Question about Maytag Dryers
Need to put on a plug to a dryer don't have manual dry model is Maytag sde305dayw 3wire
  • Maytag Master
  • 7,482 Answers
Hi denn1s200020...
Go to this webpage and you will find the picture you need.
Free answer, Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Posted on May 28, 2011
Testimonial: "you are the man hunter19"
Maytag atlantis not heating up
Heater gas relay might be in need of being replaced as mentioned on page 54 of the slope faced service manual for Maytag dryers circa 1999.
Nov 21, 2012 | Maytag Dryers
Need SDE305DAYW dryer belt routing diagram. Please help
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Scroll down and you'll find the maytage diagram. There are many, but it's about half way down.
Good luck, it might help to have a buddy help for an extra set of hands.
Mike
Aug 04, 2011 | Maytag PYE2300AY Electric Dryer
In my Maytag dryer model SDE305DAYW the heating element works; however, the tumble drum stopped moving. What's wrong?
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
I hope this helps! :)
Dec 15, 2010 | Maytag HYE3657A Electric Dryer
Maytag dryer model SDE305DAYW drum will heat but not turn. Belt is not broken/
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 29, 2010 | Dryers
I need help replacing maytag dryer belt model no.sde305dayw . I am having a problem getting around the pulley maytag dryer
The Link below will show you the configuration for all dryers. Choose the one that looks most like yours keeping in mind that some dryers are made under several different names: Good Luck
Belt Configuration
Nov 12, 2009 | Maytag Dryers
Dryer wont shut off when the clothes are dry
Most likely your timer assembly is defective. If you are so inclined, unplug the Dryer and remove the back cover (several screws)at the top section of the back panel. Pull the timer knob off the front panel of the dryer. There are usually a couple of screws that hold the timer assembly in place and a wiring plug in module, unplug and remove. You can go to a local Appliance Parts depot(see yellow pages or internet) and take the old one in to match up the part number etc. It also helps to take your Make/Model/Serial numbers in as well. This part is usually about $30 to $50. Many of these Parts depots can test the old one for you if you ask them to see if this is the actual fault before buying the new one.
Oct 13, 2009 | Maytag Dryers
Maytag SDE305DAYW
hi thanksfor the question the noise that you hear could be the blower wheel this is a very common problem with maytag the blower is located at the left front
Sep 22, 2008 | Maytag HYE3657A Electric Dryer
Maytag dryer sde305day won't heat
you may need to replace the heating coil from the back... i have the unit pulled apart as we speak :).... also make sure to check the connections on the back switch to the heat selector! if you need pictures i would be more than happy to get them for you please contact me a Admin ........ at .......WhyPayForHelp .... .... dot org ... the e-mail is "encrypted but you should be able to figure it out :)
~Lee
Mar 20, 2008 | Maytag HYE3657A Electric Dryer
Maytag model sde305dayw
Check your fuses or breaker...If you have fuses, replace both 30 amp fuses. If you have breakers, flip breaker to OFF then back to ON, then try your dryer to see if it heats.
Dryers Logo
168 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
