Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
KENMORE HE4T STARTED AS BALANCE AND F11 NOW ITS F06
EVERYTHING WAS FINE FOR 2 YEARS AND 7 DAYS AS THE STORY GOES. THEN A BALANCE PROBLEM EMERGED WHEN I DID A SUPER LOAD OF TOWELS CAUSING THE DRUM TO SHAKE SO HARD IT FORCED THE DOOR OPEN BREAKING THE DOOR LOCK MECHANISM. I REPLACED THE DOOR LOCK MECHANISM AND ALL WAS WELL ALTHOUGH I NOTICED BALANCE ISSUES WITH LARGE LOADS BUT COULD COMPLETE LIGHT LOADS WITHOUT INTERUPTION. THEN I GOT THE DREADED F11. I PLAYED IT SAFE AND REPLACED BOTH THE CCU AND MCU IN THAT ORDER. AFTER CHANGING THE CCU THERE WAS NO CHANGE IN F11 STATUS. AFTER CHANGING THE MCU THE F11 CLEARED. WHILE I WAS DOWN THERE, I NOTICED THE FRONT 2 SHOCK ABSORBERS HAD BECOME UNATTACHED AT THE TOP SO I RE-INSERTED THEM. (WISH I HAD CHECKED THAT WHEN THIS WHOLE THING STARTED). AFTER THE MCU WAS SWITCHED THE F11 CLEARED BUT UPON THE FIRST TEST CYCLE THE F06 NOW APPEARED. SEEMS THAT AFTER WATER STARTS TO FILL FOR A FEW SECONDS THE MOTOR ENGAGES TO TURN THE DRUM FOR A FEW SECONDS AND THEN STOPS. IT DOES THIS 3 TIMES AND THEN DISPLAYS F06. I AM NOT VERY HANDY IN THE ELECTRICAL DEPARTMENT AND DONT KNOW HOW TO TEST THE MOTOR'S AMPS/OHMS BUT CAN DO OTHER PRELIMINARY CHECKS.
  • ONE4BRI Aug 17, 2008
    I AM TESTING VARIOUS COMPONENTS AND CANT GET A SUCCESSFUL TAKE-OFF WITH MY WASHER WHILE THE PANELS ARE OFF. IT TURNS FOR A COUPLE ROTATIONS AND THEN WINDS DOWN TO THE DREADED F06 EROR.I WONDER IF I MUST REINSTALL THE KICK PLATE AND BACK PANEL FOR IT TO WORK AFTER NOTICING A SMALL PRESSURE SWITCH BEHIND EACH PANEL?
  • ONE4BRI Aug 23, 2008
    TURNS OUT THE REPLACEMENT MCU BOARD WAS BAD AND THE MCU WAS THE ONLY CULPRIT ALL ALONG. THANKS!
    Genius:
  • 1,028 Answers
Ck all the connectors to both boards and motor you may have inadverantly left 1 loose or knocked one off during previous repair
Posted on Aug 17, 2008
I have an F11 code on my kenmore front load washing machine
After years of suffering from random F11 that became a permanent F11, I did the repair as in the video and all is good for 2 years. No more F11. About one load a day (we have kids!)
Aug 22, 2014 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore Elite HE4t washer Model # 1104599, F11 is appearing often and more often, what can i Do?
"I got this great help from a guy on this site a few days ago. He suggested taking the top cover off, then pulling the white relays ( there are 2 Omron ones K1 and K4) You have to remove the solder and then pull them off. He said he guaranteed one was burned. Sure enough. He suggested cleaning the off with a pencil eraser or scraping with an Exacto ( is what my husband did as the prongs are so close together) then switching them as one of them carries a lot less voltage, therefore doesn't burn You need a fine tip soldering gun for re-soldering or you may burn the circuit board. He put it all back together and voila! it works fine now. I have been putting up with this F11 code for 2 years and nobody could seem to figure out what was really wrong. This may get me through a year or two more before I have to replace these relays. If you are handy, you can do it yourself. The repairmen only want to replace the whole CCU board and that is expensive."
Hope this helps.. Good luck! :)
Jun 10, 2011 | Kenmore 45996 Front Load Washer
Water is in the bottom of the washer after a day
are the inlet valves leaking? to test this shut off the water supply, if the water stops then replace the washers water intlet valves..
Aug 25, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T Elite F06 problems
Given I had purchased the Extended Warranty, Sears replaced the washer. So, we will see how this one works.....
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
F11 code on my HE4t washer
I fixed this myself for $30 and an hour of time.
Took hi-res photos and created a step by step guide.
www.he4tf11.blogspot.com
Dec 09, 2008 | Kenmore Elite HE4 Electric Dryer
Door Lock Problem
with panel off reach up to lock location pull down on small tab door latch will click (at this point door would pop open if it were closed ) retry operation to see if ok if code dl reappear may to replace door lock if f11 may need new control module under top rear..ck wires first ..good luck
Sep 09, 2008 | Kenmore Elite 45986 Front Load Washer
HE4T F06 ERROR
Wow. Sounds like you've had your hands full with this one. Well, since you've already gone the route of replacing the CCU and MCU, more than likely you have a wiring harness problem and/or drive motor issue (as you have already explained). The following link explains the "F06" error and how to troublehoot:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Review the information and double check to make sure you have overlooked anything. Unless, you have purchased defective replacement parts, I can only assume the motor and wiring. Unplug the washer and perform resistance checks on the motor windings. If you have a multimeter handy, this would be on the RX1 scale. The pin locations are mentioned in the link provided. Each motor winding should read 6 ohms or less. On another note, the vibration problem you mention, was definitely caused by the shocks not being mounted properly. You may consider replacing them, since you said you're still experiencing vibration issues.
If you are still confused by anything, please let me know. I hope this helps you.
Aug 16, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
HE4t King Size Washer Balance Problem
remove the lower acess panel ( 3 screws across bottom) check for broen suspension/shock absorbers
Mar 02, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
160 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
