Question about Panasonic Viera TH-42PZ80U Plasma TV
Thin blue vertical line left of middle on screen
  • 159 Answers
Sounds like a faulty Plasma Display Panel.
Contact Panasonic and find out if it is still covered under warranty.
Please remember to rate my solution to show your appreciation.
Amardeep
For more tips visit my blog at http://thegeektweet.wordpress.com
Posted on May 28, 2011
5 Suggested Answers
  • 31 Answers
SOURCE: 50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Posted on Mar 10, 2008
  • 4234 Answers
SOURCE: 42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Posted on Aug 29, 2008
SOURCE: samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Posted on Dec 23, 2008
  • 1536 Answers
SOURCE: thin blue line down middle of screen
The red line driver at that point isn't working or there is a bad connection to the panel for that line. (I assume the intensity and hue of the cyan line varies witht the picture). What type of screen is it? Plasma or LCD? The following is for LCDs and may not apply to plasma panels. (I haven't had to fix those yet.)
Once in a while you can solve the problem on an LCD by gently massaging the connector to the display panel edge at the bad spot, although there is a risk of causing other lines to drop out. I once fixed an LCD that had a hair caught between the elastomeric connector and the display glass, but if that were the culprit in your case, you'd probably be missing more than one line. It could also be a problem with the driver chip for that line.
Be very careful about tearing into the LCD. The connections are very delicate, the fluorescent backlight tubes are glass and have mercury inside, and the potential for electrostatic discharge damage is always a concern. It's easy to cause more problems than you fix when you get into the connections, although those can usually be reversed with patience and steady hands. The worst case is a misalignment that would mess up your color registration (color drive going to the wrong line). Most panels have a sticker inside warning against removing the driver electronics. It's there for a good reason.
If I've scared you off, or if the connector massage doesn't work, there are companies like Moniserv that specialize in repairing LCDs. They have the equipment and dust-free facilities needed to repair bad panel drivers.
Posted on Mar 23, 2009
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Vertical line
Sounds like a T'Con fault. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Screen-shots to defective LCDs aregiven. You can compare it to that of your TVs' and can make sure about the fault.
Dec 04, 2013 | LG 32LG30 32 in. LCD HDTV
I HAVE GOOD AUDIO BUT A THIN LINE IN THE MIDDLE OF THE SCREEN THAT HAS VIDEO. ALSO THE SCREEN IS BLACK ON THE TOP AND BOTTOM WITH THE THIN LINE OF VIDEO IN THE MIDDLE.
Have you vertical deflection circuit checked for bad Vertical IC, and or Bad vertical Capacitors in the vert output section for the deflection board. Also have Vertical output Pump up Capacitor replaced, also have B+ voltage check coming from flyback transformer, for any open fusible resistors
Oct 12, 2009 | JVC AV-20120 TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blue thin vertical line on my monitor.
LCD needs to be replaced.
Common problem called "Tab separation".
Mar 22, 2009 | HP Compaq Presario R4000 Notebook
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Sep 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Thin blue line
What have they told you to do? This will help us in troubleshooting. Is this still under warranty?
Aug 20, 2007 | HP f2105 21" LCD Monitor
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Panasonic Viera TH-42PZ80U Plasma TV Logo
825 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
