Question about GPS
I have a genie garage door opener - screw vs. chain - and the motor turns but the screw does not. The door will not open. What might be the problem?
    Guru:
  • 1,833 Answers
With a screw-drive Genie opener, thecoupler could be exposed. If it is you will have to take down the opener andinstall a new coupler. The coupler is located at the end of the opener rail andthe motor head. For any other assistant you canvisit http://www.geniedoor.com/troubleshooting-guides.Hope this will help you.
Posted on May 28, 2011
I am missing the lever for the bolt
Genie Screw Drive Garage Door Opener Failure - Repair ...
? 6:16
https://www.youtube.com/watch?v=htCkcs1SWvI
Feb 11, 2011 - Uploaded by sengsationa1
Genie Screw Drive Garage Door Opener Failure - Repair - Part 2 .... on the openings of the clip and wrenches ...
Prevent Garage Door Break-Ins - Instructables
www.instructables.com/id/Prevent-Garage-Door-Break-Ins/
InstructablesCatch the emergency release lever (yellow arrow) and gently pull until the ... That may work on many garage door openers, but this one is a Genie screw ... They don't care about breaking windows or making noise because they will be gone before the police arrive. ..... I am sorry to hear this is happening in Iowa now, too.
[PDF]garage door opener assembly/installation manual - Home ...
Dec 02, 2015 | Building Materials
Can I use tje existing screw/rail of the 1/2HP Genie CM86001C and replace the old head with the new PowerMax 1500 head or does the new PowerMax 1500 require a new screw/rail?
No rail wont fit quite right. I would consider a liftmaster/craftsman/chaimberlain with yellow antenna wire. The liftmaster models are 8355 or 8550. Not sure how those model #'s translate to the craftsmans and chaimberlains. These units use 3 frequencies which are chosen automatically by opener radio. This gives you the best option to avoid interference. Genie typalically uses 2, but their fixed, so its a crapshoot to avoid interference. Do not confuse these frequencies with the rolling code feature which is a static frequency with only the "channels" changing.
Mar 28, 2015 | Genie Garage Door. PowerMax 1500 1 HPc DC...
How do I stop my craftsman garage door opener from whining? it whines on the inside of the motor
is it gear or chain, is it genie or liftmaster. check for smooth operation of door by disconnecting motor. check tightness of cable/chain running down rail. this may be putting undue stress on gears and ruining plastic drive gear.
Oct 20, 2014 | Building Materials
Genie 900 door operator
hello,there is an adjuster on the side of the motor,also check that the micro switch[if fitted on your particular type} is 'clicking' and actually in contact with the arm as it revolves closed. hope that helps, cheers
Jun 02, 2014 | Genie PowerLift 900 1/2 HP Screw Drive...
Electric motor hums but does not open or close garage door
If it just hums and not actually run. Then the trolley is jammed against one of the stop bolts.
Mar 26, 2014 | Building Materials
Gene garage door openers
are you sure that it doesn't just stay on for 30 seconds to one minute and then shut off? if it stays on all the time, the light switch has been manually turned on and you need to turn it onto 'automatic'
Mar 18, 2013 | Genie 1/2 HP DC CHAIN MOTOR
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
I have a Genie garage door motor. Whenever I try to open the garage door, the door opens about 5" and then simply stops. What's going on?
check the track for tight spot it will stop if it is not stright, too close or too wide also check cable or chain for dirt lubracate all
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie garage door opener chain adjustment?
Remove the cover and check the main drive gear. It is most likely stripped.
Jul 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
GPS Logo
81 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
