Question about Mantis 2-Cycle Tiller
How do I adjust blades to dig troughs? - Mantis 2-Cycle Tiller
Have a gravel driveway bought a Ariens 24 Snow Thro adjusted skid shoes to lift machine, is the scraper blade also adjustable, it is throwing a lot of rocks?
Yes, they are all adjustable. Loosen the hardware, Find something to use as a shim... a few paint can stirrers.. put them under the Scraper to lift it about 3/8" then tighten the hardware. See how that helps the stone throwing. Gravel driveways are tough for Blowers and Plows...It's best to actually leave snow on the driveway to pack down and form a Base. Then the next snow will be stone free.
Jan 07, 2017 | Garden
Troy-bilt rzt mower deck has heavy grass build up on the left side and leaves ridges whine mowing.
First thought is " is the blade on that side turning?"
By ridges do you mean digs into the ground on that side?
If it is digging into ground on that side then yes you need to adjust the height on that side. this is usually done with the wheel on that side or maybe both sides.
May 11, 2016 | Garden
Toro timecutter42 blades squealing and won't turn
just had a guy tuesday bring me a zero turn that did the same thing xcept his fell off his trailer ramp and bent one of the blade spindles so now blade digs into cover , engine off blades spin sort of free?
May 07, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
What is a Pulaski axe?
A Pulaski is an axe with a mattock blade built into the rear of the main axe blade, used for digging through and around roots as well as chopping.
Apr 18, 2013 | Tools & Hardware - Others
What is a Pulaski?
Feb 03, 2013 | Garden
How do I lock the height adjustment on makita mlt100
You almost answered your own question.. As you've already discovered, the blade will slowly move as you're feeding stock to cut, so you can either locate the missing locking nut/screw, or buy a replacement from the nearest Toolshop.. Or dig out a 50-75mm machine bolt from your junk box & use this as a temporary replacement.. You'll have to check for the correct thread size 1st as they may differ from country, but I'm sure that'll solve the problem for now..
Aug 17, 2012 | Makita MLT100 TABLE SAW FOR 220 VOLTS
Thanks for the help. I don't know what happened but this is my true problem. I have a 2002 TL that the blade hits the bottom rest only when the window is wet. I questioned if the wiper blades are not...
at the base of the wiper blades there is a nut that holds the wiper arm to the linkage it sounds like the nut is loose tighten the nut on each one and see if it fixes it if it doesnt fix it then it would be in the linkage but i believe it's the nuts
Jan 12, 2010 | 1997 Acura TL Series
RIGHT SIDE BLADES CUTS LEVEL, LEFT SIDE DIGS INTO THE GROUND
the right side cuts level but left side doesn't well the answer i have would be that someone stepped on the deck which will cause the adjustment arms to bend & deck will not be level or the only other thing it could be is the blades could be bent as well if i can further help e-mail me @ wadembly@aol.com thanks ,wade
Jun 08, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
19.5 hp 42 in cut craftsmen lawn tractor.I got from grandmother,blades were bent got new sears blades still digs into ground and doesn't cut in middle,do I need a new deck?
No,You need to park on a level area and lower the deck to it's lowest setting and adjust the deck with the large butterfly nuts on each side,just under the foot pan,just loosen and let the adjusters fall into place,Tighten back up and it should be set.You may need to do this more than once.
May 11, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I just purchased a Hitachi C12LSH. The blade hits the guard in the cutting trough. How do you move the saw blade to center it?
you should be able to adjust blade up a little bit, you only want blade to cut through tile bout 1/4 inch ,should be big knob you lossen to lift up motor and blade good luck
Aug 02, 2008 | Irwin Miter Saw Laser Guide Attachment...
Mantis 2-Cycle Tiller Logo
15 people viewed this question
Top Mantis Garden Experts
Mike Squire
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Mantis Garden Expert? Answer questions, earn points and help others
