Question about Durabrand CD-203 Boombox
Battery Operation I put fresh batteries in (and they are in the correct position), but it will not turn on unless it is plugged into an outlet. Is there a switch to have it play on AC or DC?
  • 1 more comment
  • margcurtis Sep 13, 2008
    I havae a Durabrand Model CD203 Boom Box Radio and have new batteries installed correctly and it does not work. Isn't this radio a battery operated one? If so, why can't I get it to work
  • margcurtis Sep 14, 2008
    can't get it to work on the battery "side" at all
  • margcurtis Sep 18, 2008
    are all durabrand C-203 boomboxes battery powered? If so, how do you activate the battery operation? I have installed new batteries and can't get it to work
Try removing the AC cord from the back of the boom box, it activates a switch that lock out the batteries. On mine it sets in there pretty snug and required a little tugging.
Posted on Nov 23, 2008
I have the same problem, There is no switch to change. Can someone tell me how to make this play on battery only
Posted on Sep 18, 2008
1999 Ford F150 Electrical Problem
at this point , removing a battery will activate the immobilizer system
try using a scan tool to reset the ECM to see it that puts the program back correctly
if it does then all the other problems should be fixed as well
Jul 04, 2016 | Ford Cars & Trucks
WHY MY BLACK AND DECKER SS925 WILL NOT CHARGE
The charger or battery is bad though it shows charging it may be putting out the correct wattage
Sep 06, 2014 | Electrical Supplies
How can i shut off my kidde carbon monoxide detector, it is a constant alarm unless you remove the battery completely
Try another hard whack. If that does not undo the initial damage, nada will and you have a nice paper weight.
Sep 01, 2017 | Kidde Nighthawk Combo Gas/co Detector
Motorcycle not starting
Hi Timothy, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections especially the negative cable at "BOTH" ends
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below. Good luck and have nice day.Harley Davidson Wiring Diagrams and Schematics Harley Davidson Sportster error codes and how to access them
Jun 12, 2012 | 2009 Harley Davidson XL 1200L Sportster...
How to use the TM 111D
1) To use the timer:
Make sure outlet has power.
Check outlet with circuit analyzer to make sure polarity issues do not affect timer operation.
Plug timer into outlet for 1 hour until battery is charged.
Some timers have internal battery that do not need to be charged.
After battery is charged, unplug timer to set programs.
Set program(s).
Turn lamp ON and make sure bulb is good.
Leave lamp turned ON
Plug lamp into timer.
Then plug timer into outlet.
2) To program the timer, open following links for possible instruction manuals:
http://waterheatertimer.org/pdf/How-to-program-Timex-TE111.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Timex EASY TO SET TIMER BY TIMEX
1997 buick park ave ultra After I replace the battery, do I need to do anything to reset the electronics?
Usually when you replace the battery, you lose the memory settings on your radio, power seat memory and any other accessory memory settings. The engine might also have to go through an idle relearn process. The engine might run erratically until this process is completed. One way to avoid this problem is to install a memory saver, available at most parts stores and are relatively inexpensive. They come in two types. One uses an electrical outlet and the other one uses a square 9 volt battery. It plugs into the cigarette lighter or 12 volt adapter. Install the memory saver and leave it plugged in until you are done installing the battery. If you use one of these, then you do not need to reset anything. If you don't then you might need to reset your accessory memory functions and have unstable engine operation until the idle relearn is completed. Although the computer will correct the problem on its own by driving it, you can speed up this process by performing a manual idle relearn procedure.
1. Start the engine and allow it to run in park position with all the accessories off for one minute.
2. Put the transmission in drive with all accessories off and let it idle for one minute.
3. Put the transmission back into park and turn all of your accessories on for one minute.
4. Put transmission into drive with all accessories on for one minute.
I hope this information is helpful to you and thank you for using Fixya.com.
Jun 05, 2011 | 1997 Buick Park Avenue
I have a Casiotone MT70 made in 1984. How do I check the polarity as I need to get an AC Adaptor and don't want to damage the keyboard?
Here is how you might check the polarity of a 7.5 volt DC replacement adapter:
Put the 5 batteries into the unit and verify operation. NOW using a DC voltmeter measure the voltage from battery negative and meter negative connected and meter positive to the pin on the power jack. IF you see 7.5 volts positive, then the pin is the positive lead for the adapter.
If you see zero, then continue testing.
With the 5 batteries inserted, connect the positive meter lead to the positive of the stack of batteries. Now touch the negative meter lead to the pin.
If there is 7.5 volts there, then the pin is the negative lead for the adapter.
READ THESE INSTRUCTIONS CAREFULLY.
USUALLY the jack has a contact that disconnects the batteery when the plug with sleeve is inserted.. We are testing the jack without inserting a plug here so the plug should HAVE THE BATTERY VOLTAGE with correct polarity on the pin.
Oct 07, 2009 | Casio Music
Xerox 6115 mfp has please wait on screen and has
General Troubleshooting
Product Will Not Turn On
Cannot Print the Configuration Page
Probable Causes Solutions
The power cord is not correctly plugged into the
outlet.
Turn off the product, confirm that the power
cord is correctly plugged into the outlet, and
then turn on the product.
Something is wrong with the outlet connected to the
product.
Plug another electrical appliance into the
outlet and see whether it operates properly.
The power switch is not correctly turned on (I
position).
Turn the power switch off (O position), then
turn it back to the on (I position).
The product is connected to an outlet with a voltage
or frequency that does not match the product
specifications.
Use a power source with the specifications
listed in Electrical Safety on page 1-2.
The tray is empty. Check that at least Tray 1 is loaded with
media, in place, and secure.
The product’s covers aren’t closed securely. Make sure the covers are closed securely.
Close all covers gently to avoid jarring the
product.
There is a paper jam. Clear the paper jam.
Driver Problems
With Pages/Sheet on Multiple Copies, the Output Is Incorrect
Booklet Left and Right Binding Output Is Incorrect
Did you set the correct date and time? Ensure you have set the correct Date and
Time on the control panel, through
CentreWare IS or the MCC.
The backup battery has reached the end of its
service life.
Replace the backup battery.
Media or settings are not correct. Make sure the duplex unit is installed and
enabled in the product driver.
Make sure that you are using correct media.
See Supported Paper and Media on page 6-2.
Do not duplex custom-sized media, envelopes,
labels, postcards, thick stock, or
transparencies.
Make sure that you have not mixed media
types in Tray 1.
In the product driver choose "Print on Both
Sides".
Both the driver and the application have been set to
Collate.
For Pages/Sheet on multiple copies, choose
Collate only in the driver’s Basic tab. Do not
set collation in the application.
Collate.
For Booklet Left Binding and Booklet Right
Binding, choose Collate only in the product
driver’s Basic tab.
Do not set collation in the application.
Status Messages
Message Definition Solutions
CANCELLING JOB The job is being cancelled. No action needed.
*ENERGY SAVE* The machine is in Energy Saver
mode to reduce power
consumption during periods of
inactivity.
*PLEASE WAIT!* After replacing a toner cartridge,
or after rebooting your machine
after environmental changes,
your machine automatically
pauses to do an Auto-Image
Density Control (AIDC) cycle.
This process is provided to make
reliable machine operation with
optimum output quality possible.
The machine is warming up.
Aug 19, 2009 | Xerox Office Equipment & Supplies
My camera does'nt on anymore
I've been experiencing the same problem and fixed it today. The Kodak Easyshare C613 has a defective battery door design and should be recalled. The problem is that the small copper connector in the hinged door doesn't make good contact between batteries.
  • First, check that both AA batteries are fresh. Then verify that the batteries are inserted correctly. Unfortunately, this camera has contradictory polarity (+ -) labeling. The hinged door has a positive (+) marking stamped in the metal on the side toward the lens while the plastic housing has a negative (-) marking on the side toward the lens. The metal marking is correct, ignore the markings on the plastic housing. The nub (+) side of the battery should be facing out of the battery compartment on the side toward the lens. The flat (-) side of the battery should be facing out of the battery compartment on the side toward the strap.
  • If fresh batteries are inserted correctly and you still have a problem, then use a small piece of paper to wedge the batteries in place. I folded a 1 inch square down to 1/4x 1/2 inch and placed it between the two batteries. Now my camera will turn on every time.
Hope this helps.
May 23, 2009 | Kodak EasyShare C613 Digital Camera
Psp will not turn on unless the cord is plugged in
ok your son's psp has malfunctioned and instead of trying to charge the batteries it drained them. i would recomend for u to get ur son a new psp and buy a another battery for your daughter.
there is a newer battery being sold that you put AA batteries inside
to make it work. check out your local best buy and wal*mart
Dec 23, 2008 | Sony PlayStation Portable (PSP) Slim...
Durabrand CD-203 Boombox Logo
156 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
