Question about Sram SX4 7-Speed Trigger Rear Mountain Bike Shifter - 00.7015.044.030
How do you put new cable on inner and outter?i have sramsx4 shifters ty
    Brigadier General:
  • 8,546 Answers
How to replace an inner tie rod end on a 2001 s600 mercedes benz
I will enclose some pictures to also help you, First remove the wheel on the side of the bad inner tierod,make sure a jack stand is used under the frame for safety. With the wheel off you will next loosen the nut at the rear of the outter tie rod, just a few turns is good, theres a nut that holds the outter rod to the spindle you will need to remove the cotter pin first is it has a locking nut then there will be no cotter pin, remove the nut and seperate the tierod from spindle, this is done with a fork or hitting the side of spindle with a hammer, with that off you will untwist the outter rod, count the turn so it will be close until you have an alignment. with end off next remove the nut that you loosened that locked the outter rod. Remove the clip clamp on the boot and also remove the inner clamp and slide boot off, turn wheel so the inner rod on the side you are working on comes out all the way, next is to remove the inner rod by unscrewing it, if you look you will see a washer that bends over the end to lock it, use a chisel or screw driver to bend ends out of the way then use a wrench to remove the inner tie rod, the new one is ready to install, use locktight on the thread off the new inner tie rod to lock it and also bend washer ends back over to also help lock it, then reverse directions to finish the job. then you will need an ailgnment, hope this is helpful.johnjohn2_66.jpgjohnjohn2_67.jpgjohnjohn2_68.jpg
Feb 22, 2011 | 2001 Mercedes-Benz S-Class
Dodge ram wheelbearing number
front inner, cone pt# 52007659
front inner, cup pt# 4746921
front outter, cone pt# 52007899
front outter, cup pt# 4746922
those are straight off mitchell ondemand
front seal is # 52007658
Nov 30, 2010 | 1997 Dodge Ram 1500 Club Cab
Huskt tc250 broken inner an outter case round kick start
Obviously, new casings would be the best option, but another option you have is to take the parts to a commercial welding shop and have them Heiliarc weld the casings. Alternate to that, you could try Googling motorcycle salvage Husqvarna to see if you can get some used parts. The bad thing about a busted inner casing is that you should change out the inner casings as a matched set. Sometimes the casings don't line up perfectly if only replacing one side and the result is shafts that freeze up when you tighten down the screws. Please rate my answer. Thanks.
Feb 11, 2010 | 2004 Husqvarna TE 250
How does the speedometer work in a 1989 c1500? is there a cable ? the guy I got the trk from said the trany he put in didn't have the same hook up as the old one because it was out of a newer trk
The 89 truck uses a cable it is not a magnetic pick up so there is an inner and ottter cable and you can buy from any parts store. inner cable runs 10 dollars a fitted inner and outter cable is about 425.00 and is the way I would go.
Oct 05, 2009 | 1989 Chevrolet C1500
Replacing rear axle dust cover boot on 2005 yamaha grizzly
Inner or outter?? The outter cv joint doesn't come apart. If you rip the outter boot, you need to get a new half shaft. The inner cv joint has a clip inside that you have to take out to split the joint and install a new boot. You also need boot clamp pliers to tighten the clamps or it will come back off first time you ride it.
Jun 19, 2009 | Yamaha XT 660 X Motorcycles
Packing front wheel bearings
what I do is put a glob of grease in the palm of my hand and push bearing down in to grease untill you see the grease come out of the bearing or you can go to your local parts store and get a bearing grease packer. also wipe spindal with a genorus glob and put grease in between bearing in rotor. To get to the bearings all you need to do is remove tire, center cap (outter grease seal) the silver cap in the center. the cotter pin, Nut, washer outter bearing then the rotor will slip off inner bearing is in rotor still being held in by inner grease seal take seal off replace with new one pack your bearings and reverse removal procedure when retightening nut do not make tight just snug the go another turn if you go to tight you will burn your bearings real fast.
Apr 07, 2009 | 2002 Ford F250 Super Duty SuperCab
How to clean inside of screen?
Your tv has two screens on it. The outter screen and the inner screen. The outter screen has a frame around it held on by clips. You can remove this outter screen by gently prying it from the tv. There is a small gape between the outter screen and the tv casing. When prying the outter screen be carefull not to dsanage the tv case or the outter screen frame. Take note of the location of each clips because you will need thses to put the outter screen back on. Clean with a good gentle screen cleaner, (Do Not Use Windex). Philips screen cleaning gel for plasma & LCD works very good. Install the outter screen back on the tv by making sure the clips line up and use light pressure to snap it back in place. Do Not Hit Outter Screen To Force Clips Into Place.. I do this on my tv about once every 6 months or so.
Jan 04, 2009 | RCA P61960 61" Rear Projection Television
Clutch cable replacement
bit tricky with pedal up u need to pull inner cable towards u and hold still the outter cable make sure you got plenty of light
May 23, 2008 | 1987 Honda Prelude
Sram SX4 7-Speed Trigger Rear Mountain Bike Shifter - 00.7015.044.030 Logo
206 people viewed this question
Top Sram Cycling Experts
Michial Gueffroy
Mike
dante
Are you a Sram Cycling Expert? Answer questions, earn points and help others
