Refrigerators Logo
Posted on May 28, 2011
My samsung srl3928b, keeps beeping and freezer temp is scrolling up and down, how can i fix this?
5 Related Answers
Anonymous
  • 290 Answers
  • Posted on Oct 07, 2007
SOURCE: Freezer keeps beeping and switching off
Next time this happens unplug it for about 10 minutes. When you plug it back up you should be able to turn it back on normally. This resets the board, much like restarting your computer. If the problem happens again, you will probably have to replace the board. You also want to make sure you have a good ground on the circuit and a steady power supply without too much fluctuation. Hope this helps.
Anonymous
  • Posted on Jan 03, 2009
SOURCE: Samsung Fridge can't get temp down
it is probably the door switch. I just pulled the switch from a rb2055 and disassembled the switch. one of the contacts is broken.
If you unplug the fridge and plug it back in, the light should work. push in on the switch button with the door open. If the light does not go out, switch is bad.
pry the switch gently out with screwdriver, unplug it and get a replacement.
If you are watching this I can also probably tell you how to jerry-rig it to run while waiting for replacement swicth.
Anonymous
  • Posted on Jun 22, 2009
SOURCE: over temp reset
This site is stupid - no one helped me fix anything - all ive gotten since I posted was spam to join
Anonymous
  • 117 Answers
  • Posted on Jan 16, 2011
SOURCE: SAMSUNG SR L3928B FRIDGE/FREEZER KEEPS
samsung fridge freezer problem">
Anonymous
  • 247 Answers
  • Posted on Feb 17, 2011
SOURCE: My Lg fridge/freezer is beeping
try to unplug your ref for several minutes then plug in after then start your unit to reset your unit then observe it.
Turn up the temp on a samsung side by side,lower drawer model, with digital display . touching the "Refig " button ( also marked as quick cool ) only sends temp down. how do we incr. to 37
Are you trying to get the freezer temp down or the refrigerator temp? If it's the refrigerator, Samsung might have a cutoff of 37 degrees to keep you from getting the temp to low and icing over your coil
Samsung refrigerator alarm beeping continuously
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
My samsung frige, french doors keeo ringing
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Samsung rs267tdpn beeping 11 times
Sounds like the temperature is your problem which is why it's beeping at you. The freezer is supposed to be at 0 degrees, which is well below freezing at 32. If your unit can't get down to temperature but your refrigerator is correct (38 is the ideal temperature for the refrigerator) then you have something wrong with your control board. If you keep pressing the freezer button it will go to -4 then -6, then so on until it goes positive and eventually you can scroll to 0 again. Either way if it's set to -4 it should easily be below 0 degrees. If it jumps back to the current temp, replace the control board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Samsun cool'n'cool the temp for the freezer keeps going up and down and beeping every 20 mins. I tried turning off and on cleaning around the air vents at the back and it still keeps doing it.. any...
you could try cleaning the door seals if there is a gap the seal will not close and the system will keep trying to freeze, anything can stop the magnetic door seals from closing properly, setting of the alarm over time.
Over temp reset
4helpful
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
