Question about Homelite Garden
I have a almost new homelite edger that will only run for a few feet when under load before it quits. It will start up when I use the cold start but will only last for about 3 feet of edging.
  • Homelite Master
  • 7,482 Answers
Hi mvollenw...
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 31, 2011
2 cycle 30 cc homelite will start but not stay running
I had one of these a few years ago which started doing the same thing. I get fed up with it, and was going to throw it away. I gave it to a friend who found the fuel system was partially blocked. After running some carby cleaner through it, it worked fine. Its still going now...
Aug 18, 2014 | Homelite Consumer Products Tiller...
Homelite htc 12 tiller.. motor runs ok but tines wont turn under load free wheeling they turn but under load no clutch?
Hi bh1149...
You have bad gears on the inside of the tiller gear box...
I had this same problem with mine.
You will have to take the gearbox apart in order to know what parts are bad.
Be sure to check the lube more often when you install the new gears/parts.
Go to the following website and order your parts.
http://www.ereplacementparts.com/homelite-parts-c-18807.html
Sep 08, 2011 | Homelite Consumer Products Tiller...
I have Homelite trimmer/edger for 3 years. It has been working great until recently, after a cold start and edging for 7 - 8 minutes it stops all of sudden until it gets cold and runs for 6 -7...
You need to check the ignition coil, by running until it quits and then remove the spark plug, reattach the plug wire and then ground the plug threads to the block and then try to start it. If you get no spark or very weak spark, the coil is bad and needs to be replaced.
I hope this helps get you going again.
Aug 17, 2011 | Homelite Mighty Lite Lawn Trimmer
I have an old homelite brush king that all of a sudden won't spin the blade under a load. When there's no load it runs fine. ?? Any suggestions where to begin.
Sounds like a clutch problem. IF it is, you need to disassemble the tube shaft from the power head to get to it.Normal operation is just the opposite of what your machine is doing.
Sep 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Trimmer won't start
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 13, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite won't start
You may consider installing a new spark plug. 2-cycle engines foul plugs pretty regular. I'm guessing you are using old gasoline??
Aug 17, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
MightyLite is a Real POS. Brand new and only runs on half choke
Agreed all these cheap trimmers are built at a price the only way to tune them is to take it to the dealer, The special tool costs nearly as much as the machine.
So most machines under 100 dollars are throw away and replace its bs but everything is ending up the same.
Jun 28, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite xs 135 runs 10-15 min then stops. have to reprime and it runs 10-15 min.
Either the gas mixture is not quite right or the gas cap is slightly clogged.
If you don't have enough oil in the gas, this may cause it to overheat.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Homelite Garden
Cold morn - not starting. Car was moved a few feet night before.
OK, so starting the engine uses a lot of battery power, and the engine needs to be left running a while to recharge the battery.
When it is cold batterys don't hold as much charge (not quite the correct technical term, but I don't want to go into battery mechanics and chemistry here). You either need to pop it on a trickle charger or let it run for at least 15 minutes.
Dec 28, 2008 | 1998 Suzuki Swift
Garden Logo
32 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
