Question about Hunter 52" Ceiling Fan With Light And Remote Control
Ceiling fan with light and remote: Globe came loose and fell down. Broke one of the chains and can't find where it goes. Can you help? It is a hunter fixture
The chain should go into a small hole on the housing that wraps around part of the motor. In order to connect the chain you will have to lower that portion of the housing cover some how. It should have a small portion of chain that you can still connect to. If it broke off inside the motor, you may not be able to fix that and may have to ask an electrician to the job, An electrician will be able to tell if you need a new fan motor or if it can be fixed. If you can take photos of it ( up close ones). You can email them to me and I may be able to assist you better.
Marc the Handyman
Marc Arel Services
mackeral74@hotmail.com
Posted on May 28, 2011
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
No clips to hold globe on ceiling fan
You best resolution now may be to replace the light kit with one available at Home Depot ..
Jun 07, 2009 | Hampton Bay 52 In. White Redington...
Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
The chain for fan speed control comes through the glass light globe at such an angle that the fan can not be changed to different speeds is there a fix for this problem
Never heard of that, usually the chains come out of the housing above the light and hang straight down.
Is the chain tangled somehow?
Apr 25, 2009 | Hunter Ceiling Fan Light Switch Control
I'm tring to find a light globe for may antigua ceiling fan mine broke when tring to take down form ceiling. where can i find one?
I am thinking of buying this fan, but do not want to use the light. Are you still looking for a light globe?
Feb 28, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Oct 30, 2008 | Dryers
Broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Apr 04, 2008 | Dryers
How to replace or repair center fan speed pull chain
the chain goes into the switch and operates a round contact plate. just get a new three speed switch.
Jan 31, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Dryers Logo
80 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
