Question about American Standard Heating & Cooling
I have three units in my house. Two work and one does not. These are brand new and never been used until last week. I am looking to troubleshoot. Any help would be great
    Genius:
  • 1,015 Answers
What I would do first is to compare the wiring between the unit that is not working to one that is. Make sure thermostats are hooked up and set the same. Check t-stat wiring into furnace and from there to condensors.Check voltage into contactors on a/c.With t-stat not calling for cool there should be 220-240 volts across input leads.Turn t-stat to call for cooling and contactor should close and compressor come on.If the contactor does not close then double check all t-stat wiring or replace stat
I would check all breakers an fuses if so equipped. If these units are all new can't you have contractor take care of it under warranty. Thank you
Posted on May 28, 2011
We have a propane tank outside to supply our range stove in the house for some reason the gas is not reaching the stove anymore , can it be the cold weather?
I would suspect the regulator might have iced and maybe if you poured hot water over it it would pass on thru system but be prepared to buy a new one if it doesn't .
Jan 13, 2015 | Cars & Trucks
I have a Dometic RM2652RBX Refer. The last two trips out it has given us problems. The first trip it worked fine all the way to Texas. We spent 2 weeks in Texas with no problems. We went to the Grand...
If the RV was level when it did not function. First you will want to open the rear vent of the fridge on the RV and check for a yellow residue above the burner area. If you do see that, then you will require a replacement cooling unit because the pipe ruptured. It is common in all new RV fridges that the cooling units lets go within 3 to 7 years. Check out ArctiCold Refrigeration We keep it cold the replacement cooling unit can be purchased through Ebay Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 17, 2013 | Dometic RM2652 Refrigerator
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
This unitr was working until a few weeks ago, then
some will not reconize generic disc and i hate to say this but keep trying using another disc sometimes although new disc will not be formated like they are suppose to be.
Jul 28, 2010 | Pioneer DVR-112D DVD RW Dual Layer Burner
Seven months ago, a bosch alled at my house
you will always have this problem in city type of appltcations.there is too much of a flow differation.
Jul 13, 2009 | Bosch 2700ES Natural Gas AquaStar ...
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
Clicking from Condenser
I would have to say it's your fan going out, also if the units aren't fixed the the DD should come out and fix it for free since it wasn't done the first time. I would take a look at it but I don't know where in florida you are. I'm in highlands county. If your close enough I could come take a look. If there's clicking coming from your condenser then it's one of two things, the compressor or the fan. hopefully the fan. let me know.
Sep 29, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Completely dead
Hi This is my opinion only, but I have worked on many many DVD players, and if you don't need anything fancy, then go for the $30.00 unit. Actually, I would look for something in the $50.00 range, as the $30.00 units are very cheaply made. I have often worked on a $100.00 unit, followed by a $50.00 unit, which had the exact same laser and mechanism inside, the only difference being the brand name stamped on the front. But.... You could purchase three $30.00 units, for $100.00 and if you used them one at a time until the last one died, I dare say they would very likely outlast the $100.00 unit by far. I've probably just confused you now, so I'll just end by saying that on a regular t.v., the picture will look just as good using either option, and you can have good luck or bad luck with any piece of electronics expensive or not. Good Luck!
Aug 12, 2006 | Toshiba SD-3980 DVD Player
Heating & Cooling Logo
19 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
ROCKIT957
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
