Question about HP LaserJet 9500n Printer
59.6M PRINTER ERROR - HP LaserJet 9500n Printer
  • HP Master
  • 1,915 Answers
This error indicates a problem with the magenta drum rotation motor. Remove the magenta drum unit and reseat it. Restart the printer. If the error still continues then replace the drum. You can also look in the install slot for the magenta drum to see if there is any visible damage.
Posted on May 28, 2011
Message showing LSU Error
this is a laser scan unit error, either lsu reuires services , else needs replacement.
Nov 20, 2016 | Office Equipment & Supplies
HP photosmart 1215 Inkjet Printer Error
Dial 1-800-436-0509 HP printer technical support phone number to fix HP Printer Fuse Error, HP printer support helpline help you to get fix all type of HP printers. HP printer support helpline is open 24*7 to support you online.
http://www.hpprintersupporthelpline.com/hp-printer-50-9-fuse-error-contact-1-800-436-0509-tech-support-to-fix-it
Jul 17, 2016 | HP PhotoSmart 1215 InkJet Printer
Show error 52.00
52.X PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Apr 16, 2016 | HP LaserJet 4350n Printer
My printer ESP5210 is showing error codes 3501,3606,3507. What can i do to fix this
To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
for more help visit https://cbrtechsolutions.net
Sep 29, 2012 | Kodak Esp 5210 Inkjet All-in-one...
Error 163 on oki c5500 printer
163 Toner Sensor Error, Color: Black An error has been detected in your printer's Toner Sensor.
1 Machine Check Exception A problem has been detected in the printer hardware
2 DSI Exception The printers main logic has attempted to look up an invalid address.
3 ISI Exception The printers main logic has attempted to read the next instruction, which has failed to execute for some reason.
4 Alignment Exception The printers main logic cannot access the memory for some reason.
5 Program Exception The printers main logic has issued an exception code.
6 Floating-point Unavailable Exception A floating-point instruction is executed when the MSR floating point enable bit is set to Disable.
7 Instruction Address Breakpoint Exception The printers main logic has attempted to look up an invalid address.
20 CU ROM Hash Check Error 1 CU ROM hash check error has been found. Check reproducibility if possible.
21 CU ROM Hash Check Error 2 The printers CPU has a checksum error in it's memory.
23 CU ROM Hash Check Error (resident) Seek service if restarting the printer does not correct the problem.
25 CU ROM Hash Check Error (DIMM2) Seek service if restarting the printer does not correct the problem.
30 CU Slot1 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 1
31 CU Slot2 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 2
35 Slot1 RAM Spec Error Check the specification and install in slot 1 RAMs supported by the product
40 CU EEPROM Error The EEPROM mounted on the CU board needs to be replaced
41 CU Flash Error The CU Flash needs to be replaced
43 Flash File System Version Mismatch Seek Service if restarting the printer and initialising the flash memory does not correct the problem
42 Flash File System Error Seek Service if restarting the printer and initialising the flash memory does not correct the problem
43 PS Flash File System Error An Flash Memory error has occured and the printer needs to be serviced if restarting the printer does not correct the problem
51 CU Fan Error The CU cooling fan needs to be replaced if restarting the printer does not correct the problem
70 Postscript Failure An error has been detected in your printer's Postscript Core.
72 Engine Communication Error A communications error has occurred between CU and PU boards.
73 H/W Overrun Detect An error has been detected in your printer's hardware input area.
74 F/W Overrun Detect Occurs when the firmware is unable to set video data in response to video DMA's data request.
75 VIC Limiter An error has been detected in your printer's
80 Parameter I/O Error An error has been detected in your printer's Input/Output area.
81 Parameter Consistency Check Error The EEPROM and flash memory reformatted and initialized.
102 Engine RAM Error An error has been detected in your printer's engine RAM.
103 Engine SRAM Error An error has been detected in your printer's engine SRAM.
104 Engine EEPROM Error An error has been detected in your printer's engine reading/writing the EEPROM at power-up.
105 Engine EEPROM Missing Error An error has been detected in your printer's Engine
106 Engine Control Error An error has been detected in your printer's Engine Controller.
122 Power Supply Fan Motor Error An error has been detected in your printer's Power Supply Fan Motor.
123 Humidity Sensor An error. has been detected in your printer's Humidity Sensor
124 Temperature Sensor An error has been detected in your printer's Temperature Sensor.
127 Fuser Unit Fan Error An error has been detected in your printer's Fuser Unit Fan Error.
131 LED Head Missing, Color: Yellow When yellow LED head connection cannot be detected
132 LED Head Missing, Color: Magenta When magenta LED head connection cannot be detected
133 LED Head Missing, Color: Cyan When cyan LED head connection cannot be detected.
134 LED Head Missing, Color: Black When black LED head connection cannot be detected.
140 Drum Up/Down, Color: Yellow An error has been detected in your printer's Yellow Drum
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum.
142 Drum Up/Down, Color: Cyan An error has been detected in your printer's Cyan Drum.
150 Drum Fuse cut NG, Color: Yellow An error has been detected in your printer's Drum Fuse.
152 Drum Fuse cut NG, Color: Cyan An error has been detected in your printer's Drum Fuse.
153 Drum Fuse cut NG, Color: Black An error has been detected in your printer's Drum Fuse.
155 Fuser Unit Fuse cut NG An error has been detected in your printer's Fuser Unit.
154 Belt Unit Fuse cut NG An error has been detected in your printer's Belt Unit.
160 Toner Sensor Error, Color: Yellow An error has been detected in your printer's Toner Sensor.
161 Toner Sensor Error, Color: Magenta An error has been detected in your printer's Toner Sensor.
162 Toner Sensor Error, Color: Cyan An error has been detected in your printer's Toner Sensor.
170 Upper Thermistor, State: Short An error has been detected in your printer's Upper Thermistor.
171 Upper Thermistor, State: Open Restart the printer. If the problem continues the printer will need to be serviced
172 Upper Heat Temp, State: High An error has been detected in your printer's Upper Heat Temp.
173 Upper Heat Temp, State: Low Turn the printer off to let it cool down, then restart the printer.
181 I/F Error, Loc. Duplex An error has been detected in your printer's Duplexer.
182 I/F Error, Loc. Tray2 An error has been detected in your printer's Tray2.
187 I/F Error, Loc. Control Pnale An error has been detected in your printer's Control Panel.
190 System Memory Overflow An error has been detected in your printer's System Memory Overflow.
191 Page Memory Overflow An error has been detected in your printer's Page Memory Overflow.
200 PU F/W download Check Sum Error Error during PU flash download
201 PU F/W Flash Write Error An error has been detected in your printer's PU F/W Flash Write Error.
202 PU F/W Flash Data Missing An error has been detected in your printer's PU F/W download Check Sum Error.
203 Engine Page Sequences IMAGACK Error An error has been detected in your printer's Engine Page Sequences IMAGACK Error.
204 EnginePageSequences IMGSET Error An error has been detected in your printer's Engine Page Sequences IMGSET Error.
2005 Oki Data Americas, Inc.
Sep 14, 2012 | OKI C5500n Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Error code 6202
Thank you for contacting FixYa printer support. Error: "Printer error" (6202) Published 08/25/2010 11:38 AM ' Updated 05/20/2011 09:04 AM ' Answer ID 1247
How do I resolve the error message "Printer error" (error code 6202)?
To resolve this error:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
If the error continues and you cannot upgrade the firmware, contact Kodak Technical Support.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 11, 2011 | Office Equipment & Supplies
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
HP LaserJet 9500n Printer Logo
679 people viewed this question
Seeker5211
Seeker5211
