Question about Estate TEDS740JQ Electric Dryer
Dryer does not heat. Everything else seems to be working OK. Thanks.
  • Estate Master
  • 7,482 Answers
Hi cvw1452...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 28, 2011
Maytag Dryer model DE212 no heat everything else works? Checked sensors and switch block on drive motor all seem to be ok how to test timer switch?
the heater element may of burnt through, or they may be a red reset switch on the rear of the dryer.
Nov 17, 2011 | Dryers
Our dryer is a little over a year old. Everything seems like its running ok except for the fact that there is absolutely no heat. Any ideas?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | LG DLE2512W Electric Dryer
Dryer will not heat
Have a certified electrician check your outlet. The dryer requires 220VAC for the heating elements to work. If this is ok, check the heating elements it may be broken.If this is ok, check the high and low limit switches, this could be defective.
Apr 04, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
There is no heat
Disconnect power and access your dryer fuses. Check and test your fuses for "continuity". Most likely, a white thermal fuse. Can possibly be your ignitor or heat element as well. Is your dryer gas or electric?
Jan 27, 2009 | Hoover Dryers
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
Frigidaire Gas Dryer not heating up. Other elements are all ok.
It sounds like your igniter is no good. At all costs, check the Fuse before anything else. It is usually accessed from the back of the unit.
Nov 25, 2008 | Frigidaire FGQ332ES Gas Dryer
Kenmore dryer will not heat
check the exhaust pipe, if it is clogged, it will trip a sensor to tell the dryer to not call for any more heat. make sure to check every inch of it and look for lint buildup
Oct 27, 2008 | Kenmore 63942 Dryer
Dryer problem
HI thanks for your question. the problem is with the 2 coils on the gas valve. replace the coils. thanks
Oct 12, 2008 | Whirlpool Dryers
My dryer doesnt heat.
hi there,
check the ignitor and the coils on the burner assy.
Sep 30, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Estate TEDS740JQ Electric Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
