Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
How do you take the front plastic see through cover off??? I have to get the wet dog hair out of it.
How to remove the clear plastic front. It is clogged with wads of dog hair
HAVE NO IDEA since you did not state MAKE,MODEL.try google for a manual thru the manufacturer Google
May 21, 2016 | Vacuums
Miele S7210 red light on
You may have more dog hair in the main hose. Pull the hose out of the body, turn the lower hose swivel 90 degrees parallel to the floor and twist the hose off. You will see where to remove it at the swivel. Also check the port door on the back of the vacuum near the bottom of the upper section. It can be looks like a parallelogram with 2 plastic screws, twist the screws half a rotation and gently pry the cover off. After clearing out any debris, replace the cover and fasten the screws. A small LED flashlight will be very handy for checking all of the ports and hoses.
Feb 07, 2013 | Miele S7210 Bagged Upright Vacuum
There is dog hair stuck in the hose-how do I get
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
nb,.n
May 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
How to clean clear plastic thing in front of Bissell ProHeat?
you may have to run it to soften the hair, then you should be able to go under it with a rag to clean it.
Apr 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
The hoover shampooer will not extract the water from carpet, is it because the carpet is so low ?? the carpet is cleaning fine there is VERY poor underlay and then wood under that, worried about the wood...
do you have suction at the front of the base,if you don't then look at the plastic cover on the base,you should be able to see through the plastic.the suction slot on the bottom front of the base is very narrow.i don't know if you have pets but most of the time the suction chanel gets clogged with hair and dirt.the chanel is right up the middle on top of the base.look in there and see if you don't see a lot of hair and dirt stuck up inside.there are some screws on the bottom that you need to take out to remover the cover.then the cover comes apart in two pieces to allow you to get to the suction chanel.please leave some feedback.i hope i was some help to you
Apr 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dyson dc17 animal motor spindle keeps clogging
If you have animals get rid of the dyson and go to a vacuum that has a metal brushroll and better airflow. There is no fix on the dyson they just are not good on hair of any kind.
Jan 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell Pro Heat 8910 clogged?
Why the motor sounds muffled I am not sure. When the water is sucked up, it goes directly into the tank. The motor only creates the suction so it can do that. There should be a filter on the rim of the recovery tank lid, is it clean? Other then pulling the top cover off, and then the motor cover so you can inspect the motor, I really don't have a good answer for you. I t may be that that clump of hair when down the chute and into the fan, I have seen that happen with vacuum motors before.
Nov 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Ultra model
There are six black screws holding this cover. That's all you need. Good luck.
Mar 30, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
My Rainbow E series power switch doesn't work
To get access you need to remove the plastic side cover panels. To remove these, I found the easiest way was to use a small flat screw driver, leverage it under the pastic in the centre at the 'cord end' and lift carefully. There are two lugs at the top and one at the bottom. The plastic panel will 'bow' a little, but with care, it will pop off. The gold looking vents underneath are just a 'facade'. By removing the side plastic panels they will expose three screws either side. Undo these and the top will half of the cleaner will lift off. Good luck!
Jun 25, 2006 | Rainbow E series Canister Wet/Dry Vacuum
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
97 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
