Question about Kettler Mondeo Elliptical Trainer
My kettler elliptical squeaks and creaks. Can't really tell exactly where it is coming from. tightened all bolts and lubricated but it didn't help
4 Suggested Answers
SOURCE: Loud banging noise when using the Kettler elliptical trainer, ctr
This is a common problem for the CTR1, it actually sounds a lot worse than it is. It's just one of the 4 bolts that hold the front "pole" of the CTR1 in place that is broken. You will need to unscrew the bolts at the base (just move the plastic piece that hides the bolts up on the "pole"). After removing the pole you will need to remove the broken bolt from the inside of the "pole" with plyers. Then just put the pole back in the base, replace the screws (be sure to tighten them good). All will be good :)
This is a weak point of the CTR1, be prepared to run into the same problem again down the road...
Posted on Jan 16, 2011
SOURCE: Owners Manual for Kettler XTR-1
Here you go.  Its in all languages and is the only thing I could find:  http://www.kettlerusa.com/XTR1.pdf
Posted on Feb 05, 2010
  • 5 Answers
SOURCE: how to access batter on
If you look behind the unit, (directly behind the digital readout) you'll see a small rectangular inset, if you look up in that (I used my cell phone light), you'll see a tab that you can pry with a screwdriver gently to release the computer section. Just keep one hand on top, when you pry it you'll feel the unit pop up, then you can lift it out. It takes 2 AA batteries, thankfully not some bizarre disk batteries :)
Btw when you look at the readout, you'll notice it's set in a silver square- that square is the computer module that pops out.
Hope this helps!
Posted on Feb 21, 2011
Lifefitness elliptical. How do I fix a squeaky pedal?
There are several areas that could create squeaking in an elliptical,
  • Check the floor where your elliptical sits to verify the floor is level. An uneven floor could create strain on moving parts which would create squeaking
  • Spray an aerosol multipurpose lubricant onto any moving joints, especially metal on metal high friction areas like bolts and washers.
  • Apply grease around the rollers on the roller arms beneath the pedals. Operate your machine to spread the grease onto the roller ramps. Wipe away any excess grease.
Synthetic grease works best and will last you longer also.
I will be attaching a link to the grease we recommend, if any other questions come up please do not hesitate to call on our Tech Support Team at 888-713-2280 or visit us online at www.sportsmith.net
http://www.sportsmith.net/itemform.aspx?item=P0000SUPELUBE02&ReturnUrl=%2fproductsearch.aspx%3fdsNav%3dN%3a751055
May 28, 2015 | Exercise & Fitness
User manual for Kettler 07854-000 "Orion" Cross-Trainer Elliptal
Try here
http://toolbox.kettler.net/fileadmin/_kettler_dam_import/SPORT/Dokumente_-_Kataloge/Montage_und_Ersatzteile/Cro(ss)trainer/07854-_Orion_706f-1003.de,en,fr,nl.pdf
Oct 28, 2014 | Exercise & Fitness
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
May 29, 2014 | Exercise & Fitness
Clonking sound when im peddling backwards
please make this maintenance. God bless you
Depending on the amount of use, oiling your elliptical as much as once a month or once every 6 months can help prevent mechanical problems and avoidable repairs in the future.
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Aug 23, 2013 | Exercise & Fitness
My Nordictrack E9.0 Elliptical machine has a loud squeek
I have found a possible source for your squeak. I have the same elliptical and had an annoying squeak in the front end of the machine. The squeak could be coming from the roller arm flex bracket and/or the pedal arm flex bracket. These brackets are secured to the front of the roller arms and the pedal arms with a single bolt. Tightening these bolts may help get rid of the squeak. If you don't have your manual, you can download the manual at the nordictrack website. The manual will have an exploded drawing of the elliptical. The roller arm bracket and the pedal arm bracket are numbered 135 and 136 and you will see which bolt I am talking about. I have had numerous issues with my elliptical but after changing some parts under warranty, it is working like new. Good luck.
Mar 19, 2013 | Exercise & Fitness
Where and how often do I lubricate Spirit XE295 Elliptical
The manual for this Elliptical doesn't show any lubrication needed.
Is the unit starting to make abnormal noises like squeaks, thumps, or extra/less resistance?
This is from the owners manual for the Spirit XE295.
Maintenance:
1. Wipe down all areas in the sweat path with a damp cloth after each workout.
2. If a squeak, thump, clicking or rough feeling develops the main cause is most likely one of two
reasons:
i. The hardware was not sufficiently tightened during assembly. All bolts that were
installed during assembly need to be tightened as much as possible. It may be
necessary to use a larger wrench than the one provided if you cannot tighten the
bolts sufficiently. I cannot stress this point enough; 90% of calls to the service
department for noise issues can be traced to loose hardware or the rear rails being
dirty.
ii. Dirt build-up on the rear rails and polyurethane wheels are also a source of noise.
Noise from build-up on the rails can cause a thumping sound that you would swear
is coming from inside the main body of the machine because noise travels, and is
amplified, in the tubing of the frame. Clean the rails and wheels with a lint free cloth
and rubbing alcohol. Stubborn build-up can be removed with your thumbnail or a
non-metallic scraper, like the back edge of a plastic knife. After cleaning, apply a
small amount of lubricant on the rails with your fingers or a lint free cloth. You only
need a thin coat of lubrication, wipe off any excess.
3. If squeaks or other noises persist, check that the unit is properly leveled. There are 4 leveling
pads on the bottom of the rear rails, use a 14mm wrench (or adjustable wrench) to adjust the
levelers.
Jan 18, 2013 | Spirit XE295 Elliptical
Life Fitness 9100 Elliptical Squeaks
You can use the link below to purchase a suggested form of lubrication. You may end up needing to replace a bearing or bushing.
Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
Nov 24, 2012 | Life Fitness 9100 Elliptical Cross Trainer
Left side its sqeak when i peddle
My Precor EFX 546 elliptical trainer began squeaking when my weight was on the pedals. I thoroughly cleaned the track and wheels with Windex and then used my finger to apply a thin coat of teflon based lubricant (Tri-Flow brand) to the outer surface of the wheels. After 2 applications of lubricant, the squeaking has been eliminated completely. Hope this helps!
Sep 24, 2012 | Exercise & Fitness
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Nov 10, 2009 | Kettler Mondeo Elliptical Trainer
Kettler Mondeo Elliptical Trainer Logo
457 people viewed this question
Top Kettler Sport & Outdoor - Others Experts
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
