Question about Pro Line 2089VYD TV
My Proline LVD1985WD TV keeps saying No Signal in the middle of programs, although the aerial is connected and functioning fine when we tried it on another tv for 3 days straight with no loss of signal. What could be the problem?
    Scholar:
    New Friend:
  • 58 Answers
I'm having the same problem, i think it's something to do with a hardware fault with the dvb, your ariel is fine. If you have warranty on your tv set then take it back and ask for your money back and get a different tv altoghether. i've had three of these tv's and they all do the same thing. I gave up and got a samsung 19", I havn't had any problems with it. sorry that this isnt a fix to your problem as i dont think there is one, even tryed a firmware update, but they dont broadcast one for this tv so i'm at a loss with this, all the best.
Posted on Oct 30, 2013
My cello tv won't tune in at all. Every time I try auto tune it goes through the process of tuning then says no signal.
Auto tune would be for the old analogue TV system I believe. Does the aerial connect through a box or direct to the TV? The Sky box should connect through scart (very old) or HDMI which you just need to choose the right input for. Look for a button on your remote for input or an icon that looks like a screen with an arrow pointing into the middle.
Feb 18, 2018 | Televison & Video
Why does my new television keep pixcelating? I tried another television & it is fine. I have a booster on my aerial & another on the tv.
If it breaks up with large pixels it is a lack of signal but in your case it might be too strong a signal. On a new set it is unlikely you need to boost the signal. Try removing them. Also check the connections on your satellite or cable box. If you use a signal via an aerial, check for nice clean connections on the junction box at the aerial itself.
Dec 14, 2015 | Sharp Aquos Televison & Video
I have an Alba 16 inch flatscreen tv with built in digital tv. When i try to do initial setup or auto install it says check antenna connection even although ariel is in. Can you help
Do you have an indoor or outdoor aerial?
Indoor aerials will not have the strength to pick up television broadcast signal.
Double check your connections, as you could have a loose wire or connection somewhere.
You might need to speak to someone who, can take a look at your aerial to see if it is configured correctly.
Also to make sure it isn't a problem with the aerial, do you have another TV that you can try using on the aerial. to see if you can get signal?
Jul 19, 2011 | Televison & Video
Having brought my television back from the caravan i cannot now get it to tune in to any of the programes. It search but doesnot find any. Keeps saying no signal i know the aerial is ok i have had another...
just connect the cable then try to retuned. but no funtion?maybe the tuner is being damage due to caravan or there is a loose connection inside the tv
Jun 19, 2010 | Televison & Video
Lost our freeview. New TV in bedroom (Sharp LCD, LC-19SH7E-BK), which has freeview and was working fine. However, we set up a magic eye so we can have SKY (which we can now use through channel...
if you have connected your sky box as per instructions, putting the aerial coax to it and a fly lead(as in a male to female coax as used on a vcr to tv) from the output to the tv's aerial input, then disconnect the aerial from the sky box and put it back to the tv. The skybox will weaken and even loose the signal.
Feb 14, 2010 | Televison & Video
No TV signal
try a different aerial if that doesnt work do a factory reset and then redo your first time installation
Jan 02, 2010 | Televison & Video
Just moved into flat and my tv keeps saying no signal but i know its ok? i dont have the manual with me
You will have to retune the TV to the incoming signal, if you have tried this & still get "no signal" then you will need to check the incoming aerial connection & if there is a good aerial fitted for the flat.
Oct 19, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Code for total control4 - Proline TV
i have the same problem cant get a code for my durabrand dvd recorder
May 05, 2009 | Televison & Video
Bush TV Model No 5693D
Try using the source button to switch through different inputs.
If that does not work try connecting a signal booster to the aerial, they cost about ten pounds at Argos.
Mar 06, 2009 | Bush 5693D 24" TV
Televison & Video Logo
408 people viewed this question
Top Pro Line Televison & Video Experts
Are you a Pro Line Televison and Video Expert? Answer questions, earn points and help others
