Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
How much salt do you add to a 20 ft by 48 in. Intex above ground pool?
  • 106 Answers
SOURCE: Just added an Intex salt water Gernerator to my
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Posted on Apr 18, 2010
  • 8 Answers
SOURCE: I am starting an above the ground pool with a salt water system
25 pounds per 1,000 gallons or 3 kg per 1,000 liters of water.
Posted on Jun 16, 2010
SOURCE: hi i have a 18 x 48 above ground intex frame pool
flow pump low signal comes up
Posted on Jul 19, 2010
  • 8404 Answers
SOURCE: it says low flow, how can i fix it
Low flow means there is insufficient water traveling through the cell to make CL. Is your cell clean and clear? Is your filter clean and clear? Clean your cell according to the manufacturers instruction and back wash your filter.
Posted on Jul 24, 2010
  • 8404 Answers
SOURCE: We change our pool that we have had for 10 years
The pool is green because you didn't take the metal out of the water first. It is too late now to do that ... you will just have to let the filter grab it. It may trake several days. Run the filter 24/7 for those couple days for best results.
Next time you fill your pool ... get a sequestering agent to grab the metals before you introduce CL to your pool. Use the sequestering agent according to the container instructions.
Your salt level should be around 3200 ppm, is it?
Posted on Jul 28, 2010
How much salt do you put in a 22,000gal. pool?
WOW... You have a huge above ground pool! Are you planning to use the Intex chlorinator to chlorinate your 22,000 gallon pool??? If you are, take a look at the max gallon rating and how long you may need to run... Here's a chart that should help you determine how much salt to add... After adding the salt, run the pump for 24 hrs without the chlorinator to properly dissolve the salt... Don't be surprised if you need to add above 500 lbs!!!
Good luck and hope this works for you...
Aug 22, 2011 | Intex Automatic Salt Water System for ...
I have an 18 by 48 Intex easy set pool and have had a high salt reading I emptyed about a 1/3 and ran clean in but still to high now its turning green what do you suggest I shock it with?
For your pool size you should have started with 160 lbs of salt. 18x48= 6,400 gallons of water. The manual says the only way to lower salt is to partially drain and refill with water, I do not believe there is anything you can add to remove salt. I would think you can throw in some regular chlorine shock to get the green out while you are adjusting the salt level.
Jul 11, 2011 | Intex Automatic Salt Water System for ...
We change our pool that we have had for 10 years over to the intex salt system. 4ft X 24 ft round above ground pool. 13500 gla water. We put in 10- 40lb bas of pool salt and have ran the system for the 12...
Jul 07, 2010 | Intex Automatic Salt Water System for ...
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
I have a Intex Pool that is 18 ft by 52 in. I have a Salt water chlorinator unit and I am tryiong to start up my pool. I added 80 kg of salt which is the recommended amount for my pool and then I ran my...
I have a krystal Clear deluxe Satlwater system recently the water went green(lots of rain) I added more salt and have run the pump extra time. It is better but not back to normal. Do I have to shock it and how do I do that? What and how much do I put in for an soft set pool 18 x 48.
thank you
Jun 17, 2010 | Intex Automatic Salt Water System for ...
My intex saltwater system green light then low salt light
You need to add salt to the water. How much depends on what size pool you have. Your owner's manual will tell you exactly how much to add when the low salt light comes on. On my Intex I would need to add 35 lbs.
May 30, 2010 | Intex Automatic Salt Water System for ...
How much salt do you add to a 18 x 48 pool
what is the average depth... your going to take your widthxlengthxaverage depth and then multiply by 7.48... thats how many gallons your pool makes up.... most salt chlorinators call for 2700 to 3700 ppm ... get yourself a salt test kit, and make sure you use salt made for swimming pools....
May 24, 2010 | Intex Automatic Salt Water System for ...
How much salt do i put in my pool. its 18 feet by 4 feet round. its the intex salt water system.
for the 18x48, you will add 135 pound (60 kgs) to start. When the Low Salt light comes on you add 35 pounds (15kgs)
May 22, 2010 | Intex Automatic Salt Water System for ...
Just added an Intex salt water Gernerator to my existing above ground pool. Water is green, can I add chlorine shock to speed up the process. And Ph is low. Can i add PH increaser or should I just wait and...
Apr 18, 2010 | Intex Automatic Salt Water System for ...
Low salt
Same here, been getting the 91 code, 3 times in last 1 1/2 weeks. Added salt. Came on today, so I checked titanium plates and they were half clogged with white stuff. DO NOT ADD SALT just because 91 code is on, which I have done. . You need to check plates and clean if clogged, with hose and some pressure. I used a plastic wire tie to clean, do not use metal item to clean plates, you'll scratch the plates and ruin them. Mine was clogged on 2 plates full length.
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
191 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
