Question about iCall
How do i remove any extra files and registry entries related to the software iCall from windows 7 ultimate 64 bit os?
  • sammypresley May 31, 2011
    well i wanna thank you for that response
  • 1,381 Answers
Hi sammypresley
Download RevoUninstaller from http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Reinstall your product first and use RevoUninstaller for a complete delete of the program and cleaning of your registry . Select the advanced mode . This is the easiest and safiest way .
Best regards ,
fanaudi .
Posted on May 28, 2011
  • fanaudi
    fanaudi Jun 01, 2011
    You are welcome , sammypresley . Fanaudi .
How to change an operating system on the c:/ drive without destroying the information on the drive. Your email address: JCMCJMC68@YAHOO.COM
Your motherboard has to accept 64 bit OS before anything. If it is 32 bit only it will never load a 64 bit operating system. The easiest way to keep all your pictures, music and any other data files is to transfer them to an external USB drive. If you don't have the original software installation disks the software you have on the C drive won't run because the registry will have to be rebuilt. If you do get the 64 bit version of 7 to work, you'll have to upgrade most of your existing software to 64 bit versions. Example: installing a 32 bit version of Word will not run on a 64 bit machine.
Sep 24, 2014 | HP PROMO 8100 ELITE SFF WINDOWS 7 CUSTOM...
I used twinkle cam successfully in windows xp. I have upgraded to windows 7. How do I get the driver or will anything work?
According to http://www.chicony.com.tw/download/di/driver.asp , the available drivers were written in 2004. Chicony has stopped supporting their cameras for newer Windows OS versions. I suspect they never made a 64-bit version of the driver for XP 64-bit.
If you had the 32-bit version of Windows 7, you might be able to use the compatibility mode to install the driver. To check your version, click on Start > Control Panel > System and Security > System. Look for your Windows version and check if it says x64. If you see that in the description, you have the x64 bit version. Otherwise, right-click on the driver file from the above site (after extracting the files from the zip file). Choose Properties and the Compatibility tab. Check the box for always Run this program in the compatibility mode and set it to Windows XP in the drop-down menu. You may need to repeat this on the camera software as well.
If you have a 64-bit version Windows Home Premium, you may be better off upgrading to Windows 7 Pro or Ultimate. Then you can download and install Virtual PC and the XP mode, if your hardware can handle that software. This gives a virtual version of the 32-bit version XP that will run your camera. (The CPU needs to have virtualization support and it has to be enabled in the BIOS. Then you need enough memory to give the virtual XP at least 512MB -1GB of memory.) If you already have Windows 7 Pro or Ultimate, just use XP mode. Other virtual PC software exists but they require a licensed version of XP. (If you can find a valid license.) The only issue I've found is that files saved to the C: drive in one OS can't be accessed by the other OS. You have to transfer the files with an external drive, flash drive or burn the file to optical disc.
Dual boot systems with XP and Windows 7 can be set up if you have the XP license. Then pick the OS you need when you boot up the computer. This requires you to repartition the hard drive or have two bootable hard drives. Make sure to back up before partitioning the drive.
I wish that I had better news for you.
Aug 22, 2013 | Chicony TwinkleCam DC2110 Webcam
How do i increase the performance of ma dell inspiron M5030
You can perform the following steps for better performance:-
  1. Increase the virtual memory.
  2. Remove run, run once entries from registry. The path for run, run once entries is " HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run"(For 32 bit OS) and " HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432\Microsoft\Windows\CurrentVersion\Run" (for 64 bit OS), " HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run" (for 32 & 64 bit OS).
  3. Download and run a scan from Malwarebytes Anti-Malware. The link for Malwarebytes Anti-Malware is " http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=rb_content;main;pop"
  4. Remove toolbars and other Antiviruses
  5. Delete temp, %temp%, and prefetch files.
  6. Delete the files from this location C:\Users\<USER NAME>\AppData\Local\Microsoft\Windows\Temporary Internet Files.
  7. Run Disk Cleanup by cleanmgr
  8. Reset the browser
  • For Internet Explorer, you can reset it by inetcpl.cpl
  • For Mozilla Firefox, Google Chrome and Opera "ctrl+shift+delete".
Also if possible download ATF cleaner from www.download.com to delete the temp files and folders.
Feb 24, 2012 | Dell Computers & Internet
I just re-installed the latest version of iTunes 10.3 hoping it would fix the error box that says the Registry for burning CD's isn't working..Recording Disc software not working, etc. It still...
You probably have a problem with your gear driver software and your chipset. This is a lengthy thing to fix but if you want to brave it, goto this link 3 Removing GEAR Drivers. Follow the section for your OS be it Vista 32/64 or Win 7 32/64.
Once you remove the gear drivers reboot your system and try itunes. Note: You may have to reinstall the latest version after doing this.
I stress... make sure you follow the gear removal instructions exactly as it requires editing the registry and removing some system files. If you edit the wrong registry entry or delete the wrong system file you may cause your system to not boot correctly.
This is a bit in-depth but its faster then what most people do in this situation... which is to reinstall windows :) I try not to recommend that! :)
Cheers Chris
Jul 19, 2011 | Apple iTunes
Why I cannot remove AVG in my laptop? The last time I tried to uninstalled and the process looked not to work so I turned off my laptop. When i tried to remove AVG, it does not work at all. So, I cannot...
If you are facing problem in removing or uninstalling Avg Antivirus from your computer then no need to worry, In this case, the user just need to dial Avg help desk number UK +44-800-756-3354 and make sure that quality form of the technical solution is provided round the clock. http://www.antivirus-helpnumber.com/avg-antivirus.php
Jan 11, 2011 | AVG Download 1-Year AVG Internet Security...
I am using windows 7 ultimate 64 bit OS. i am having turbo c++ 32 bit software.how can i install it in my laptop...
The Turbo C++ you are trying to install is just incompatible for your OS. Because your OS is of 64-bit and you are trying to install 32-bit one. Try to find a 64-bit Turbo C++ program.
You can try downloading this one for 64 bit compatibility:
Turbo C++ for 64bit
Dec 19, 2010 | Computers & Internet
Lexmark 5400 series model no X5470 is not working with windows 7 ultimate . please give me a solution Amresh Mishra
First, unplug the Lexmark printer from your computer. Then uninstall any existing Lexmark X5470 driver from your computer. Go to Start menu -> Programs -> Lexmark X5400 Series -> Tools -> Uninstall. Uninstall the driver. Reboot pc when prompted.
When your computer turns on, check if your Windows 7 is running on 32-bit or 64-bit service type. Go to Start menu -> right-click on Computer -> Properties. Take note of the Service Type.
Visit the Lexmark website to download the Vista driver. Use the links below:
Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Dec 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
Black lines on scans and prints HP 2727nf
Oct 27, 2010 | HP Laserjet M2727nf Multifunction Printer
O s
The four things that make 64-bit Vista inadvisable for ordinary users are:
1: No compatibility with old 16-bit Windows apps. This means ancient Windows 3.x software, which most people don't run any more, but 16-bit code can still pop up in the darndest places. Like, for instance, in the installer programs for other apps.
2: No automatic registry and file redirection, which is what 32-bit Vista uses to allow existing software to work with Vista's better user account security, even if the software wants to do admin-rights stuff to the registry and Program Files directory. Many apps still break in 32-bit Vista, but many more break in the 64-bit version.
3: No compatibility with existing 32-bit drivers. Everything on your computer will need a new driver. 64-bit WinXP is the same, and there aren't many 64-bit computers on which Vista won't at least install, but 64-bit Windows also has...
4: No support for unsigned drivers.
Jan 28, 2008 | Computers & Internet
Computers & Internet Logo
Top iCall Computers & Internet Experts
David Payne
David Payne
Are you an iCall Computer and Internet Expert? Answer questions, earn points and help others
