I have a LOGITECH X540 5 1 140W one day i played music in the morning and came home from work and it totally stoped working i went through properties to fix it but nothing is working i even pluged it in to my mp3 player and blackberry normally it works but im getting no sound but when i press the power button i hear the speaker getting turned on.
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 28, 2011
Right side of headphone stoped working
you need to open the broken side up and re solder the cable back also check the other cable to see if it hasn't sheered off inside the insulation like mine did. Hope this helps. J
Feb 17, 2013 | Philips SHB9100/00 Bluetooth Stereo...
My speakers does not play on my pc. i have purchased them with the pc together. they play on my laptop,ipod but nt on my pc. my os is windows vista home basic..help please
have you try to play a music when it still in the store? does it work?.. replace it with a new one in the store tell them whats wrong,.. install a audio device that support your speaker... thank you and have a nice day..
Apr 29, 2011 | Logitech R-10 Computer Speakers
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
My ps3 won't play my disk-based games
This sounds a similar problem what I had. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
LOGITECH COMPUTER MOUSE JUST STOPED WORKING
On the bottom of the mouse is a small door and it takes two AA batteries.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Jan 06, 2009 | Computers & Internet
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Logitech speakers will only play on 2 speakers not 5
Liamog, i bought the exact same speakers and sound card, and i had the exact same problem as you. I tried for days to fix it and it turns out that its only a setting you have to enable in your sound card settigns. If you go into your EAX console for your creative sound card you will find a thing that sams CMSS 3D, and all you have to do is select the button that says Enable CMSS 3d surround. I hope this will fix your problem. Alex.
Nov 11, 2006 | Logitech X-530 Computer Speakers
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
