Question about KitchenAid Toaster Ovens
How do I repair an artisan kitchenaid 4 slice toaster. The light comes on but the heating element doesn't. The element is ok. Would someone have an electrical schematic diagram ?
  • 776 Answers
Before you even start, most manufacturers are using special fasteners that cannot be unscrewed with standard homeowner tools. Make sure you can remove the 4 screws on the bottom to get the unit open. These appliances are meant to be disposable - even the expensive KitchenAid, Krups and Brawns.
If you do get it open, a heater wire is likely the cause of your troubles. The wires are heavy gauge (12 gauge) meant for high temperature. They are crimped onto a spade-type connector or crimped directly to a copper plate on the toaster because solder is not good near food or near high temperature connections like this.
It may look like the wire connecting to the elements is connected and ok but the strands the black casing are likely fried. Use a volt meter to check.
It is rare that the circuit board goes bad. If it is bad, there are no replacement parts available that i have ever found for these appliances so there is no point trying to fix it. The panels on the expensive toasters have on-board temperature sensors and even light sensors to "see" how browned the toast is getting. Unfortunately, these have microcontrollers that are programmed at the factory so you cannot replace it with a generic microcontroller (without figuring out the circuitry and writing your own program to control the toaster).
Sorry I don't have better news for you.
-Mark
Posted on May 28, 2011
Osher toaster oven
check breaker and plug --if power to unit will need a meter to test the controls,switches and elements
Sep 05, 2016 | Oster 003905-000-000 4-Slice Toaster...
Will not heat up.
The heating element may have failed.
Feb 03, 2016 | Hamilton Beach Easy Reach 4-Slice Toaster...
How can I troubleshoot my kitchenAid toaster oven? The timer works but the light will not go on, and it will not heat up on any setting.
The heating element went bad. The manufacturer makes it impossible to open the unit and doesn't sell parts - the lawyers told them it is too risky to let consumers repair toaster ovens.
Sorry.
Feb 25, 2015 | KitchenAid KCO222OB Countertop Oven
Why wont my toaster work
Bad move. It probably burned the heating element out.
Sep 30, 2014 | Dualit 26102 Lite 2 Slice Toaster
WHY DOES MY TOASTER OVEN NOT BROWN ON THE BOTTOM
Does the lower element come on? If not check the element, it may be burned out or one of the spade ends may have broken off. If its OK, check for 120Vac or 250Vac as the case may be, at the elements terminals.
Aug 21, 2014 | Applica Black & Decker 6-Slice Convection...
The toaster (upper) part of our 4-slice toaster oven model 6067 suddenly stopped working after several months of using it consistently. Will return it to Target but hoping it's an easy fix. We kind of like...
Hi there. I just repaired mine. The wire connected to left side (as you are looking at the front of the toaster) of the front top heating coil had come off. I replaced all four of the crimps going to each side of each of the top two heating coils as well as the wire going between the front and back coils on the left side. Make sure that you use HIGH TEMP crimps and HIGH TEMP wire. I had the crimps and purchased the wire from a ma and pa repair shop here in my town1_24_2012_10_47_09_pm.jpg
Jan 01, 2011 | Sunbeam 6067 Toaster Oven with Convection...
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 30, 2009 | Krups Toaster Ovens
Toaster Ovens Logo
413 people viewed this question
Top KitchenAid Toaster Ovens Experts
Think Crucial
Think Crucial
Tom Chichester
Are you a KitchenAid Toaster Oven Expert? Answer questions, earn points and help others
