I can't install my camera on my laptop.. - Computers & Internet
Can't download my camera on pc even though have disc
Delete camera program. Install disc to reload software. Then connect camera. Update driver.
Oct 23, 2012 | Toshiba Satellite L10...
Can't download pictures to my L305 computer
First of all you will need to install the CD provided to you with the camera. It is not alwys necessary but since you can't so you will have to do that first and then you can easily download the photos from your camera. Also alternately you can remove the memory card from your camera and directly copy the photos to your laptop , no need to install the CD in this case..
Aug 26, 2012 | Toshiba Satellite L305-S5921 Notebook
No webcam detected error on laptop
If it's an external Webcam,please look for Universal Serial Bus controllers in the device manager,are there any device with '?' sign?
and if it's internal please look for a key on the keyboard which has webcam picture on it,usually F1-F12,and then press that key with Fn(function) key at the same time while the computer is on,and try to use the webcam
Aug 26, 2012 | HP ProBook Computers & Internet
My PDR-M700 Digital Camera will not connect to my computer when i plug it in with a USB
If the camera will work from USB, install the manufacturers software and drivers first.
Apr 08, 2017 | Toshiba PDR-M700 Digital Camera
My computer can't read camera and headphone
Hellooooo friend..............
Check first if the battery of your camera has the enough power to operate while it is plugged to your laptop.
If yes and still does'nt work.
If that's brand new, you'll find two kind of CD in the packaging; one is the installation CD and the manual CD. Install the installation CD for it will load the Driver of your camera. Then try to upload you picture again.
If that's not brand new, connect to internet and download the camera driver while your camera is plugged to your laptop
Sep 21, 2011 | Computers & Internet
Today I formatted my C drive and install win XP.............after completion of the installation I've installed all the dirvers and softwares which were there in the driver CD provided by ASUS with my...
You need to start WinXP in Safe Mode. Safe Mode does not load the drivers... you can then open the device manager and delete/uninstall the camera. Press F8 during the boot process (after the hardware logo and before the WinXP logo).
Aug 12, 2011 | Computers & Internet
When I try to download pictures to my laptop from my camera nothing happens...My camera says at the bottom communication error...I have had the camera since Feb and downloaded pictures to my laptop many...
Canon PowerShot SX130 IS Digital Camera's come equipped with the installation cds for their software. Make sure these are installed properly. The reason that the camera is stating "communication error" is that it cannot properly communicate with the computer, so make sure that your USB works properly (ie. no bite marks on the wire, it's not loose, you get the drift), that you're not using a USB hub (or if you are, it's capable of sending and receiving packets at a high speed) and that your camera is charged. Usually this can be resolved with changing the USB, so try another usb if you have one lying around, and make sure that it's connected properly to the camera and the computer.
Jun 30, 2011 | Canon PowerShot SX130 IS Digital Camera
I purchased Lenovo G560 last month which has the easy camera software was installed. However in the process of installing other softwares it uninstalled or remove the camera software from the laptop and I...
Since you bought it last month, i assume that you have Win 7 32bit OS. Go to the following link, select the appropriate OS from drop down.
select camera from 'Category' drop down. download and install the drivers.
VOILA....done
May 25, 2011 | Computers & Internet
I have a BENQ DC E800 camera and i've installed the driver in my BENQ Laptop but every time i hook my digital camera to my laptop it says unknown format and cannot be recognized and on my camera screen...
When you installed the driver do you have connect the camera to laptop, if the laptop cant't find the camera be connect to laptop when you installed the driver it will failed. Else, as to save life of your camera, suggest that to use card reader instead of connect camera to laptop.
May 03, 2011 | BenQ DC E300 Digital Camera
How i install the web cam of lenovo laptop with window vista
Hi patidebahuti,
The webam's software and driver that is compatible with Windows Vista can be downloaded on this link. For the wfebcam's driver look for CAMERA and you'll see underneath the driver for Windows Vista. And for the software, look for SOFTWARE then select Easy Capture.
Here's how:
1. First, click on the driver's name (Lenovo Easy Camera Driver).
2. You'll be routed on another page. Just click on Download.
3. Once it's downloaded to your laptop, double click on the icon to install it.
4. Finally, you'll be asked to Reboot/Restart your PC.
The same process goes with the installation process for your Easy Capture installation.
Hope it helps.
Thank you for using Fixya.
Sep 21, 2010 | Lenovo 3000 Y410 Laptop
Computers & Internet Logo
David Payne
David Payne
