Question about LG Cell Phones
Id like to unlock my lgks360 for free but im finding it hard. could you give me a code to do this please?
  • 3 Answers
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
Posted on Jul 12, 2011
  • 151 Answers
Please see below the list of LG unit and instruction on how to unlock code:
Model : LG U300
1 - Switch ON the phone with Accepted SIM Card (from Original Network Provider)
2 - Enter Code : 815118#*#
3 - then phone will ask to enter NCK
Model : LG C2000:
1) Insert non-Cingular SIM card
2) Power on the handset - phone will display "phone restricted"
3) Select "Cancel" - phone will display "phone restriction code"
4) Enter the SIM Unlock code
5) Select "OK" - the handset is now successfully unlocked
Model : LG KU990 Viewty & KE990
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
or
1. Without sim phone power "ON"
2. Hold "camera" + "lock" button
3. You will get key pad write 2945#*990#.
4. Press active code.
5. Your cellphone will be restart
6. Turn off cellphone and insert your sim (internation sim)
7. Enjoy your unlocked phone !
Model : LG TU720 - LG CU720 (Shine)
1) Power ON your phone with not allowed sim card (one that didn't come with the phone)
2) Type *#865625#
3) the phone will ask you to input the unlock code twice, just input the unlock code
4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone;
2) The phone display: Invalid Smart Chip
3) Power on handset
4) Select "Cancel" - phone displays "phone restriction code"
5) Enter the unlock code (8 digit code*)
6) Select "OK'" - the handset is successfully unlocked
Model : LG GR500 (Xenon)
1) Insert not-allowed SIM card
2) Power on the handset- phone will display "phone restricted"
4) Enter the SIM unlock code
or
2. Enter 2945#*9701#
3. A menu will pop up, select sim unlock
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
or
After turning on your mobile phone, press: *#865625#
Press Yes to continue.
Enter the 16 digit Subsidy Unlock Code
Enter the 16 digit Subsidy Unlock Code, again.
Device should say: "Network Lock Deactivated"
Phone may automatically reboot
Model : LG CU320
1) Power on the handset
2) In Idle screen, input the special code "277634#*#".
3) Enter the SIM Unlock code
4) Access the submenu "SIM Test" in Phone Test Mode.
5) Input the special code "2945#*#".
6) Access the submenu "SIM Unlock" which is just activated after the special code.
7) Input the 8-digit Unlock code in the "Enter unlock code" input screen.
8) It will be unlocked.
Model : LG CU400 & CU405
1) Insert non-Cingular SIM card"
2) Power on the handset - Phone will display "Invalid SmartChip".
3) Enter 159753#*#
4) Enter the 8 digit SIM Unlock code
5) Select "OK".
6) The handset will be unlocked.
Model : LG CU500
1) Insert non-Cingular SIM card.
2) Power on the handset. Phone will display "Invalid SmartChip"
3) (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4) In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5) Enter the 8 digit SIM unlock code
6) Select "OK"
7) The handset is now successfully unlocked.
Model : LG CU515, CU575 (Trax)
1) Put a non-Cingular sim in the phone
2) Phone says invalid smart chip
3) Now enter *#865625# then select option 1 and then again select 1
4) Enter your 16 digits code
5) Device should say: Network Lock Deactivated
6) The handset is unlocked.
Model : LG U8150
1 - Switch ON your phone with a NOT Allowed SIM Card,
2 - Compose : 2, 7, 7, 6, 3, 4, #, *, #,
3 - Go to menu "SIM Lock",
4 - Enter the Unlock Code we send to you.
Model : LG U400
1. Insert the network SIM in the handset which has given u the LG U400.
2. Enter 2945#*88110#.
3. The phone will then prompt 'Unlock sim'. Press OK.
4. The phone will then prompt 'Network Unlock'. Press OK.
5. The phone will then prompt- 'Input Network Control Key'.
Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code.
6. It should give you the message Success.
7. Come back to the main screen and Enter 2945#*88110#.
8. The phone will then prompt unlock sim. Press OK.
9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code.
10. Then press OK
Model : All other model
1 - Switch ON your phone with an Allowed SIM Card,
2 - Then compose :
2945#*5101# - (if you have a LG 510w)
1945#*5101# - (if you have a LG 1200 & B1200)
2945#*5221# - (if you have a LG 5200 & 52200)
2945#*5301# - (if you have a LG 5300)
2945#*5401# - (if you have a LG 5400)
2945#*70001# - (if you have a LG 7020)
2945#*7101# - (if you have a LG 7100)
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
2945#*70001# - (if you have a LG7250T)
2945#*2201# - (if you have a LG C2200)
2945#*5301# - (if you have a LG T5100)
2945#*3311# - (if you have a LG C3310)
3 - Go to "Menu" and then to "Settings",
4 - Then select "Security",
5 - To finish select "Network Provider" and select "Desactivate"
6 - Enter the Unlock Code we send to you.
Model : To Classify
For the next models u must to insert the original SIM:
LG C3100 press 2945#*3101#
LG C3380 press 2945#*7101#
LG F2300 press 2945#*7101#
LG KE260 press 2945#*2601#
LG KE970 press 2945#*9701#
LG KG120 press 2945#*1201#
LG KG220 press 2945#*1201#
LG KG240 press 2945#*3311#
LG KG280 press 2945#*7101#
LG KG290 press 2945#*7101#
LG KG800 press 2945#*7101#
LG KU250 press 2945#*250#
LG KU380 press 2945#*380#
After that will appear an secret menu,go to settings-security- sim lock ,enter NCK and press OK.
For next models insert one SIM ,not the original SIM:
LG KU311 press 815118#*#
LG KU800 press 82652#*#
LG L600v press 815118#*#
LG U8150 press 277634#*#
LG U8210 press 277634#*#
LG U8500 press 277634#*#
LG U400 press 2945#*88110#
LG KC550 press 2945#*71001#
LG KU580 press 2945#*580#
LG KT520 press 2945#*520#
LG KF750 press 2945#*750#
LG KF600 press 2945#*71001#
LG KG275 press 2945#*20001#
LG KS500 press 2945#*500#
LG KP270 press 2945#*270#
LG KF240 press 2945#*240# or 2945#*2401#
Enter NCK and press OK.
Posted on May 28, 2011
  • jeopardyclai Jun 23, 2011
    thanks for this site it helps a lot for all i need...i got the information that i don't know
Do u have codes of lg volt ls740
Posted on Sep 09, 2014
    Genius:
  • 1,487 Answers
You will not get free lg ks360 unlock code unless you describe your network carrier and your imei number at your question. Because to generate lg unlock code you must know both information otherwise you can reflash your phone.
Posted on Sep 28, 2011
    Novelist:
    Scholar:
  • 62 Answers
The best way to unlock LG is to buy unlock codes from a trusted vendor.
Search the internet for mobile phone unlocking websites. You will come across a thousand websites which can do this. Choose which ever you like. Do look for price comparisons and the unlocking instructions.
Recheck the Model number- Network to which your phone is locked to and the IMEI number before placing an order. If you made any mistakes in these details these people will never give you a refund!!
One more thing, before placing an order ask them about the conditions for getting a full refund in the case of a code failure! Think and make a wise decision. I have personally bought the unlock code for my LG Shine from unlockgenie.com. It is because they have good reviews on most of the mobile phone forums. I got my phone unlocked successfully from that website. Try the linkhttp://unlockgenie.com/
Posted on Aug 30, 2011
How to unlock samsung galaxy y pattern?
Im not able to unlock my pattern, its asking gmail ID and password, i entired so many times but its not accepting, it is showing invalid id or password.... please tel me how do i unlock too many pattern attempt PLS HELP
Nov 13, 2012 | Cell Phones
Unlock code for lg ks360 free
This LG is PDA phone,so you cannot Unlock it as free of cost,You can get the paid Unlock code at here Simpleunlocking.com and follow the instructions below and Unlock it step by step,then You can use any GSM network,Specify the Network,country it locked and get the code...
LG KS360 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your LG KS360 mobile phones. If you enter over a certain amount of wrong unlock codes on your LG KS360 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your LG KS360 with its ORIGINAL SIM Card,
2 - Enter 2945#*71001#,
3 - Sim unlock mode pop up,
4 - Enter the unlock code and press ok,
5 - The LG KS360 will then reboot and the unlock is complete.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the LG KS360.
Aug 10, 2011 | Computers & Internet
Security codes of lgks360
To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use the SIM card witha different phone provider, Please click on this link and follow myinstructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB sites - http://www.superunlockcodes.com/unlock-your-phone/rs12wp2/ http://www.unlock-free.com http://www.unlock-zone.com/ http://www.unlocking.com/
Apr 17, 2011 | LG Cell Phones
I bought a lgks360 and to format the memory card its needs a security code to unlock
It is very easy tounlock LG cellphone. You can unlockyour LG Cellphone by follow simple instruction.Contact your carrierprovider for free unlock code.otherwiseno one give you free.you can get MEP code for your LG at cheapest rate by MEP unlockcode provider .after unlocking you will be able to use any GSM Sim.
Dec 10, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
Unlock code for sony erricson c902
the truth is that you can unlock the phone for free,but you can unlock all phone for free. The payment sites are very very cheap you could try it out and see.
There is a free site you can try out first but it is for soft
unlock not hard unlock.You can use this link for the soft unlock,
then trying out that with this site (www.unlocktotalk.com/UnlockCodeInstructions.htm),
you will now try out the hard unlock with the site below:
Note:
hard unlock is not free,You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider
and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can
get a free unlock code.
Visit the link below if you are interested in buying the unlock code:
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
Jun 15, 2010 | Sony Ericsson Cyber-shot C902 Cellular...
Lgks360 free sim unlocking codes
Hello.
You can unlock your phone by simplyenter unlock code through keypad.
You can get unlock code at cheapest rate byBlackberry unlock code provider.
I hope this
unlock code provider helps you a lotto solve your problem.
Thanks
Feb 27, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
I have a lgks360 could someone out there please help me
To unlock completely follow the instructions at www.pb4kn.co.uk/ks360_unlocking.htm it is completely free and worked for my phone
Mar 22, 2009 | LG RUMOR Cellular Phone
Locked lgks360 to boost mobile, i want it on telstra
Hi, have a look on www.pb4kn.co.uk/ks360_unlocking.htm it is totally free and works really well.
Jan 28, 2009 | LG RUMOR Cellular Phone
Unlock key for LCD JUKEBOX
Have the cracked version
at
http://teamfluxion.synthasite.com/resources/LCGJukebox.sis
If asks for serial key,
Put '0'
Please Rate
Oct 29, 2008 | Nokia 6600
Cell Phones Logo
1,371 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
