice message on reboot, after turning the adaptive overclocking feature on in the bios. I cannot clear cmos and get back into bios to turn it off again. I have tried...
Disconnect the power cable, press and hold the power button. Open the case, remove the cmos battery and short the cmos battery connectors (just touch both the metal tabs center and edge at the same time) with a screwdriver. Replace cmos battery, reconnect the power and power on. This should reset the BIOS to default settings.
Apr 01, 2009 | ASUS A8V Deluxe Motherboard
How to reset Asus PC-DL Deluxe BIOS
Remove the Lithium Flat Battery from the motherboard, then start the machine. Let it run for about 5-10 seconds and then turn it off and put the battery back in.
Some motherboards when you try to power it up without the battery, will not turn on. Press the power button 2-3 times and then place the battery back in and it should achieve the same results.
Dec 11, 2008 | ASUS PC-DL Deluxe Motherboard
Bios failure
you may have a flat cmos battery, but first try reseting the bios by the cmos reset terminals, refer to the manual
Sep 14, 2007 | ASUS A8V-VM Motherboard
ASUS X83Vm-X1 Notebook Logo
260 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
