Question about Timex Expedition® Metal Field 47042 Wrist Watch
How to advance date 4 or 5 days on a Timex T40021
Yes worked thanks used to turn the hands took forever...thanks again
Posted on Jan 30, 2012
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 172 Answers
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
Posted on May 28, 2011
How do I set time on timex 1440?
Hi maggiemugs3,
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Apr 22, 2011 | Timex 1440 Nylon watch
Where do I find a user manual for a Timex Expedition (H2Y518)? I had Timex install a new battery and although the date 3-17 is correct, the day of the week is SUN. I have tried changing the date for over...
You are very observant! Timex watches don't have a way to adjust the day.
However, if you turn the hands clockwise you will see the day advance.
So, heres the secret, follow exactly:
1. Turn the hands until the day of the week shows the day before. If today is Wednesday then turn the hands until the watch shows Tuesday
2 Adjust the date to the day before. If today is the 17th then adjust it to the 16th
3. Now pull the crown all the out and and advance the hands until the date changes to the correct date, 17 in this example. This happens at midnight. Continue the movement in a clockwise direction for a few more hours and you should see the day change to the correct day.
4. Now continue to move in a clockwise direction until you have the current time. Remember that your date/day changed at midnight so if the current time is after lunch(noon) you must continue past noon to get to the correct time. If you don't do this correctly your date will change every day at noon instead of midnight.
If you don't succeed the first time, try, try again! Good luck, Michael, Watchmaker to the Stars!
Mar 17, 2011 | Timex Watches
How to set time on a 1440 timex watch
Hi tsgoode99,
Timex Digital Watch
Hope it helps.
Dec 25, 2010 | Timex 1440 Nylon watch
I have a Timex automatic with day and date. How do I set the day and date?
I often sell vintage Timex watches which have a day and date feature. Setting the day and date feature can be a little tricky - if not frusterating if you aren't familiar with how to do it since most of the original manuals that came with these are long gone!
I'll try to explain the process - please feel free to contact me if this doesn't make sense.
1. Pull out the crown on the right hand side of the watch.
2. Advance the crown so the time advances clockwise until the day is correct.
3. Rotate the crown so the time is going counter-clockwise (the opposite direction) until the date "clicks". (the day will click first, then the date).
4. Rotate the crown so the time is going clockwise again and the date will advance.
5. Continue this back and forth action of rotation until the date is correct.
6. Push in the crown and you're done!
I'm considering making a video of this process. Please let me know if this is something you would be interested in.
Oct 30, 2010 | Timex Automatic Watch
How to set time on a timex 1440
Hi macmcl788,
Timex Digital Watch
Hope it helps.
Oct 16, 2010 | Timex 1440 Nylon watch
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Sep 25, 2010 | Timex Ironman 53151 Wrist Watch
Would like to learn how to set time on on Timex 1440 sports watch
Hi danielrob676,
Timex Digital Watch
Hope it helps.
May 28, 2010 | Timex 1440 Nylon watch
1440 date change
Hi jhnmeserole,
Timex Digital Watch
Hope it helps.
Nov 05, 2009 | Timex 1440 Nylon watch
How to set the time on timex 1440
Hi r3girls1,
Timex Digital Watch
Hope it helps.
Sep 13, 2009 | Timex 1440 Nylon watch
Old model timex compact disc digital audio
Hi catlady05,
Setting an Alarm
Hope it helps.
Oct 29, 2007 | Timex Ironman 53151 Wrist Watch
Timex Expedition® Metal Field 47042 Wrist Watch Logo
384 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
