Question about Insignia 2.0 Speaker System (2-Piece)
I have plugged my Insignia speakes into my Toshiba laptop and also into the electrical wall outlet. The power light is on, the volume is turned up, but I am getting no sound from them. Is there another place to plug them into my laptop that I can't find?
  • 670 Answers
Without the speakers is there sound coming out of the laptop?
normally you just have to plug it to the headset port, it's usually a 3.5mm hole.
Make sure that the computer is not muted so that sounds will be coming out and adjust the volume from the computer itself.
Hope this helps!
Posted on May 28, 2011
Testimonial: "You hit the nail on the head... I had the plug in the wrong hole. Thanks!!"
Why a 19' Insignia TV wont turn on?
Verify you have power at the outlet, and the TV plug. If no power check breaker. If it was moved recently to anoither location the wall outlet may be on a switched circuit, or downstream of a GFCI outlet.
Aug 20, 2014 | Insignia NS-LCD19 19 in. LCD TV
Tip
Laptop will not turn on, laptop will not power on, laptop will not start
Make sure your laptop battery has a charge. Plug it into the wall outlet for 30+ minutes and then try powering it on. When you plug it into a power source, usually the laptop will have a light indicating that it is charging. Look for a light. If the light does not light up, try a different wall outlet. <br />If it still does not charge, you may have a bad power cord, a bad laptop battery, the wall outlet may be bad or the laptop itself is damaged and will need to be serviced by a technician or replaced.<br /><br />Through the process of elimination you can narrow down possible causes.<br />-Try a different wall outlet(or by testing another device make sure the wall outlet is good)<br />-Try a different power cable.<br />-Try a different laptop battery.<br /><br />If none of the above help then you may need to have your laptop repaired(internal damage) or replaced.<br /><br />If your laptop is under warranty you should contact your laptop manufacturer or warranty policy holder to have it repaired or even replaced. <br /><br />If it is not under warranty you should look for local computer repair shops or technicians. <br /><br />-G33k<br />
on May 22, 2011 | Computers & Internet
My toshiba is charging but onlythe cord out lets bliking what does that mean
Plug the adapter into the wall outlet or power strip. If using a power strip, make sure the strip is on. Most laptop power adapters have a small LED light; the light will illuminate when power is being transferred from the outlet to the adapter. If the light illuminates, chances are you have sufficient power to supply your laptop. Wiggle the power cord if the LED light did not initially illuminate. If the light turns on and off when you wiggle it, you might have a loose cord in the adapter, or the outlet could be faulty. Plug the adapter into another power outlet, preferably a different circuit in another room, if the LED light did not illuminate the first time. If it lights up from the second outlet, the first outlet either does not work or other devices were using too much power on the initial circuit. Connect the other end of the adapter to the laptop and turn the laptop on. When the computer starts up, you should see an indication of how the laptop is being powered in the lower right-hand corner. If you see a battery icon, then the laptop is being powered by the battery, not the adapter. Make sure both ends of the adapter are securely connected. If they are, and if the LED light on the adapter is lit, then you likely have a faulty wire that is not properly connecting to your computer. If you see a plug or adapter icon, then the laptop is successfully being powered by the adapter. If the LED light on the adapter is not lit, then the bulb is out, but the adapter is still working.
Jan 20, 2013 | Toshiba Satellite Pro L300 Notebook
There is no power to the speaker, the green light is not showing. We have changed the plug fuse but this was not the problem
If you're talking about a powered subwoofer pluged into an electrical wall outlet check the wall outlet. One of my kids could not get a lamp to turn on in the den. It turned out the outlet was switched off from accross the room by a wall light switch. To check your electric wall outlet, plug in something, like a lamp, fan or a clock and see if it turns on. If not, look for wall light switches and flip them on and off. If it (example fan) dosn't turn on, you have a problem with your house electrical system. Probably right there at that outlet.
Sep 08, 2011 | Revel Audio Players & Recorders
No power. Will not turn on
Not intended to offend;
1. If using A/C (house electrical power), please check if electrical wall outlet is active. Attempt to plug-in another electrical device such as a lamp, clock, radio, etc.. If the electrical wall outlet has top and bottom plugs, try the top and then the bottom plug to see which one works. Sometimes, the top outlet will not work, yet the bottom outlet does work. The wall outlet should be replaced by qualified technician.
2. If both outlets do NOT work, and the outlet is GFCI breaker protected, maybe pressing the RESET switch on the outlet will power-up the outlet.
3. If the outlet is NOT GFCI breaker protected, check your electrical fuse box for a tripped fuse. Sometimes, a tripped fuse is NOT visible. May have to trip the specific fuse or all fuses to off, then back on. Recheck the wall outlet.
4. Once your know the outlet is live, check the power cord (a/c adapter for laptops) to make sure they are securely plugged-in to both the wall outlet AND the PC or Laptop.
Will need more information once the above steps are taken:
Is it a Desktop or Laptop?
Make and Model (if known)?
Any lights (glowing) on the desktop or laptop?
Any lights on the A/C adapter if its a laptop?
Mar 30, 2011 | Computers & Internet
If your laptop has a bad battery, will the computer still be able to turn on when plugged into a power outlet?
If your battery is totally drained or dead, your laptop will not turn on even when plugged in to power outlet. The power from the charger don't have enough power to pass through the battery that is trying to charge. Remove the battery and you will be able to turn on your laptop when plugged in directly to wall outlet.
Sep 21, 2010 | Toshiba Satellite M35X-S163 Notebook
Have an insignia tv that won't power on...was off..made popping noise...won't power on. checked power in both the surge protector it was in & wall. all other items plugged into surge protector work....
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Insignia NS-LTDVD19-09 LCD TV
My bluetooth wont turn off, the blue light stays on, and i cant pair it with my phone
To reset the hardware:
• Plug the charger into a power outlet, then press the
Volume Up and Volume Down buttons at the same
time. This turns off power to the headset and resets it.
Mar 14, 2010 | Insignia Bluetooth Wireless Headphones...
Toshiba satellite p105-s6217 will not power up or charge.
Larry,
  1. Unplug the laptop and remove the battery.
  2. Press the power button down and hold for 10 to 15 seconds.
  3. Press the power button 5 more times quickly.
  4. Plug the power back into the laptop without the battery and press the power button.
If the laptop powers on just put the battery back in.
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Insignia 2.0 Speaker System (2-Piece) Logo
193 people viewed this question
Top Insignia Audio Players & Recorders Experts
Curt Larson
Level 1 Expert
Steven Wander
Steven Wander
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
