I think my phone has downed a ribbon inside it. i can open it but when it turns on, only the "welcome hands" is appearing. then after that, nothing is appearing at all. just the battery bar, and i can only dial numbers, but nothing is appearing. only white background. what will i do? how can i fix my 6131 phone?
  • 100 Answers
There might be a problem with your display screen.
Posted on May 28, 2011
My samsung galaxy s 4g will turn on but then just vibrates with a blank screen. I tried to reset it with volume down+ power but the reset menu doesn't come up
do this to wipe partition cache
  1. Turn off the phone
  2. Note: If the phone will not power down, remove the battery and reinsert it.
  3. Hold the Volume Up, Volume Down and Power Key simultaneously.
  4. Release the keys when the Android recovery screen appears.
  5. Press the Volume Down key to highlight Wipe Cache Partition.
  6. Press the Power key or Home key (this varies based on the software version of your phone) to select.
  7. The phone will display Cache Wipe Complete after a few seconds.
  8. Press the volume keys to highlight Reboot System Now.
  9. Press the Power key to select.
i advise you to back up everything first before doing master reset
Mar 28, 2017 | Samsung Galaxy S GTI9000 Smartphone
Tip
How To Reset Your Motorola Droid
<span style="font-weight: bold;">Soft Reset</span><br /> <ol> <li>Press "Control+Alt+Delete" on your Droid.</li> <li>The phone will reboot.<br /></li></ol><span style="font-weight: bold;">Hard Reset</span><br />This will clear all of the data off of the device.<br /> <ol> <li>Turn the Droid off. If it won't turn off, remove and reinstall the battery.</li> <li>Open the keyboard and press the <b>X</b> key while pressing and holding <b>Power</b>.</li> <li>The device will power on. Continue holding down the buttons until a yellow triangle "<span style="font-weight: bold;">Warning Sign</span>" appears on the screen.</li> <li>Once the yellow warning sign appears, press the physical "<span style="font-weight: bold;">Volume UP</span>" and "<span style="font-weight: bold;">Camera</span>" buttons simultaneously to get to the menu. This may take several attempts before success.</li> <li>Use the direction pad to the right of the keyboard to select the <b>Format</b><span style="font-weight: bold;"> </span>option, or the <span style="font-weight: bold;">Wipe Data/Factory Reset </span>option.</li> <li>Scroll down to the "<span style="font-weight: bold;">Yes -- delete all user data</span>" and press the "<span style="font-weight: bold;">Center</span>" button on the D-Pad.<br /></li></ol>
on Feb 15, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Kodak Easyshare z730 - possible problem flexible flat cable. I had a recent problem with a stuck power/mode dial turning too far past the video mode. I was successful in carefully opening the camera and...
It's obviously a switch problem, not a ribbon (which controls the lcd screen) problem. Start doing your research to find that "perfect" camera. Read all the reviews to see what actual owners think in addition to the experts. Or......you can "limp along" until you get tired of that.
Oct 05, 2011 | Kodak EasyShare Z730 Digital Camera
Hi, I have recently exchanged the keyboard and now only the shortcut keys work. i.e. when I press "e" the "edit" window opens. What should I do?
Two possibilities that cause this problem:
1. the data ribbon is not in right. Recheck the data ribbon (connection ribbon)
2. the function key might be stuck down. It may appear to be up but still be stuck in contact position as if held down
It is more likely the first thing so check that first. I'm assuming you matched the particular model compaq when getting the keyboard?
Apr 05, 2011 | Compaq Presario CQ60-220US PC Laptop
Hi have sonny w760i problem it's working suddenly, screen appear "no network coverage" then can't make call and can't choose network. Even though I select 'normal mode' at start up it still...
Hello and Welcome to FixYa!
Don't worry, once my W595 got the same issue all of a sudden, its a Firmware/software bug.
All you should have is your USB data cable (That comes with the new phone; named as DCU-65).
If you have it, then navigate to this link, download, install and run the software.
It a Software update utility, follow the instructions from the wizard. This will update your phones software. You issue will be resolved after a successful update.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Feb 17, 2011 | Sony Ericsson W760i Cellular Phone
Kenmore Ultra Wash Dishwasher, model 665.15812, "locked" light stays on. Pressing and holding "no heat dry" does not cancel "locked" condition, neither does unplugging unit.
Hello Everyone,
Flashing Lock Button...tried pressing every button in every sort of sequence you can think of? Well try this!
After washing dishes by hand for a few weeks while I tried every solution I could find on the internet, I finally got my Kenmore 665.15812 Dishwasher to work! I found this post: http://www.applianceblog.com/mainforums/sears-kenmore/10277-kenmore-dishwasher-model-66515632000-flashing-air-dry.html
At the bottom Martee says that he jiggled the ribbon wire that is connected to the board (looks kind of like an IDE cable you'd find in a PC). I took off the inside pannel and the black box protecting the circuits. I jiggled the ribbon wire, and sure enough, I felt a click, shut the door, and everything was back to normal! HURRAY!
Dec 23, 2010 | Kenmore Dishwashers
When the phone is slide open, the top 4 buttons dont work
hi :) after reading your pro,i sure that phone ribbon has spoil already. because slide or flip phone.inside the conection are control by a ribbon. after long time slide or flip open/close.the ribbon will spoil. it conect from main board to upper inner keyboard control panel. that mean if ribbon spoil,the menu, options, mail, and calender button do not work.so. send to your nearby mobile shop for repair,change a new ribbon.your pro will solve :)
Jul 06, 2010 | Samsung Propel A767 Cell Phone
Unknown icon
I had the same problem for awhile too.
The box is your call equalizer settings.  The descending line indicates "boost bass" and the ascending line indicates "boost treble"
This usually only shows when you have your BB headset connected, to change the settings:
-plug in your headset -make a call, (voice mail works good for this) -press your menu button -select "Enhance Call Audio"
-make your selection
You'll see your choice on the screen
Let me know if this helps 208E019D
Apr 16, 2009 | RIM BlackBerry Bold 9000 Smartphone
Zire 71 screen
Two possible scenarios:
1. Loose LCD screen connector inside the pda. You will need to open it and put it right.
It requires some level of skills to open it, repair it, close it properly.
If not precautions are taken, there are two major risks:
a) Break the flat ribbon cable of the universal PalmOne port (used to synchronize it and charge it).
b) Break a tiny switch that detects when is slided the top side so the camera application turns on.
2. LCD screen is damaged. It needs replacement.
You can get in touch with local repair services for it, and request a quote for its diagnostics and repair.
If after get some quotes, you think that they are excessive, you can contact the Ebay seller Great_items_2004 to receive a lower quote for it.
Regards,
Jul 08, 2008 | Palm Zire 71 Handheld
Dash screen will go white.
For me, the problem was definitely the ribbon connector between the graphics chip and LCD. The YouTube video below describes how to open the dash. You only need to open the device (i.e. no need to take out the printed circuit board) and then you should re-seat the ribbon cable in the lower left hand corner back onto the PCB. Hardest part was finding a #6 torx screwdriver.
Jan 09, 2008 | T-Mobile Dash Smartphone
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
