Question about Vacuums
Bought a used Electrolux canister vacuum cleaner on Ebay. Worked for about 15 minutes. Opened bag area to see what size needed to order more bags and now bag light stays and unit won't work or unit will now work when hose is attached. It starts up for a second and then shuts off and the yellow bag light goes on. There is no obstruction in the hose
  • kalikosar May 28, 2011
    The switch inside is there and works fine. The unit works when the hose is not attached. Once it is attached the unit will turn on and then shut off immediately.
    The switch you mentioned is there are works fine. The problem appears to be more with the inlet area. When nothing is attached the suction and vacuum work. Once something covers over the outlet the yellow bag light comes on and the unit shuts off. Or if I try to attach the hose, the unit will turn on for a second and then it shuts off and the yellow light comes on.
  • 776 Answers
My first guess would be that the switch insidet the bag door is not pushed in (or missing).
The cardboard frame around the bag is supposed to push it in when the bag is properly positioned and the bag door is closed. The switch may be missing or loose.
The switch is there to make sure you don't run the vacuum without a bag.
good luck.
-Mark
Posted on May 28, 2011
  • Mark T
    Mark T May 28, 2011
    After looking into it more (and finding out the simple answer didn't work for you), I found that this is a known problem with the Electrolux cannisters. If you model has a dial that controls the suction on the unit, you can try to adjust that (to turn down the suction - it opens some vents in the cannister. If that doesn't work, there is a "control valve" just below that dial (or somewhere in the unit if you don't have a dial).
    The control valve shuts the unit down if there is an apparent block - the sensor is bad so it always things there is a block in your unit (unless no real vacuum is formed in the cannister when you have no hose).
    getting it apart may be a challenge (sealed system). Some vacuum repair stores work dirt cheap so you may want to bring it in for an estimate before you do anything yourself.
    If you decide to do it yourself, The parts are available from on-line vacuum/appliance parts stores (http://evacuumstore.com/ ).
    Good luck.
    -Mark
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
What size vacuum bags does an Electrolux Ultralux 2000 bagged Cansister have?
It takes the "C" (canister) bags made by Home Solutions for Aerus Electrolux vacuum cleaners.
Apr 24, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Model of BAg?
HI Your Exlectorlux uses Electrolux Style OX bags. Here's a few links back to our website to several different style of bags that will fit your Electrolux:
Genuine Electrolux Vacuum Cleaner Bags for Harmony Canisters
Generic Electrolux Style OX Vacuum Cleaner Bags for Harmony canisters
Hopefully this helped you! Please be sure to rate my repair helpful, or leave feedback if this was able to answer your questions.
Thanks,
Chris Jones
GoVacuum.com
May 02, 2010 | Electrolux Harmony Canister Vacuum -...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Can't get dustbag to fit
The dust bag doesnt fit into hose your supposed to out ur bag into the plastic bag holkder then sit inside the canister and this model does not take an ox bag it takes an s bag y
Apr 10, 2009 | Electrolux Harmony Canister Vacuum -...
Electrolux 2000 Mod# c151c
Turn the knob on top all the way to the right
Jul 04, 2008 | Electrolux UltraLux 2000 Bagged Canister...
I have Electrolux canister vac. The suction end pops open everytime it loads up.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689886
Generic problem for all Vacuums
Posted by wmcox on Jun 20, 2008
I have Electrolux canister vac. The suction end pops open every time it loads up.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In the door there are vacuum lines that could be pinched or bent and are not letting air through to the bag, the system is designed that if the bag get to full or the air flow is restricted it will pop the door open and save the motor from burn out. This is repairable and nor to expensive and to check with the local vacuum cleaner dealer in your area or to call the Electrolux cust serv @ the factory for further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
