Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Pool heater says low pressure - Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
    Top Expert:
  • Jandy Master
  • 6,394 Answers
If filters are clean check pressure switch if 24 volts on both sides ok if not check copper tube for blockage you can jump just to check
Posted on Mar 05, 2016
4 Suggested Answers
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
  • 990 Answers
SOURCE: my laars lx pool heater is blinking LOW PRESSURE.
The heater needs good water flow or it will overheat. You probally have a full basket in your pump or your filter is dirty.
Posted on Jan 21, 2010
SOURCE: Message 'LOW PRESSURE' on my Jandy LX pool heater.
This isn't a solution, but a question after having the same problem and doing some troubleshooting. I removed the water pressure switch in the heater and turned on the pump and water flows nicely out of the copper tube for the water pressure switch. Next I replaced the pressure switch and removed the two wires and shorted them together, being as a switch is either on or off, shorted or open. I confirmed that the short is seen at the connector going into the control panel. I still have the low pressure light blinking. What now?
Posted on Jul 24, 2010
What does lo mean on my h250 hayward pool heater
LO standss for limit open. the most common cause is lack of adequate water flow through heater. other causes are high temp limits.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater 400k...
Air energy electric pool heater shows low pressure, low temperature and will not turn on
low pressure will either be gas or water. technician with a manometer can check gas inlet and manifold pressure. ensure adequate water flow from pump. pressure switches generally close at 2psi. you can jump the pressure switch if you think its faulty, or use ohm meter and check continuity of pressure switch
Oct 03, 2013 | Pentair MAXITHERM 333K BTU PROPANE GAS...
Laars pool heater low pressure
pressure switch fault, on inadeqauate flow to pressure switch
Jun 03, 2013 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
How do you replace a pool heater pressure sensor?
check pressure switch to see if voltage both sides if not see if copper tube is plugged make sure filters are clean
Sep 22, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Heating problem with laars lx400 boiler
replace or adjust pressure switch to have heater go off when pump is off
May 29, 2009 | Jandy Laars Lt 400,000 Btu Heater
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
