Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
I have a white rogers thermostat type 1F80-0471-20-30VAC from Gaz Metro Plus for heat and air condition. I can not put it on "cool" anymore. Only "heat" and "off"
2 Suggested Answers
  • 961 Answers
SOURCE: where do i find operator
http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6841.pdf
This is the manual for your thermostat. You would want to pick what you want,; heat, cool, etc., and run. You want to be on auto and coll, heat, which ever you prefer.
Posted on Jun 09, 2011
We put in a hunter thermostat and now our central air conditioning unit is blowing cold air with the heater on.
Susan,
This means that the new thermostat is wired wrong. You did not post the make and model of the new one, the old one and possible the furnace and we need those in order to check your wiring and compatibility.
Oct 29, 2017 | Hunter Heating & Cooling
I need to know how to replace white-Rogers type 1e56w477 with a Honeywell rthl111 thermostat showing old wires to new
power off, R-R, W-W, Y-Y, G-G, power on!!! switch on back of new tstat goes to HE not HG
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 06, 2017 | Honeywell Heating & Cooling
Yes,a little more inf.that ight help solve my problem a little quicker.let me start from the begining.my wife kept switching from heat to air until my themostat finally stop working.it use to be hooke
Only the original new manual will give you the wiring. The bad news in manufacturers do not always use the t=same colors to d the same things. God Bless
John. Same happened to me and I guessed till it started functioning properly. Sorry
Apr 16, 2017 | Honeywell Programmable Thermostat Heater
White Rogers digital thermostat displayed "lo".
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. After replacing the battery you need to do the reset operation. If you need further assistance please contact us at 1800-284-2925.
Sep 24, 2012 | Heating & Cooling
I own a White-Rodgers manual thermostat...Type 1F56N-444 (horizontal version). I own a 1-Heat 1-Cool single stage Carrier Electric Heat HVAC system. Pls answer two questions regarding the thermostat: 1)...
No that is an heat anticipator setting that should be set to the same amperage as the gas valve o your furnace.....do not adjust unless you can tell this or you coulld ruin the thermostat...
Jan 04, 2011 | Heating & Cooling
My honeywell heater thermostat is only blowing cold air, there is no heat blowing regardless of setting. how can i fix it? it won't even turn off.
the wiring for thermostats are color coded. R(red)power, Y(yellow)cooling, G(green)common, W(white)heating. O(orange), E(emergency)heat. Make sure that you have the right thermostat because there is an air condition thermostat and there is a heatpump thermostat and they wire up differently.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Mr. no tv 4 you
Don't quite understand the first post.
W is white or heat
Y yellow is cool (or B for blue) either will do
R is red or 24v
RC is the same as R, unless you have separate transformers for heat and cool, place a jumper from the 2 R's
Your old wires, though are 1 white and 1 black, usually this indicates line voltage. 120v or a milli-volt @.750v. Either case, you have the wrong type of thermostat for this application.
Jan 10, 2008 | Honeywell Programmable Thermostat Heater
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
295 people viewed this question
Top White Rodgers Home Security Experts
Tom Chichester
Heatmeister99
Level 1 Expert
A Hoffman
A Hoffman
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
