Question about Yamaha 12V Air Pump
2004 yamaha waverunner FX cruser check engine light flashes - how do I fix this. I was told to look at the engine sensors - where are they and what do they look like?
5 Suggested Answers
finish line
  • 207 Answers
SOURCE: My 2005 Yamaha FX HO Waverunner runs smoothly, but
yes yes yes the new yamahas foul plugs like crazy i dont know if it is a valve defect or what but you will be changing them every year one trick i have been doing to my coustmers watercraft and has been working well insead of ngk cr9eb plugs use a cr8eb it is a hotter plug there for it will burn better and no it will not hurt your ski trust me i have over 15 yrs ex and 6 in r&d research and design
Posted on Jul 08, 2009
finish line
  • 207 Answers
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
PWCYoda
  • 118 Answers
SOURCE: 2004 gp1300r jetski 20 mins riding and overheating
pull out the cat temp sensor and check to see if its bent. if so then its definently your catalist, even if not bent chances are still good it has failed. you need to be sure which light is coming on. does it look like a tube with squigly lines going up?
Posted on Mar 10, 2010
  • 429 Answers
SOURCE: strong vibration 2004 yamaha xlt waverunner
Something was stuck to the intake obstructing flow.
When you shut it off it drifted away.
It is a good practive when in weedy or heavy debree areas to get clear shut the motor off count to 30 then restart and gradualy excelerate to make sure it is clear. used this method for ten years now and seems to work well for me.
Posted on Mar 18, 2010
It Runs but has very little power,quits often,if you give it to much throttle it bogs down
Robert, First try new plugs, check fuel filter, sounds like it could be carburetor/injector issue, dirt,plugged jet, etc. Remove and clean/rebuild carb./injector.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
XLT1200 Bogs down
Thread 2004 FX HO ECU Problem
Waverunner Loses Power and Wont go Above 35 mph Solution
https://answers.yahoo.com/question/index?qid=20080525091900AATkgJh
May 23, 2016 | Yamaha 2004 WaveRunner Superjet Base
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Waverunner is abnormally slow accelerating initially, but will finally get up to normal speed
Pull your air filter out and also replace plugs. Overtime the filter will become saturated with oil and believe it or not the plugs can cause about a 10 mph drop if there going bad. But make sure your pump and impeller are not damaged also
Sep 18, 2013 | Yamaha 2004 WaveRunner FX Cruiser
Yamaha wave runner check engine light comes one and will not run properly.
Have the fault codes read. Replace faulty items. Use only
genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units. This results in the fault codes not cancelling out.
Jun 09, 2013 | Yamaha 2009 WaveRunner FX SHO
Got my 2009 Yamaha FX sho waverunner under water, drained the water from the hull and tried to start it. Turned over 5 or 6 times and stopped. Pulled the air filter out and of course had water in it....
remove all sparkplugs and hold full throttle and crank over several times to get water out of cylinders ! have a jump pack ready as battery will die ! use carb cleaner on the plugs each time you try to run after this , hope this has only just happened as internal damage might already started ! if all ok check the engine oil also as water normally gets in after this problem ! if oil is milky then change oil several times , run for 15min on hose each change until oil normal colour ! then you must take for a run for an hour to help dry it out !
Mar 19, 2013 | Yamaha 2009 WaveRunner FX Cruiser SHO
How do i replace the camshaft position sensor on a 2004 infiniti i35
hi, i have infinity fx 35 2003 it light on the service engine camshaft position sensor bank 1 , i replaced the bank 1 after 3 hour it light on again service engine + VDC off and slip i put the scanner it told me camshaft position sensor bank 1 again what can i do ?
Jul 24, 2010 | 2004 Infiniti I35
2004 fx CRUISER ho WAVERUNNER DOESNT WANT TO IDLE OR RUN AT TOP S
did you mean 900 cause 9000 is overrived and the engine may be blown
Jul 08, 2010 | Boating
Feb 15, 2010 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
421 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
