My toshibaa equium a100-147 keeps over heating even when the fans are not blocked its very annoying and the laptop is running very slow lately i tried to take the case off so i could clean the fans but i couldn get the case off help me please
  • 5 Answers
Hi from what you are saying it sounds as if the processor is over heating due to bad thermal heat transfer, in short the heat sink compound needs replacing, this is a job for a laptop engineer
If you keep running it and it keeps shutting down due to over heating you will damage you processor.
hope this helps.
Posted on Apr 09, 2009
Toshiba Equium P200D-139 laptop wiv 19V plug keeps shutting down. Why
make sure its not over heating,
check the fan is running.
Jul 28, 2015 | Toshiba Computers & Internet
Does the engine cooling fan run continually
No the cooling fan should run continuously.
May 11, 2014 | Ford Fiesta Cars & Trucks
My Toshiba Equium A110-252 keeps turning off. When I try to turn it on, it turns off again. It can run for unspecified period of time (a day, a week) and one day it just turns off and it is impossible to...
It is not worth replacing the board as a new laptop is possibly cheaper. Could be an issue with the heat sink compound drying out and not taking the heat away correctly from the uProcessor. It may be fluff build up in the heat cooler!
Oct 07, 2013 | Toshiba Equium A110-233 A110-252 A110-276...
Toshiba equium harddrive over heating
i dont think its the hdd. its most likely the cpu. clean the heat sink and see if the fan is still working, you may even want to clean it a apply new thermal paste
if this helps please take time to rate
Feb 01, 2013 | Toshiba Satellite 1805-S274 Notebook
It is been 1 year that I bought my laptop.I have Toshiba A665-s6065.when I use it for some hours in normal cases(internet,movie,...),Toshiba health monitor shows me that my CPU temperature is going up and...
Hi RGH.
1. Fix Internal Cooling. The first and most important thing you need to do when your laptop is overheatingis to clean the fan(s) that provide(s) cooling to the CPU and graphics card. Over time, they build up layers of dust and dirt that slow them down and block airflow.
How to Fix an Overheating Laptop - MakeUseOf.
What can happen to a laptop if it overheats?
A laptop that severely overheats causes damage to the internal components. Before this happens, the laptop should attempt to shut itself down. ... If you smell smoke, a burning odor, the fans never run or the fan runs all the time, be careful to avoid ruining your laptop.
Negative Effects of an Overheated Laptop ' Chron.com.
How can I stop my laptop from overheating while playing games?
Maintain a cool environment.Try keeping your laptop in an air-conditioned or cool area to allow your system to cool down and prevent it from overheating. Consider using a heat sink. Use a steel flat bar as an external heat sink. It works because your computer has to heat up more mass before it overheats.
3 Ways to Keep Your Laptop from Overheating - wikiHow
HOPE THIS HELPS YOU OUT.
Nov 04, 2017 | Toshiba Satellite A665S6065 Notebook
My acer 5735z is over heating and turning off. the gurantee has run out on it, and i use my laptop everyday for college work, so i need it to be sorted soon. i have a cooling stand but sometimes that...
1. It is because the cpU fan within your laptop is not exhausting the heat properly for some reason.
2. Open up the laptop case and check if the fan is working properly or not. If not working, replace it immediately with a new one or it may burn out your processor itself.
3. Clean the dust accumulated on to the casing and heat sink which is under cpu fan as this may block air circulation.
4. If everything is done, your laptop should work fine. If you are not comfortable with doing youself, then seek help from any of the computer service center.
I hope this is useful to you
Thanks
Sep 23, 2010 | Acer Aspire 5735 Notebook
Hi all Technicians, I have Toshiba Equium A210-1as (PSAFJE). Problem: Shutting down itself after bios (post) - after 10-15 seconds or even 5 seconds depends how many times I want to turn the laptop on. I...
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked. You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 13, 2010 | Toshiba Computers & Internet
Equium M40X gets overheated
this is a laptop computer?
THis is probably a simple heating problem. if it is, you'll have to replace or otherwise repair the heatsink, and maybe the CPU as well.
In general, if this is still under warranty, your best bet is probably to just return it to toshiba for repair/replacement.
I would NOT reccomend opening the case on an in-warranty laptop.
However, in case this ISN'T a heating problem, or if you need a temporary workaround... these ideas MIGHT work. they won't be permanent solutions, though.
1. try setting your bios, and your windows settings, to the options that use the least power.  less power = less heat.
2. If you deliberatly overclocked your cpu at some point, reset it to normal speed. or even less-then-normal speed.
3.  are you certain this isn't just a power problem, or a corrupt operating system?  you might want to try reinstalling the os, and running the computer from an AC outlet, maybe even with the battery removed
Mar 29, 2008 | Computers & Internet
Fan Problem - Toshiba Satellite M35X-S349
Your fan is running to keep your system (mainly your processor) from overheating. Heat is the biggest enemy of laptops, and most aren't designed to put on your lap (as air intake ports are usually on the bottom and blocking them with your pants, comforter, blanket, etc... will not allow air to circulate causing heat sensing hardware/software to kick the fan into high speed) as that name would suggest. I believe that Notebook computer is the more proper term for most of them, though some are designed with no air intakes on the bottom side, unfortunately yours does. When you opened it up and "cleaned it" did you clean the heat sync and the other components or just the fan? If your PC is in a smoking environment it will have tar build up holding the dust and need a more thorough cleaning than just blowing it out with canned air from the outside (you may want to disassemble it and clean it with a non residual, non petroleum based contact cleaner. Otherwise there are plenty of temperature monitoring softwares out that will tell you what the processor and harddrive temperature are and most have free trials that you may want to try to see if heat is your problem. There is also software available to monitor and even increase/decrease your fan speed.
Good Luck.
Feb 24, 2008 | Toshiba Satellite M35X-S349 Notebook
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
