Can I connect external speakers to this tv? - Televison & Video
  • Mark T
    Mark T May 28, 2011
    Please tell us which model you have.
    Problem Solver:
  • 17 Answers
Of course you can any kind of speakers will do
Posted on May 28, 2011
  • 151 Answers
he audio outputs from TVs generally are not powerful enough to drive speakers on their own. They are intended to drive an amplifier (like a home theater system) or amplified speakers.
You need an amplifier.
What do I need to connect external speakers to tv
You will need an amplifier and depending on your tv you can run either red and black RCA leads or a toss link fibre optic cable to it.Then connect speakers to the amplifier(stereo)
Aug 30, 2014 | Televison & Video
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
I want to connect external speakers to tv
If this unit has audio output jacks then these would be connected through an amplifier to provide your external speakers. Caution: Do not open the tv and connect additional speakers to installed speakers because you'll blow the small audio amp in the tv. I have seen this attempted many times
Dec 24, 2013 | Philips Magnavox 27MS343S 27" TV
How do I connect external speakers ??
You cannot connect external speakers directly to the TV. You can connect a receiver to the TV and then connect your speakers to the TV.
Oct 14, 2013 | Panasonic 42 TCP42X3 42 Plasma TV
Connecting external speakers
Hi ,
go into your settings on the tv and see if there is a section on speakers and try to set it to external speackers ,,,,,,,,,,,,,good luck Roy
Feb 18, 2012 | Computers & Internet
How to connect external speakers to this tv. Only output jacks exist for audio.
Most of the TV's do not have a speaker output and so you will need to open the set and take the speaker connect to be meshed along with a impedance matching.
You can connect with a switch wherein the TV speakers can be switched OFF and the external speaker connected . If not the external speaker if connected in parallel must not bring down the impedance to a lower level not supported by the output IC.
The other option is to use the output AV to connect to an amplifier and speaker. ( Your Audio system)
Feb 08, 2011 | Televison & Video
Hello, I have a very old mitsubishi color tv, model cs 2657r, which I purchased in the late 1980s. The picture is still great, and I'm trying to connect two small external speakers, though the internal...
Try stripping the speaker wires and exposing it about 1 inch. Then connect the speaker wires in a way that the part that grips or holds the wires touches the metal part and not the insulation. If there's still no sound, Please check the external speakers to see if it's working by using them in another device like a home system or audio player or maybe another tv that has an external speaker port. If not, mostly likely the switches are defective and needs replacement by a qualified technician.
Hope this helps.
Oct 25, 2010 | Mitsubishi CS-13103 TV
Can i connect external speakers
gjrob,
You can connect external speakers with you model only if you have an external source of sound such as a receiver. This model does not have speaker outputs to directly connect speakers but it does have audio out connections that can send the sound from the tv to another source like the receiver.
On the back of your tv on the left there are connections listed under "Out". There is where you will find the audio out connections (red and White).
-Chris
Mar 02, 2010 | Toshiba 27AF41 27" TV
I have a panosonic plasma tv when i switch it on it tell me there is a speaker short and then switches it self of model number pdp507xda help
It's the internal circuitry problem. Try muting it and put audio connection to other speakers if it repeats, your TV audio system is internally dying.the audio connections has to be checked and faulty components should be replaced.
1. Speaker short.
Open it up and check the speaker connections. ONLY if you have basic skills working on electronics and don't have a warranty.
2. Sound Volume "Leveler"
Look in your sound option menu for a sound "balancer" option and turn it off.
If this doesn't work disable the sound and invest in that surround sound system (external speakers solution of your choice)
try this.for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the audio circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off. if the tv is connected to externalk speakers then check out without connecting the external speakers and see whether it works.if it works that means tv is perfect.but if tv is having inbuilt speakers that its confirm problem with inter audio circuit of tv.so try connecting external speakers at the back of tv and check out.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 20, 2009 | Panasonic PDP-428XDA 42 in. Plasma TV
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
