Question about Refrigerators
Hi, Is there of clearing the drain hole from the back of the fridge? Mine is blocked and so water is condensing and settling under the salad tray. Thanks
  • 520 Answers
A little air pressure works the best. if you have an air compressor or a portable air tank, usa a blower nozzle. if you can regulate the air then turn id down low, like 15 pounds or so. stick the nozzle in the drain opening inside the fridge and wrap a rag around the nozzle at the drain opening to prevent blow back. give it a quick burst of air and it should be unblocked. if not then give it a little more pressure. after its clear then pour a little bleach water down the drain to kill the slime . good luck
Posted on May 28, 2011
Testimonial: "Thank you so much but I haven't got an air compressor. I am just a housewife. I have a hoover that's all. Can that be used?"
  • mike42353 May 28, 2011
    no could ruin your vacuum. air works the best, do you have a shop vac. you can revers the hoseon that and maybe get it to work. or do you have any neighbors around that could help. the whole procedure only takes a minute.
    there is one other thought. one time i didnt have access to air. i used a rubber hose that would fit into the drain, packed a rag around the hose at the drain and blew on the other end of the hose and it did break loose. you could use a plastic tube but it has to fit inside the drain.
Water is collecting at the bottom of the fridge under the salad trays constantly
Whenever that happens on our fridge we find that the drain out the back is blocked. Have a look inside the fridge on the back wall, you may see some guttering that guides the inside moisture to a hole. That hole drains to a pan on top of the motor. Heat from the motor evaporates the water. I have always managed to clear ours by poking a bit of flexible wire down the hole. It's not a frequent occurrence, probably 7 or 8 years between blockages.
Aug 11, 2015 | Refrigerators
Hi our CB18M/1c/FAN keeps gathering water under the salad trays please advice thankyou
You say it runs down the channels.
Is their a drain hole at the bottom?
If the drain hole is blocked then you will need to unblock it using compressed air or a thin piece of medium flexible wire.
It should drain to a pan near the compressor and evaporaste from
there. Sometimes a loose particle of food can block the drain, usually at the back lower position of the fridge.
Jul 25, 2015 | Refrigerators
Water gathers in salad boxes
Hi,I found out that there are two resons for this that I know off.
one the drain hole where the water runs down at back of fridge is blocked,second one is when you put food in the fridge and it gose and tuches the back wall of the fridge it couses the water on the back of the fridge to the veg tray insted of going out of the overflow hole at the back,hope this was some help.
Jul 16, 2015 | Frigidaire Refrigerators
How do fix water inside refrigerator under bottom drawers
It may be your drain hole at the back of the fridge has become blocked.
There will be a channel at the back (or side) of the fridge that collects condensation with a drain hole out of the back of the fridge. The drain hole becomes blocked with mould / gunge causing the excess water to overflow and puddle in the bottom of the fridge.
The hole may be gently cleared with a small diameter rod or stick.
Mar 08, 2015 | Frigidaire Refrigerators
WATER COMING FROM UNDERNEATH SALAD DRAWER
My guess is that the drain tube is still clogged.
Sep 18, 2014 | Hotpoint FFS70 Bottom Freezer Refrigerator
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Water at the bottom of the GE side by side refrigerator
Check annd see if the fridge is level and the drain hole inside the fridge is clear , its at the bottom at the back of the fridge , if it is pull the fridge out and check where the pipe runs into the condensate tray on the motor at the bottom this also can block very easy!!
Mar 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water accumulation under crisper bins
Check that the hole at the back of the fridge is not blocked with gunge.  There should be a drip tray at the rear with 2 slopes towards the hole where the condensation drains to.  Some cabinets come with a little rod to clear the blockage.  The rod may live in the hole alowing water to drain around it.  Have a peek!
Feb 22, 2009 | Frigidaire FRT18S6AW Top Freezer...
Hotpoint RFA 60 Refrigerator drain problem
Well the only way to check it out completely is like you said going from inside your freezer and I like to pour water down the line to make sure it drains.
Take the back panel off inside your freezer and locate the opening of the drain. You will see the collection tray just under your coils and in the middle you will see the opening. Now if it is blocked by ice just take a couple tea spoons of table salt and pour on the opening. Ice will melt very fast and then the opening will clear and then take some water and pour down it.
If the opening is clear just pour water down and observe the drain pan under the unit and see if it comes in there.
Jan 18, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Water beneath my salad bin
if the drain is truly not blocked then the water will go down it. try poking a piece of thin wire down it to check, and have a look on the outside at the back - some models have a tray or tank where this water collects that may be full - else the fridge drain should be plumbed into a drain - check from the outside too. Also check if the fridge is truly level. The feet allow you to adjust this and see - sometimes a small change in angle can spoil the drainage characteristics of these machines (possibly even lean it backwards a little if it looks like this might help). the only other possibility is if the fridge drain is fixed into another drain, that another appliance or fixture is causing back pressure - if so you would be able to see bubbling into your fridge if you sat and watched while someone else ran all the sinks/toilets/washers/dishwashers etc around the house - in theory though when all these other items are not running then the water should still drain.
Mar 10, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
308 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
