Question about Chaintech CT-9BJA Motherboard
Usb not working anny more with OS XP. I'm sure it is a driver issue.
  • Chaintech Master
  • 27,725 Answers
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Posted on May 28, 2011
Dell Latitude C840 issue. Have 4 input USB 2.0 PCI card adapter that is connected to side USB 2.0 serial port, but external HD and devices are still running at 1.1 speed (as if I plugged into the back USB...
Hi, I haven't got a Dell but try this site for the USB driver that is missing. With XP there is no support for USB2, an updated driver is required. Did you download the drivers from Dell? If not, that could be why as they may be old drivers.
Oct 29, 2013 | Dell Latitude C840 Notebook
HP 2520hc scanner drivers
Which driver set did you install? Did you install the HP basic drivers, the full software or the Windows XP built-in driver? The Windows OS driver usually only is the printer driver.
If you connected the USB cable before installing the HP software, you will get the OS drivers. Disconnect the USB cable and then uninstall the printer driver. (Start > Control Panel > Printers and Devices. Then right click on the printer and select Remove Device.)
Install the HP software. If you want to launch a scan from the all-in-one's front panel button, install the full software.
Next open the scan software on your computer. (This is the HP Solutions Center for most models if you use the full software.) Attempt to launch a scan from the software. Adjust the resolution and other settings as needed. Then use those settings to adjust the destinations for the front panel buttons in the software. (Settings > Scan Settings > Button Settings)
If this doesn't work, try a different USB cable, a different USB port on your computer and a direct connection (if you are using a USB hub). Scanners require bi-directional communication with the computer and may fail when the printer works due to a minor cable issue. If you have the printer connected to a router or similar device to turn it into a network printer, again the scanner will not work. Again the direct connection to the computer is needed.
If you are still having trouble, can you use the all-in-one's copy function? If not, do you have any error messages? If the scanner mechanism isn't moving, the unit probably needs service. (This model doesn't have a scanner lock to protect the mechanism in transit.)
I hope this helps.
Oct 15, 2012 | Office Equipment & Supplies
Lenovo b560 win7 64 bit can't see USB storage device
Which OS you are using? If it is XP then you may have to download the driver and then install it. Also check firewall settings because it can block certain devices. Even in xp thumb drive should work perfectly.
Parts For Mercedes Benz
Aug 13, 2012 | Lenovo b560 Notebook
Attempting Computer PC to HDTV hook-uo using VGA/3.5mm auio toconnector box converting to HDMI. The line fromm PC to box is 25 ft. and the line fom box to HDMI plasma TV is also 25 ft. . Computer is...
You need to make sure you changed the sound device properly in windows. To do this right click the speaker in the bottom right hand corner of your screen and hit playback devices. Then select the correct device. If you don't know which you can select one and right click and hit "test". Keep trying them until you get sound out of your TV.
If that doesn't work then make sure you have the latest sound drivers. There are two audio drivers on the Gateway website that might work http://global-download.gateway.com/GDFiles/Driver/Audio/Audio_Realtek_5.0.1.5704_Vistax64Vistax86_A.zip?acerid=633675264897204477&Step1=DESKTOP&Step2=LX%20SERIES&Step3=LX6810&OS=ALL&LC=en&BC=GATEWAY&SC=PA_6G and http://global-download.gateway.com/GDFiles/Driver/Audio/HDAudio_nVidia_1.00.0.37_Vistax64Vistax86_A.zip?acerid=633675265145088477&Step1=DESKTOP&Step2=LX%20SERIES&Step3=LX6810&OS=ALL&LC=en&BC=GATEWAY&SC=PA_6G .Try them both and at least one of them should work. You may need to restart your computer after installing the drivers but after that everything should work fine.
May 13, 2011 | Gateway (6000161) Sound Card
Install of Brother 1440 parallel driver needed. How many MB of space is needed? Plz, cannot install USB version of 1440 Running XP Profl OS
You can download drivers and utilities on this page:
http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/dlf/download_index.html?reg=eu&c=eu_ot&lang=en&prod=hl1440_all&dlid=&flang=English&os=7&type2=-1
If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
Mar 04, 2011 | Brother HL 1440 Laser Printer
My base doesn't light up the power display and sound display at the bottom. The power button works; however, the volume buttons do not. I also have hooked the dock up to a 2 port USB KVM switch and it...
what OS, what operating system.
KVM are very unreliable. , we could talk KVM for days, on this.
no KVM evens stated, brand or model number.
dock ,circa 2008, compatible with V6000
what OS on v6000.
we can not guess what OS you are running, at all.
its a USB problem with the KVM.
V6000 is a 2006 product..
that came with XP or VISA, neither are supported now.
the V6000 must have all its HP drivers installed to work right.
no KVM is guaranteed to work here, with XP its real bad.
XP has bad USB drivers, that are infamous for not working
with odd USB devices, nor many other things,
got SP3 for XP, IF XP>? it fixes some of that be never all.
this is a V6000 to KVM USB issue.
and no OS stated at all.
May 23, 2017 | HP xb3000 (417329-001) Docking Station
I am using Pressario M2000 series model m2202tu Laptop . i have my sound driver missing . kindly help
You can download the drivers from the
Compaq/HP WEBsupport/download page.
1)Make sure you select your model laptop and
the XP orVista Windows version of the drivers
you require and install them.
2) Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Nov 17, 2010 | Compaq Presario M2000 Notebook
I need a creative zen v plus driver
Copy that huge address and it will bring you right to the download page
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=15306&prodName=ZEN+V+Plus&bTopTwenty=1&VARSET=prodfaq:PRODFAQ_15306,VARSET=CategoryID:213
Jul 02, 2010 | Creative Labs ZEN V Plus MP3 Player
I removed U3 stuff from my Cruzer micro 2.0GB; now I get message
I would like to point out that this must be something the u3uninstall utility did to the usb stick. Mine was working at full speed while I had the U3 stuff on there, and stopped working at full speed in both windows 7 and ubuntu 10.04 after I used the tool. Sorry this isn't a solution, but it's additional info. It's strange it makes it seem like the problem is your OS or drivers and not the usb stick itself, or what the u3uninstall utility did to it.
Jan 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
49 people viewed this question
Top Chaintech Computers & Internet Experts
Ed Mac
WTF Chuck.....
WTF Chuck.....
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
