Question about Dane-Elec DaneElec 4GB USB Drive Red Hard Drive
I need to remove write protection from my 4G flash drive. havr tried to reformat but this does not work, internet suggested contact maker for answers.
  • Dane-Elec Master
  • 27,725 Answers
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on May 28, 2011
Remove write protect on my usb flash drive
Some flash drives have a manual setting available for turning on or off protection. If not, the on/off protection is et by a software switch. Check with the Flash drive maker for details on removing the protect function. This is not a DELL setting.
Mar 05, 2014 | Dell I15r-1158mrb Core I5 2.66ghz 6gb...
Tip
Blu-ray/DVD/Flash to HTC EVO 4G Conversion,Rip Blu-ray to HTC MP4 Great news to...
Great news to HTC EVO 4G users comes when Sprint announced the update of smartphone operating system to Android 2.2. Sprint is the first carrier to offer Android 2.2 to HTC EVO 4G with Flash support. However, there is no Blu-ray support to Sprint Supersonic HTC EVO.
Aunsoft Blu-ray Ripper is the right Blu-ray to HTC EVO 4G converter for you to enjoy Blu-ray movies on smartphone.
Rip Blu-ray to HTC EVO 4G:
You can load Blu-ray disc and DVD disc to the converter, and load BD/DVD movies from computer hard drive with disk structure.
Downscale 1080p Blu-ray to HTC:
Convert high definition Blu-ray movies from 1080p to 800x480 to fit the screen of HTC EVO 4G.
Remove copy protections:
The HTC EVO 4G converter removes the copy protections like BD+. ACCS in Blu-ray disc, CSS, region code in DVD disc, so that there is no pixilation on the output videos, and ensure smooth playback on HTC EVO 4G.
Why choose Aunsoft Blu-ray Ripper as Blu-ray to HTC EVO 4G converter?
- Convert Blu-ray 1080p to Sprint HTC EVO 4G at 800x480.
- Remove copy protections to enable smooth playback on HTC EVO 4G.
- Rip DVD movies to MP4 for HTC EVO 4G.
- Support disc conversion and DVD-file structure conversion.
Free Download Blu-ray to HTC EVO 4G converter for your Windows computer with OS like Windows XP, Windows Vista, Windows 7. It is no longer difficult to play Blu-ray movies on HTC EVO 4G. If you are using Mac computer like iMac/MacBook Pro, you may try the Mac Blu-ray to HTC EVO 4G converter.
on Aug 09, 2010 | Cell Phones
How do i remove parameters from a kanguru 4 g usb flash drive?
Which format fat32 or ntfs make sure its fat32 Indeed, FAT32 only supports files up to 4 GB. I ran into the same problem when copying an ~4.5 GB file to an 8 GB flash drive. There is a quicker solution that doesn't require you to reformat or lose data on the drive, using the command-line "convert" command. Suppose the flash drive is mounted to g:\. Open up a command window (start menu -> run -> cmd), and type: convert G: /FS:NTFS. Personally, I don't need the "security descriptors" on the flash drive file system, so I use the variant: convert G: /FS:NTFS /NoSecurity. The conversion should be very quick, and of course it has the benefit of not needing to move any files off the flash drive (since you don't need to reformat it). Hope this helps.
Dec 18, 2012 | Kanguru 4GB FlashBlu II USB 2.0 Flash...
I cannot reformat my flash drive..always indicating" write protected" what shall i do to through reformat it?
Hi sampagac ,
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Hope this helps ...:) your feedback would be appreciated.
May 13, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a PNY 4g flash drive. My pc nor Mac will recognize the device when it is plugged in. I have tried downloading USB drivers and nothing is working. I do not have a backup of this flash drive and I...
Try reformatting it:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Jan 09, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My verbatim USB 2 GB is write protected. I am not able to remove write protection. Please suggest to solve the problem.
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Nov 12, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Kingston DTI/1Gb usb is write protected and cannot be reformatted. I tried fixing it using a software that can format usb even if it's write protected but it says cannot found flash drive. It seems not...
Probably a damaged flash drive. Copy what you can to a new one and discard the damaged one but not in a landfill site! Use a recycling station.
May 24, 2017 | Computers & Internet
Ive tried to drag songs from itunes & put them onto my sandisk card & tried to copy & paste it but it still dont work all it say is "remove th write-protection or use another disk" why is...
The write protection is the little slide on the side of the disk. You just need to slide it towards the side with the gold contacts. If you hold it so the label is rightside up, the switch should be near the upper left. You need to slide it up to unlock.
Sometimes you also get this error when the disk is bad or corrupted. you can reformat it and that will fix it. If it will not format i then you have to replace it.
Sounds like the switch.
Sep 05, 2010 | SanDisk 2GB microSD Memory Card
How to reformat a write protected usb?
No need to reformat your write protected USB. The hings you should do is to slide to small button you can see in your USB to remove the write protected.
Mar 29, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protected 4 GB GENX USB
I ve a 4 GB genx USB that.It become write protected. How do I remove the write protect so i can reformat it? The device doe't have a write protection switch. What's wrong with it?
Jan 16, 2010 | Electronics - Others
Dane-Elec DaneElec 4GB USB Drive Red Hard Drive Logo
112 people viewed this question
Top Dane-Elec Computers & Internet Experts
Steve
Piyal Perera
Piyal Perera
woodzowl307
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
