Question about Lexmark X2500 All-In-One Printer
E mailing from scan sheet - Lexmark X2500 All-In-One Printer
  • Official Brand Answer
  • 3,344 Answers
You can refer to the Lexmark X2500 User's Guide on how to scan documents or images for emailing. Go to page 43.
Posted on Jun 01, 2011
I just want a new element fitting instruction sheet for my russell hobbs k2 kettle
if you still need a copy of the fitting instructions for your k2 element, i may be able to help, if you have a e-mail address i could try sending you a copy, ( send me a reply to pamplinandy@yahoo.co.uk ) and i will scan mine and send to you,
Oct 25, 2012 | Kitchen Appliances - Others
I'm trying to scan an A4 size sheet(document). I was getting the same size of the scanned sheet, but now its shrinked its size so that I can not getting the same size as in the sheet. Please help me...
Hi
Try the HP software rather than the Scanner itself.
HP Solution Center > Settings > Scan Settings > Scan Document Settings > make sure it is set to Scan Document as Image (no OCR) > Apply > OK.
I hope this helps.
Aug 24, 2011 | HP ScanJet 2400 Flatbed Scanner
How do i scan more than one sheet into a pdf document?
In Adobe Acrobat, go to -File-/-Create PDF-/-From Scanner-/-Scan-. Scan your first sheet and after it is completed, in the Acrobat Scan Dialogue box, click on -Next-, and scan the next sheet. Continue until you have finished your document and then click on -Done-. You can make your scanned document searchable by doing an OCR procedure on it by going to -Document-, -Recognise document by using OCR-/-Start-.
Aug 12, 2011 | Canon MP560 All-In-One InkJet Printer
Bothers MCF-490CW 4 in 1 || scanner - when scanning multiple pages, what must I do so when I send as an attachment the attachment is one group instead of each individual sheet?
Create a WORD document then paste each images on a page, save the Word document and then send this Word document as an attachment in your e-mail.
If you do net want to send the Word document then you can create a PDF of the Word document and send the PDF file as an attachment.
Jun 06, 2011 | Office Equipment & Supplies
How do i get the fax to fax more then one page?
keep all the sheets of paper one behind the other together in the faxing tray and let the FAX do the rest....
Nov 18, 2010 | Brother MFC-210 All-In-1 Print/...
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
I have a Toshiba 3550 w/ malfunctioning mg-1003 10 bin sorter. I would like to disable the sorter and run without it. I was told to change system mode 4 from 1 or 2 to 0. It was already set to 0. Which...
Please check out these codes and descriptions, if they are ever helpful.
C01 Main motor drive problem C21 Optics problem Scan , lens, mirror C26 Exposure lamp detect problem C32 Setup error (UA) C41 Fuser thermistor, or no heat C43 Fuser thermistor problem or other fuser problem, after machine goes into ready C44 Heater problem C54 Communication problem between sorter and machine main board C55 Communication problem between ADF and machine main board C71 ADF drive problem C72 ADF registration sensor problem C73 EEPROM initialization problem C81 Sorter paper conveying motor C82 Sorter bin motor C83 Sorter upper sensor C84 Sorter lower sensor C85 Sorter home sensor C86 Sorter copy removal sensor C94 Optics initialization problem in test modes E01 Paper jam E02 Fuser jam E03 Paper jam E05 Paper feed jam E14 lower cassette jam E71, E72, E73 ADF jam E75 ADF jam of 2nd original E81, E82 Sorter jam
Good luck.
May 23, 2010 | Office Equipment & Supplies
How can I stop my printer automatically printing out a test page when I switch it on?
every time u switch on the printer it will print the alignment sheet until you scan it.once the alignment sheet is printed ,keep it in the scanner glass and press the scan button.this will scan the alignment sheet.
Sep 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
Scanning sheet music
Scan all pages with GrayScal Single Page JPEG and then convert them to Multipage PDF.
Jan 22, 2008 | Canon CanoScan 8000F Flatbed Scanner
Fi-4990c problems- front optical sensor
fi-41990 scanner cleans after scanning 100,000 sheet for paper roller the pad cleans after scanning 100,000 sheets feeding path cleans after 200,000 sheets http://www.fujitsu-europe.com/support/scanner/manuals/consumable-option_3-5-8.pdf
Aug 09, 2007 | Fujitsu fi-4990C Path-Through Scanner
Lexmark X2500 All-In-One Printer Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
