Question about Canon PowerShot S5 IS Digital Camera
Super macro It says hold macro button for more than a second to get super macro mode and I'll see its icon appear on the LCD monitor. It doesn't. The image remains blurry.
Press the macro button once to get it to display the Macro Mode sign. Press and hold it after that to get it into Super Macro
Once you are in Super Macro, you can't move the lens so you MUST use the Manual Focus (MF) button that is located right above the Macro toggle button. While holding the MF button, use the 4 way directional pad to focus in and out. Press the Up and Down to focus.
You have to be REALLY close for Super mode.. less than about 6 inches
Posted on Aug 17, 2008
All photos I take have suddenly become blurred on my vivitar Vivicam 8225
The reasons why Photos get blurry might not always be an issue with the lens. Here are a few things you should consider -
1) Check if the Battery of the Camera is fully charged. This can hugely effect the outcome of your pictures.
2) Make sure the Memory Card is not full.
3) Check for the Macro or Normal mode. To do this, simply check the top of the LCD Screen. If you find a "Flower" Icon, then the camera is set into Macro mode. To change this, press the OK/Menu button. Find the Macro menu and press up/down to make Macro Off and Normal (Mountain Icon) to On. The camera is now changed into Normal Mode and a Mountain/Pyramid icon should be there at the top of your screen.
4) Try increasing the resolution. Again press the OK/Menu button and press Right/Left until you find a "Lines" icon. Press the Down/Up arrow to choose the resolution. 8M is the highest. Press OK to confirm.
Note - Higher the resolution, better the picture quality but lesser the number of pictures you can save.
5) Check if there is a Crossed Thunder Bolt icon on the LCD screen. If you find one, the flash has been turned off. To turn it on, press the Up/Thunder Bolt. A Crossed Arrow with an A should appear. This indicates the Camera has been set to auto Flash.
Hope the images get better with these tips. You can always call Sakar International at 877-397-8200
Aug 28, 2010 | Vivitar ViviCam 8025 Digital Camera
The camera will not focus when I try to take up-close shots. Such as an eye. I would like to photograph just an eye but whenever I try to zoom or walk in close enough the camera refuses to focus, haha....
Normally the closest focus you can get is 1.6 ft at W and 3.0 ft at T. In Macro mode you can get down to 3.9 inches. In Super Macro mode you can get even closer.
To get into Macro mode, press the Flower button until the flower appears on the LCD. To get into Super Macro mode, keep pressing the Flower button until an S appears inside the flower.
For full details, refer to your manual. In my copy, it starts on page 56.
Feb 20, 2010 | Canon PowerShot S2 IS Digital Camera
I cannot get super macro mode
Turn the dial- the one that lets you select a mode. You have to be in certain modes to allow for super macro.... (I have a powershot S2) Try AV or manual, or a couple of others. There are a few that will not allow super macro. That's your problem. Good luck!
Feb 02, 2009 | Canon PowerShot SX10 IS Digital Camera
LCD screen black, no viewed image displayed.
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Jul 31, 2008 | Ricoh Caplio R30 Digital Camera
I can't get my Powershot S5 to go into Super Macro mode - Help!
There seem to be two stipulations for getting into super macro mode,
First you must be in scn ("A" or "S" mode's only) and "movie", "P", "TV", "AV" or "M" modes only.
Secondly the zoom Lens must be all the way out.. set at the widest angle.
Best of luck
Jun 14, 2008 | Canon PowerShot S5 IS Digital Camera
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Focus
Your camera has the ability to shoot Macro and Super Macro, although in some Dial Modes, you can't use Macro.
To engage the Macro mode, press once the button on the left side of the lens/camera that looks like a Flower. To engage the Super Macro mode, press and hold the same button for more than one second.
Macro mode range 3.9 in. - 1.6 ft
Super Macro mode range is 0 in. - 3.9 in.
To cancel Macro mode, press the Flower icon button once.
Zoom levels are limited, and you will know that when the zoom bar turns yellow. This means the zoom is not available at that zoom level.
Hope this helps.
Nov 24, 2007 | Canon PowerShot S3 IS Digital Camera
Canon Powershot S2 IS Super Macro mode
Make sure your camera isn't zoomed in (full telephoto) The camera can't handle both full zoom AND super macro. Don't forget super macro goes from Zero to 20cm from the lens. Zoom completely out and you should be able to see something within that range. The biggest complaint I've heard about the S2 IS is if you take closeups of bugs the chances of the bug crawling onto your lens is pretty good.:-) Be very carefull of blocking light with the lens at extreme closeup too. Although the flash squelches well to allow for closeups it can leave a nasty shadow. If you're really serious about macro you'll find a ring flash would come in handy. BMW
Jul 13, 2006 | Canon PowerShot S2 IS Digital Camera
Macro mode
The Macro Mode is easily accessed by pressing the second oval shaped button to the left of the arrow pad on the back of the camera. This button is designated by a green colored box with a curved doubled headed arrow – which will rotate the image file when in view mode. The same button also has a flower icon, which represents MACRO MODE when in Shooting mode. Pressing thios button in Shooting Mode displays a menu where you select three options: OFF, Close-Up or Super Close-Up photography.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
200 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
