Question about Lasko 3300 Wind Machine Fan
I've had my Lasko Windmachine fan for a couple of years now. Just recently, I turn it on and the motor will only spin VERY slowly, no change when I change the speeds. The blades just barely spin around and I'm not sure the best way to fix this. No strange noises or rattling or anything, just the barely spinning. Any help you could give would be greatly appreciated! Jennifer
  • 1 more comment
  • jennifer_blo May 28, 2011
    It plugs into the wall. I've tried different outlets, no change.
    There is nothing I can find that is obstructing free movement.
    My fiancee is going to see if he can take it apart, so that he can lubricate the motor.
  • jennifer_blo May 29, 2011
    So we took some dust and animal hair out of the drive-shaft area and then WD-40'd the motor. So far, it's working like new. Just smells like WD-40. Thanks!
    I've had my Lasko Windmachine for at least a few years and it started running really slow. After clearing some hair and dust from the drive-shaft area and lubricating the motor, it seems to be running as good as new. Hopefully this isn't just a temporary fix, but so far, so good.
  • 670 Answers
Would you be able to see if there are any obstruction to the fan causing it not to spin with full power?
If none, would you be able to try give a push to the propeller see if that will make it spin faster.
If it spins then lubrication might be needed for the fans to spin like they normally do.
How is it receiving power? is it plugged into a power outet or does it receive power in another way?
If it's plug into a power outlet try another one because it could be receiving less electricity causing the fan not to spin properly.
If all else fails you may want to have it checked by a local technician because most likely there is a problem with the motor.
Posted on May 28, 2011
    Problem Solver:
  • 7 Answers
I had this problem, I turned it face down and beat the motor housing with my fist. Only been a few minutes but so far working on high speed!
Posted on May 31, 2014
Lasko fan wont blow air
Sounds like the fan motor is the problem
Aug 31, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
Tip
Lasko or Air King fan suddenly stops working.
I just figured this out with the help of a local electric motor repair shop (thanks Portty) and thought I share the information since it seems to be a common problem but no one has directly addressed it. Never by pass safety mechanisms! Replace them at your own risk and use your head!
If your fan suddenly stops working (as opposed to taking longer and longer to start turning) it is likely that one of the two main safety systems has been triggered. It's hard to know if it's the safety plug or a thermal fuse in the motor. These are two likely causes for your fan stopping working.
The safety plug, as I understand, has a standard fuse that trips when the current flow gets above some threshold (I suspect the threshold varies between models). For example, my 16" window fan is listed as using 0.8 Amps so they likely used a 1 or 3 Amp fuse in the plug. If the current goes above that it means something is wrong and so, as a safety measure it cuts the current, permanently. You can create your own, fixable alternative by replacing the plug and putting an inline fuse into the power cord above the plug. I would try to find a fuse that is not easy to open since you'll be exposing 120V when it is open.
A second possible cause is the thermal fuse that is located in the motor. This fuse triggers when the motor gets above its normal operating temperature. I've seen references for a 115C cut off, but I don't know for sure what it's threshold temp. is and, again may vary between models. There are numerous YouTube and Instructables that describe how to replace the thermal fuse. For my window fan, I had to disassemble the entire motor in order to able to replace the fuse. Be careful when soldering the new fuse not to overheat the fuse or else you'll blow it and have to put another one in.
More importantly, the fact that either one of these safety systems were triggered means there something wrong with your fan and you'll want to fix that before you restore the tripped safety feature.
One possible and common cause is the motor running out of lubricant. The motor spindle should turn freely when the fan is unplugged. Nice and smooth and very little effort when the blades are removed. If it is stiff, try oiling the axle at both ends. There are some small holes near where the axle comes out that is designed for oiling the motor. Try adding oil there, spin the motor, pull it back and forth, oil some more, repeat until it turns smoothly. Don't worry about using too much oil, you can just wipe any excess off once it starts turning easily.
#lasko #safety_plug #thermal_fuse #air_king
on Jun 10, 2015 | Lasko Dryers
Kenmore (11020722990) spinning slowly
If the coupling was broken, the machine would make a horrible noise. The way to check the pump is to remove it and take the lines off to verify any kind of obstruction. Now, chances are that the motor, a variable speed device with a capacitor, has more than likely started to go back, but the way to check this is to take the motor off, bypass the lid switch with a jumper wire(from one wire to another, just not the green) and plug the machine in and turn it on and see if it engages without a load on it.
May 27, 2012 | Kenmore Washing Machines
Fan blade does not immediately spin when turned on; loud
The motor bearings need machine (like sewing machine oil).
Try a quick spray of WD40 or Liquid Wrench, but use machine oil, soon.
Look for an "oil hole" on top of the motor; there may be two of them.
Oct 05, 2009 | Lasko 2506 16", 3 Speed, Oscillating Fan
My lasko fan stopped working after a power outage. the motor hums but blades dont spin
check the capacitor usually found beside the motor winding or inside the switch box of the stand fan
Aug 26, 2009 | Lasko 3135 Stand (Pedestal) Fan
Lasko Box Fan Stinks!
same thing with my lasko box fan awful oil smell
Aug 05, 2009 | Lasko 3720 Floor / Box Fan
Problem with a Lasko 3440 Floor/Box Fan.
light is on ,but there is no movement from the fan. I think I need a fan motor.Lasko 20" fan motor part #3440.
Mar 30, 2009 | Lasko 3440 Wind Tunnel Floor / Box Fan
Lasko E20739 Fan
It sounds like the electronic controls have put the fan into "breeze mode". The fan turns slowly then is supposed to surge back to high. Some people love this feature for some reason...
Disable breeze mode via your remote (its the button with the stacked ~'s).
A bad motor wouldn't rotate at all. The only other problem might be the motor's running capacitor. If you can start the fan in either direction (give it a hand spin in the opposite direction of rotation) you have a bad capacitor...and you can find a replacement anywhere (Radio Shack).
Aug 03, 2008 | Lasko 2530 Elite WindTower Fan
Lasko 3300 Wind Machine Fan Logo
871 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
